Author Topic: MAMEWAH crashes on me with this error..  (Read 1313 times)
JoeB
  • Last login:Today at 11:09:06 am
  • NES Fanatic
« on: September 30, 2003, 09:37:21 pm »
not sure what I did..
but every time I try to switch emulators in MAMEWAH, it crashes on me with the following error:
Run-time error '384':
A form can't be moved or sized
while minimized or maximized.
I'm using the latest version of MAMEWAH, and it happens when I try to switch to a different pre-defined emulator from the one that's currently selected.
The only other thing I'm ready to do at this point is a fresh install of the app..
But what can cause this??
Re:MAMEWAH crashes on me with this error..
« Reply #1 on: October 01, 2003, 05:03:01 am »
Are you using different layouts for different emulators?
JoeB
  • NES Fanatic
« Reply #2 on: October 01, 2003, 11:31:15 pm »
yes I am..
JoeB
  • NES Fanatic
« Reply #3 on: October 05, 2003, 03:08:29 pm »
I have just manged to narrow it down to something in the layout file that Mamewah doesn't like.. (even the older version).  The wierd thing though, if I tell MAMEWAH to use a specific default (current) emulator, it loads it fine!
If I use MAMEWAH to switch to another, it crashes.. if I manually switch it in the MAMEWAH.CFG file, it loads it fine.
« Reply #4 on: October 06, 2003, 05:11:04 am »
Sounds like a bug - I will fix for the next version...
JoeB
  • NES Fanatic
