Author Topic: WTB: 49 Way Joystick Part  (Read 1438 times)
Stack15
  • Last login:July 22, 2012, 10:16:06 pm
« on: April 29, 2012, 11:32:04 pm »
This is my first post...
I believe I need to purchase an optical board for an Atari 49 way joystick.  I mean the green PC looking board within the joystick assembly that the cord plugs into.  It has a part number of either 04-11135 or 5772-15356-83.  I think this is it here:
http://na.suzohapp.com/joysticks/a219391.htm
It appears to be a $7.55 part, but by the time I pay the $10 surcharge for being a small order and $15 shipping, that $7.55 part is costing me $32.55.  Is there a cheaper way to get one of these things?  Is there a "better" website that I'm just not aware of yet?
Here is there rest of the story:
I purchased a Gaulent Legends arcade game made by atari.  One of the characters goes to the right when the joystick is pushed left and goes right when the joystick is pushed right.  I disassembled the joystick and cleaned everything... this didn't help, but when I switched what I believe is the optical board with the one from the joystick next to it, everything works fine.
Stack15
Re: WTB: 49 Way Joystick Part
« Reply #1 on: April 29, 2012, 11:40:08 pm »
This is the part I need.  Thanks!
lilshawn
  • Last login:Today at 05:48:23 pm
« Reply #2 on: May 02, 2012, 06:28:22 pm »
i'll check my parts bins at the shop tomorrow and see if there is a board there. i know we have a couple of cabs that use those joysticks but not sure about parts.
edit: those optos look pretty standard, you sure you can't find someplace to buy just an opto sensor (or scab a part from maybe a printer or old fax machine???)
« Last Edit: May 02, 2012, 06:30:59 pm by lilshawn »
MonMotha
« Reply #3 on: May 02, 2012, 09:17:24 pm »
FWIW, if you end up needing to order something, Divemaster127 on here can get basically anything Happ actually has at much more reasonable prices.
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
« Reply #4 on: May 02, 2012, 10:21:21 pm »
I have 3 full joysticks sitting in a blitz 99 cp
