Author Topic: autostart arcade os?  (Read 3747 times)
amers1
« on: May 13, 2002, 12:03:59 am »
is there a way to have aos auto start in dos without  starting windoze? but I have win95 on this pc and want to leave it on it.
thanks
amers1
JustMichael
  • Mmmmm!! Cheesecake!!
Re: autostart arcade os?
« Reply #1 on: May 18, 2002, 10:58:13 am »
Make a boot floppy and have your computer boot from that.  Then you don't have to change a thing on your hard drive.  Just eject the disk whenever you want to boot to windows.
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #2 on: May 30, 2002, 01:27:24 pm »
thanks
amers1
Make the last two lines in your autoexec.bat file look like this
cd c:\arcadeos
arcadeos
then arcadeos will launch on startup. if you exit arcadeos, then win95 will launch. When you're testing stuff, put the line
pause
infront of the cd line. Then your computer will wait before it launches AOS. You can use ctrl-c to break the batch file at that point to edit things.
bob
south carolina
