Author Topic: Mala 1.74 crashes  (Read 3067 times)
Knightlore
  • Last login:June 04, 2014, 07:44:55 am
Mala 1.74 crashes
« on: April 07, 2012, 04:56:44 pm »
Hi, I'm trying to set up my cab, got the artwork loaded on (which ran fine with standard layout) but I changed the layout and now for some reason every layout I try (including standard) gives me exception errors.
I think it is the same problem this guy was having :
http://forum.arcadecontrols.com/index.php?topic=111681.0
And there was a mention of Bios files appearing in the gamelist, I too have this and wondered if that was the problem or not?
Knightlore
Re: Mala 1.74 crashes
« Reply #1 on: April 08, 2012, 03:12:45 am »
Just to confirm, these are the errors I'm getting :
Error: Exception Message: Scan line index out of range, Object Function: LoadPicture, Exception Class: EInvalidGraphicOperation, Object Class: TfrmMain
Info: Showing taskbar
Error: AppException: Terminating MaLa
Info: Screensaver: ScreenSaver Form Destroyed
EDIT - Sorted this, using Romlister to take out the bios files.
« Last Edit: April 09, 2012, 02:14:23 pm by Knightlore »
loadman
  • Moderator
    • MaLa
« Reply #2 on: June 11, 2012, 02:49:38 am »
cool ;D
