Author Topic: Wiring troubles  (Read 2792 times)
dprush83
  • Last login:January 13, 2020, 12:47:54 pm
Wiring troubles
« on: April 05, 2012, 02:51:32 am »
Tonight I wired up my control panel, I was very excited to test the inputs before loading a game. In the game I found an issue with my UP button, though. The input goes through, but only one quick up motion and then the input ceases even if I hold up. For Mario to go up a ladder in DK you have to hit up 4-5 times.
I thought it was a loose connection, but after trying a few adjustments I got a new wire and even needle nosed the wire directly to the prong...still the same issue.
Anybody know what might be causing this??
Louis Tully
Re: Wiring troubles
« Reply #1 on: April 05, 2012, 05:29:14 am »
« Last Edit: February 12, 2015, 05:32:34 am by Louis Tully »
mytymaus007
Re: Wiring troubles
« Reply #2 on: April 05, 2012, 08:11:45 am »
what encoder are you using? Try another input to see if it that and if its still doing the samething try a different switch
dprush83
Re: Wiring troubles
« Reply #3 on: April 05, 2012, 09:24:56 am »
It is being run through MAME, but the problem occurs in other programs too (game selection in Hyperspin).  I'm using an ipac, I rewired that input a couple of times to make sure I installed it correctly.  Good ideas about the switch, I will try that tonight to see if perhaps that is it.
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: Wiring troubles
« Reply #4 on: April 05, 2012, 09:29:28 am »
I've never had any problems with my IPacs but I would check the switch on the up and then if the problem persists I would give a visual glance over for the solders on the bottom of the IPac board.  Make sure it didn't get damaged possibly.
MTPPC
Re: Wiring troubles
« Reply #5 on: April 05, 2012, 10:07:02 am »
I had this problem with a switch on a zippy joystick.
http://pinballmd.com/
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
Re: Wiring troubles
« Reply #6 on: April 05, 2012, 10:25:09 am »
Temporarily hook your "up" to one of your buttons or another direction on your joystick and see what that does.
