Author Topic: FS: Tron & 2 Tigers Spinner, Kickman 2 way trackball, wico 3" red trackball[MN]  (Read 1159 times)
I have some original arcade parts for sale, I wanted to post them here before trying ebay. I have not been able to test the equipment, but have no reason to believe that they wouldn't work. In the US, shipping is $10.00 flat rate no matter if you order 1, 2, 3 or all 4 items. Outside of US, PM me for a quote. Payment with Paypal.
1) Tron Spinner $45
Original Tron Spinner from upright cabinet. Can't test, but spins fine, encoder wheel is straight, and PCB looks fine.  Rust is on the mounting plate of the spinner, but light sanding and painting will fix. Knob in good condition but missing sticker.
2) Two Tigers spinner $35
Spinner put in Tron machines for player 2 when converted to a two tigers machine. This is a Midway spinner just like the tron, has the same weight, knob and feel of a tron spinner with same dimension of mounting plate. Still no sticker on top. Spins smoothly, has a straight encoder wheel.
3) Kick / Kickman 2-way trackball $20
Depending on who you talk to, this is either a 2 way trackball, or a ball style spinner. It only goes left and right, so it has the feel of a trackball, but the function of a spinner. There are a few scuffs on the ball, but in overall good shape. It spins really nicely, but the little inlet screw that fastens the encoder wheel to the shaft is missing. The encoder wheel also has a couple teeth that need to be gently bend a little to perfectly line up.
4) Wico translucent Red illuminated trackball. $25
I don't know what this trackball was used in, but it is a complete set except the screws to hold the shell together are missing. There are very standard screws, and finding something to fit won't be a problem. Cosmetically, the trackball has 1 half inch scratch and a number of tiny nicks in it. Not enough to really affect play, but nicks tend to be more noticeable on an illuminated trackball, so a new ball might be desired. The shell has scuffing but is fine. The rollers are fine for used. The LED is mounted on the underneath of the shell, and I am assuming it is a white LED.
Madaracs
  • Last login:April 05, 2023, 03:51:17 pm
I would like to buy the Tron spinner but I can't PM anyone on this board for some reason.  I'm also on KLOV.
Hey Madaracs!
Yeah, over here PMs are restricted on members with low post counts. I will PM you with my Paypal. If you have any questions on it, you can feel free to either post here or reply to the PM. There are no restrictions on replying to PMs.
