Author Topic: Neo Geo 1st time boot - wierd screen  (Read 1649 times)
b3dr0ck
  • Last login:January 05, 2014, 05:49:02 pm
« on: April 23, 2012, 01:25:58 am »
So ... continuing on this project - thanks for everyone's help so far
I've got the AC straight, the 5V and the 12V at the Jamma connector are good.
I connect a monitor, I turn on power and I get this screen.  It flashes back and forth.  I took 2 pics so you could see it, sorta.
I plugged another Jamma board in, and the video on it seemed OK.  Any ideas?
MTPPC
Re: Neo Geo 1st time boot - wierd screen
« Reply #1 on: April 23, 2012, 09:33:49 am »
Clearly the monitor is good. Maybe reseat the chips on the board.
http://pinballmd.com/
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: April 23, 2012, 10:36:56 am »
Channelmaniac's repair logs are a good place to start -- here is the link to his NeoGeo logs:
http://newlifegames.net/nlg/index.php?PHPSESSID=09bc4649c6c5ed7155098b55d60b12cb&topic=152.0
Working: Not Enough
Projects: Too Many
Progress: None
  • Last login:Today at 10:22:04 am
« Reply #3 on: April 23, 2012, 11:16:44 am »
1. Does the motherboard BIOS match the cart's region?
2. Take a q-tip and rubbing alcohol and remove any dirt from the connectors on both cart and motherboard.
