Author Topic: None-interlaced modelines for Xorg(Linux)  (Read 10592 times)
Lomaxx
  • Last login:April 23, 2012, 02:42:54 pm
« on: April 03, 2012, 08:14:53 am »
I'm searching for all possible composite modes (Modelines) for use with a PAL-CRT-TV over a vga-scart-cable that I can use in Xorg.
Interlaced modes are out of interest to me because I can't stand that flickering.
By using "lrmc", so far I found working resolutions for my old nvidia-card from "408x288x50.08" up to somewhere at "1296x288x50.08" (stopped searching there as it doesn't make much sense) with increasing steps of 8 for the horizontal resolution (408,416,424,432,....).
EDIT: Note that i used a wrong term in the first few posts from here on: When ever I wrote of "composite modes", I actually ment "progressive modes". Sorry for the confusion, but I don't know much about the different video-modes.
But I wonder if there are composite modes possible with a different height than 288 lines/pixels for use with a PAL-CRT-TV?
« Last Edit: April 03, 2012, 03:01:46 pm by Lomaxx »
Calamity
  • Moderator
  • Last login:Today at 08:05:28 am
  • Quote me with care
Re: None-interlaced modelines for Xorg(Linux)
« Reply #1 on: April 03, 2012, 08:30:01 am »
Hi Lomaxx, just one question first, by "composite modes" you mean composite sync?
Steps to create a log:
Lomaxx
« Reply #2 on: April 03, 2012, 08:46:38 am »
Rehi, Calamity.
I probably do mean "composite sync", yes. ;)
I mean those Modelines that do not have the "interlaced" option set at the end. The once I use look like this one:
Code: [Select]
   Modeline "408x288x50.08"  7.875000  408 424 464 504  288 293 296 312  -HSync -VSync
So far I only know of these two types - with and without "interlaced" -  of which i prefer the ones without. But pretty much any mode without flickering is welcome. =)
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #3 on: April 03, 2012, 09:30:34 am »
Try this (got from "umc"):
Code: [Select]
    # 640x480x31.60 @ 15.610kHz
    Modeline "640x480x31.60"  12.488320  640 656 720 800  480 484 488 494  -HSync +VSync
The only thing the monitor (probably) won't like is 31.60Hz as horizontal refresh rate.
Earth could be the hell of another world
Lomaxx
« Reply #4 on: April 03, 2012, 10:17:55 am »
Hello Ansa89.
I tried your line. That's not excepted at all, although i checked several times that I added it correctly to the two related sections in xorg.conf.
from the Xorg.0.log-file: "[ 22615.326] (WW) NVIDIA(1): No valid modes for "640x480x31.06"; removing."
Because of this it doesn't appear at all in the xrandr-selection-list.
Ansa89
« Reply #5 on: April 03, 2012, 10:22:47 am »
The modeline is used on a pal tv, ntsc tv, or arcade monitor?
Try changing "+VSync" with "-VSync".
Lomaxx
« Reply #6 on: April 03, 2012, 11:08:31 am »
On an old pal-crt-tv. I doubt that changing +/- will make a change, because it's not accepted at all, but i will try soon.
bleargh
  • Last login:Today at 12:05:22 pm
  • ribbit...
« Reply #7 on: April 03, 2012, 12:52:16 pm »
Have you tried looking over at the MythTV modeline database to see if they have anything close to what you need?
    http://www.mythtv.org/wiki/Modeline_Database
Ansa89
« Reply #8 on: April 03, 2012, 01:05:15 pm »
The modelines in the database seem all interlaced (or not for 15KHz).
bleargh
  • ribbit...
« Reply #9 on: April 03, 2012, 01:11:20 pm »
XFree86 modeline generator maybe?
    http://xtiming.sourceforge.net
Years ago, when I first started building my MAME cabinet (some eight or nine years back), there was a resource I used to help create all of my modelines.  For the life of me I can't remember WhatTF it was though.   :(
Calamity
  • Moderator
« Reply #10 on: April 03, 2012, 01:13:37 pm »
Rehi, Calamity.
Code: [Select]
Lomaxx, I think there's a confusion going on here. What you mean is progressive modes, that's the opposite to interlaced modes.
Whenever you see the "-HSync -VSync" in a modeline, it means the sync signals are separated. A composite sync modeline would have a single "Csync" param instead of those.
On the other hand, I strongly recommend you to use Switchres for modeline generation instead of lrmc or anything else. There's no possible comparison.
« Last Edit: April 03, 2012, 01:17:20 pm by Calamity »
Ansa89
« Reply #11 on: April 03, 2012, 01:18:49 pm »
The online modeline generator is more or less the same as "lrmc" or "umc" (imho).
BTW, Lomaxx asked for a modeline without interlace (for flickering problems), so the topic focus is on how get a "highres" (like 640x480) not-interlaced modeline.
Calamity
  • Moderator
« Reply #12 on: April 03, 2012, 01:35:20 pm »
Well that's obviously impossible within the 15 KHz / 50-60Hz range.
Horizontal resolutions are arbitrary, use the highest that looks fine. You'll need to use vertical resolutions like 224p, 240p, 248p, 256p, 264p, 272p, 280p, 288p (p stands for progressive). Refresh rate doesn't need to be restricted to 50 Hz, the TV will probably support 60 Hz too (probably not up to 256-288 lines).
« Last Edit: April 03, 2012, 01:39:16 pm by Calamity »
Ansa89
« Reply #13 on: April 03, 2012, 01:42:00 pm »
So the max possible resolution should be 400x300 at 49.76Hz (hoping the tv is a bit tolerant with refresh rate).
The alternative is 400x288 at 51.74Hz (but in this case we broke the 4:3 proportion).
Calamity
  • Moderator
« Reply #14 on: April 03, 2012, 02:04:18 pm »
400x300@49.76 is about 16KHz, the TV will likely support it but with huge vertical overscan, I don't think you can fix that overscan with the service menu. On the other hand, you should be able to adjust some arcade monitor to show that amount of lines.
If aspect matters you can use 384x288.
Lomaxx
« Reply #15 on: April 03, 2012, 02:59:35 pm »
Sorry for the confusion.  :-[ I'm not very firm with all these terms. From what you describe, Calamity, I do mean progressive modes, yes. I will edit the first post to reduce confusion.
However I am not necessarily searching for highres progressive modes. Just for any possibly horizontal resolution beside 228 in non-interlaced way. This can also be lower or just slightly higher.
I tried to somehow use switchres instead of lrmc, but I couldn't find out how to download or use it. I found a link which was supposed to be a link to the homepage of switchres, but that was just pointing to groovyarcade and it's sourcecode repository, where i couldn't make out anything like a switchres-stand-alone-command-line-programm.
Lomaxx
« Reply #16 on: April 03, 2012, 03:22:09 pm »
Update: Found the switchres-programm now.
Lomaxx
« Reply #17 on: April 04, 2012, 11:43:13 am »
hmm ... tried some modelines that switchres spit out, but none worked.
Code: [Select]
./switchres --emulator groovymame --monitor pal --nointerlace --calc mrdo
# mrdo 344x240@50.08 15.6250Khz
        ModeLine          "344x240x50.08" 6.624983 344 360 392 424 240 267 270 312 -HSync -VSync
./switchres --calc --monitor pal --nointerlace --emulator groovymame raiden
# raiden 400x256@50.08 15.6250Khz
        ModeLine          "400x256x50.08" 7.749980 400 416 456 496 256 275 278 312 -HSync -VSync
Maybe I will try some more, but I start to think that there are no other progressive modes than ???x288 possible.
Calamity
  • Moderator
« Reply #18 on: April 04, 2012, 11:48:38 am »
What do you mean that they don't work? Is the screen grabled when you use those?
Lomaxx
« Reply #19 on: April 04, 2012, 12:50:23 pm »
Yep. They are accepted, they show up in the xrandr-list, but when I set them then the picture keeps jumping, is misaligned and not of the right "size". In other words: is garbled.
Calamity
  • Moderator
« Reply #20 on: April 04, 2012, 04:13:57 pm »
Have you tried using the --monitor ntsc param? I wouldn't restrict it either to NTSC/PAL standards, better try cga settings.
Lomaxx
« Reply #21 on: April 05, 2012, 03:04:28 pm »
I now did something like a brute-force-test with the "--monitor cga"-option.
First I ran a double-FOR-loop to get a long list of modelines with 60hz:
Code: [Select]
for y in {104..800..8}; do for x in {104..800..8}; do ./switchres $x $y 60 --emulator groovymame --monitor cga ;done;done > /tmp/output_50hz.txt
Then I did the same with 50hz instead with output to a different- file, grepped for modelines, sorted and removed double-entries:
Code: [Select]
grep -h ModeLine output_60hz.txt output_50hz.txt | sort -ru > output_all.txt
After that i added all modelines below 640x480 of output_all.txt to the crtTV-"Monitor"-section of my xorg.conf and restarted X.
"DISPLAY=:0.1 xrandr" now showed many modes, but obviously lot's of them have not been accepted at all. I commented out these unaccepted modes (as an example I show the modes for horizontal-616-resolution):
Code: [Select]
#       ModeLine          "616x584x50.00" 12.625000 616 640 704 808 584 586 592 625 -HSync -VSync interlace
        ModeLine          "616x576x50.00" 12.216600 616 640 696 792 576 578 584 617 -HSync -VSync interlace
#       ModeLine          "616x568x50.00" 12.097800 616 640 696 792 568 571 577 611 -HSync -VSync interlace
#       ModeLine          "616x560x50.00" 12.097800 616 640 696 792 560 567 573 611 -HSync -VSync interlace
#       ModeLine          "616x552x50.00" 12.097800 616 640 696 792 552 563 569 611 -HSync -VSync interlace
#       ModeLine          "616x544x50.00" 12.097800 616 640 696 792 544 559 565 611 -HSync -VSync interlace
#       ModeLine          "616x536x50.00" 12.097800 616 640 696 792 536 555 561 611 -HSync -VSync interlace
#       ModeLine          "616x528x50.00" 12.097800 616 640 696 792 528 551 557 611 -HSync -VSync interlace
#       ModeLine          "616x520x50.00" 12.097800 616 640 696 792 520 547 553 611 -HSync -VSync interlace
#       ModeLine          "616x512x50.00" 12.097800 616 640 696 792 512 543 549 611 -HSync -VSync interlace
#       ModeLine          "616x504x50.00" 12.097800 616 640 696 792 504 539 545 611 -HSync -VSync interlace
#       ModeLine          "616x496x50.00" 12.097800 616 640 696 792 496 535 541 611 -HSync -VSync interlace
#       ModeLine          "616x488x50.00" 12.097800 616 640 696 792 488 531 537 611 -HSync -VSync interlace
        ModeLine          "616x480x60.00" 12.629040 616 640 704 808 480 482 488 521 -HSync -VSync interlace
        ModeLine          "616x480x50.00" 12.097800 616 640 696 792 480 527 533 611 -HSync -VSync interlace
        ModeLine          "616x472x60.00" 12.188880 616 640 696 792 472 474 480 513 -HSync -VSync interlace
        ModeLine          "616x472x50.00" 12.097800 616 640 696 792 472 523 529 611 -HSync -VSync interlace
#       ModeLine          "616x464x60.00" 12.093840 616 640 696 792 464 468 474 509 -HSync -VSync interlace
#       ModeLine          "616x464x50.00" 12.097800 616 640 696 792 464 519 525 611 -HSync -VSync interlace
#       ModeLine          "616x456x60.00" 12.093840 616 640 696 792 456 464 470 509 -HSync -VSync interlace
#       ModeLine          "616x456x50.00" 12.097800 616 640 696 792 456 515 521 611 -HSync -VSync interlace
        ModeLine          "616x288x50.97" 12.685600 616 640 704 808 288 289 292 308 -HSync -VSync
        ModeLine          "616x288x50.00" 12.196800 616 640 696 792 288 289 292 308 -HSync -VSync
        ModeLine          "616x280x52.33" 12.685600 616 640 704 808 280 281 284 300 -HSync -VSync
        ModeLine          "616x280x50.00" 12.078000 616 640 696 792 280 283 286 305 -HSync -VSync
        ModeLine          "616x272x53.77" 12.685599 616 640 704 808 272 273 276 292 -HSync -VSync
        ModeLine          "616x272x50.00" 12.078000 616 640 696 792 272 279 282 305 -HSync -VSync
        ModeLine          "616x264x55.28" 12.685600 616 640 704 808 264 265 268 284 -HSync -VSync
        ModeLine          "616x264x50.00" 12.078000 616 640 696 792 264 275 278 305 -HSync -VSync
        ModeLine          "616x256x56.88" 12.685599 616 640 704 808 256 257 260 276 -HSync -VSync
        ModeLine          "616x256x50.00" 12.078000 616 640 696 792 256 271 274 305 -HSync -VSync
        ModeLine          "616x248x58.58" 12.685599 616 640 704 808 248 249 252 268 -HSync -VSync
        ModeLine          "616x248x50.00" 12.078000 616 640 696 792 248 267 270 305 -HSync -VSync
        ModeLine          "616x240x60.00" 12.604800 616 640 704 808 240 241 244 260 -HSync -VSync
        ModeLine          "616x240x50.00" 12.078000 616 640 696 792 240 263 266 305 -HSync -VSync
#       ModeLine          "616x232x60.00" 12.117600 616 640 696 792 232 234 237 255 -HSync -VSync
#       ModeLine          "616x232x50.00" 12.078000 616 640 696 792 232 259 262 305 -HSync -VSync
#       ModeLine          "616x224x60.00" 12.117600 616 640 696 792 224 230 233 255 -HSync -VSync
#       ModeLine          "616x224x50.00" 12.078000 616 640 696 792 224 255 258 305 -HSync -VSync
#       ModeLine          "616x216x60.00" 12.117600 616 640 696 792 216 226 229 255 -HSync -VSync
#       ModeLine          "616x216x50.00" 12.078000 616 640 696 792 216 251 254 305 -HSync -VSync
#       ModeLine          "616x208x60.00" 12.117600 616 640 696 792 208 222 225 255 -HSync -VSync
#       ModeLine          "616x208x50.00" 12.078000 616 640 696 792 208 247 250 305 -HSync -VSync
#       ModeLine          "616x200x60.00" 12.117600 616 640 696 792 200 218 221 255 -HSync -VSync
#       ModeLine          "616x200x50.00" 12.078000 616 640 696 792 200 243 246 305 -HSync -VSync
#       ModeLine          "616x192x60.00" 12.117600 616 640 696 792 192 214 217 255 -HSync -VSync
#       ModeLine          "616x192x50.00" 12.078000 616 640 696 792 192 239 242 305 -HSync -VSync
#       ModeLine          "616x184x60.00" 12.117600 616 640 696 792 184 210 213 255 -HSync -VSync
#       ModeLine          "616x184x50.00" 12.078000 616 640 696 792 184 235 238 305 -HSync -VSync
#       ModeLine          "616x176x60.00" 12.117600 616 640 696 792 176 206 209 255 -HSync -VSync
#       ModeLine          "616x176x50.00" 12.078000 616 640 696 792 176 231 234 305 -HSync -VSync
#       ModeLine          "616x168x60.00" 12.117600 616 640 696 792 168 202 205 255 -HSync -VSync
#       ModeLine          "616x168x50.00" 12.078000 616 640 696 792 168 227 230 305 -HSync -VSync
#       ModeLine          "616x160x60.00" 12.117600 616 640 696 792 160 198 201 255 -HSync -VSync
#       ModeLine          "616x160x50.00" 12.078000 616 640 696 792 160 223 226 305 -HSync -VSync
#       ModeLine          "616x152x60.00" 12.117600 616 640 696 792 152 194 197 255 -HSync -VSync
#       ModeLine          "616x152x50.00" 12.078000 616 640 696 792 152 219 222 305 -HSync -VSync
#       ModeLine          "616x144x60.00" 12.117600 616 640 696 792 144 190 193 255 -HSync -VSync
#       ModeLine          "616x144x50.00" 12.078000 616 640 696 792 144 215 218 305 -HSync -VSync
#       ModeLine          "616x136x60.00" 12.117600 616 640 696 792 136 186 189 255 -HSync -VSync
#       ModeLine          "616x136x50.00" 12.078000 616 640 696 792 136 211 214 305 -HSync -VSync
#       ModeLine          "616x128x60.00" 12.117600 616 640 696 792 128 182 185 255 -HSync -VSync
#       ModeLine          "616x128x50.00" 12.078000 616 640 696 792 128 207 210 305 -HSync -VSync
#       ModeLine          "616x120x60.00" 12.117600 616 640 696 792 120 178 181 255 -HSync -VSync
#       ModeLine          "616x120x50.00" 12.078000 616 640 696 792 120 203 206 305 -HSync -VSync
#       ModeLine          "616x112x60.00" 12.117600 616 640 696 792 112 174 177 255 -HSync -VSync
#       ModeLine          "616x112x50.00" 12.078000 616 640 696 792 112 199 202 305 -HSync -VSync
        ModeLine          "616x104x60.00" 12.165120 616 640 696 792 104 111 112 128 -HSync -VSync doublescan
        ModeLine          "616x104x50.00" 12.117600 616 640 696 792 104 124 125 153 -HSync -VSync doublescan
I tested which of the remaining modelines produced a solid, working picture. Here they are:
Code: [Select]
The others of them only brought up a garbled picture. I also tried variations with +HSync and +VSync or both, but that didn't bring a change.
This is almost always the same pattern for all horizontal resolutions at least somewhere down to 400 (in steps of 8 ). Although I didn't test them all. ;) I will try around some more.
« Last Edit: April 05, 2012, 03:35:36 pm by Lomaxx »
Lomaxx
« Reply #22 on: April 05, 2012, 03:21:37 pm »
Forgot to mention: As seen above I added each resolution two times: once for 50hz and once for 60hz. But "xrandr --verbose" reveals that only one of them is used except for vertical resolutions of 288. I can see both modes for 288. Unfortunately I didn't figure out for the other modes which of the two is not accepted and thus can be removed. I will test that too.
Lomaxx
« Reply #23 on: April 06, 2012, 11:51:55 am »
I sorted out all modelines that did not work. So here's the complete list of modelines that I found through this little test to be working with my setup (GeForce FX 5900XT and a PAL-CRT-TV):
Code: [Select]
ModeLine          "1400x576x50.00" 27.888400 1400 1456 1584 1808 576 578 584 617 -HSync -VSync interlace
ModeLine          "1392x576x50.00" 27.641600 1392 1448 1576 1792 576 578 584 617 -HSync -VSync interlace
ModeLine          "1376x576x50.00" 27.394800 1376 1432 1560 1776 576 578 584 617 -HSync -VSync interlace
ModeLine          "1360x576x50.00" 27.148000 1360 1416 1544 1760 576 578 584 617 -HSync -VSync interlace
ModeLine          "1344x576x50.00" 26.531000 1344 1392 1512 1720 576 578 584 617 -HSync -VSync interlace
ModeLine          "1336x576x50.00" 26.407600 1336 1384 1504 1712 576 578 584 617 -HSync -VSync interlace
ModeLine          "1320x576x50.00" 26.160800 1320 1368 1488 1696 576 578 584 617 -HSync -VSync interlace
ModeLine          "1304x576x50.00" 25.914000 1304 1352 1472 1680 576 578 584 617 -HSync -VSync interlace
ModeLine          "1288x576x50.00" 25.543800 1288 1336 1456 1656 576 578 584 617 -HSync -VSync interlace
ModeLine          "1272x576x50.00" 25.297000 1272 1320 1440 1640 576 578 584 617 -HSync -VSync interlace
ModeLine          "1264x576x50.00" 25.173600 1264 1312 1432 1632 576 578 584 617 -HSync -VSync interlace
ModeLine          "1248x576x50.00" 24.803400 1248 1296 1408 1608 576 578 584 617 -HSync -VSync interlace
ModeLine          "1232x576x50.00" 24.433200 1232 1280 1392 1584 576 578 584 617 -HSync -VSync interlace
ModeLine          "1216x576x50.00" 24.186400 1216 1264 1376 1568 576 578 584 617 -HSync -VSync interlace
ModeLine          "1208x576x50.00" 24.063000 1208 1256 1368 1560 576 578 584 617 -HSync -VSync interlace
ModeLine          "1192x576x50.00" 23.816200 1192 1240 1352 1544 576 578 584 617 -HSync -VSync interlace
ModeLine          "1176x576x50.00" 23.446000 1176 1224 1336 1520 576 578 584 617 -HSync -VSync interlace
ModeLine          "1160x576x50.00" 23.075800 1160 1208 1312 1496 576 578 584 617 -HSync -VSync interlace
ModeLine          "1144x576x50.00" 22.829000 1144 1192 1296 1480 576 578 584 617 -HSync -VSync interlace
ModeLine          "1136x576x50.00" 22.705600 1136 1184 1288 1472 576 578 584 617 -HSync -VSync interlace
ModeLine          "1120x576x50.00" 22.212000 1120 1160 1264 1440 576 578 584 617 -HSync -VSync interlace
ModeLine          "1104x576x50.00" 21.965200 1104 1144 1248 1424 576 578 584 617 -HSync -VSync interlace
ModeLine          "1088x576x50.00" 21.718400 1088 1128 1232 1408 576 578 584 617 -HSync -VSync interlace
ModeLine          "1080x576x50.00" 21.471600 1080 1120 1224 1392 576 578 584 617 -HSync -VSync interlace
ModeLine          "1064x576x50.00" 21.101400 1064 1104 1200 1368 576 578 584 617 -HSync -VSync interlace
ModeLine          "1048x576x50.00" 20.854600 1048 1088 1184 1352 576 578 584 617 -HSync -VSync interlace
ModeLine          "1032x576x50.00" 20.484400 1032 1072 1168 1328 576 578 584 617 -HSync -VSync interlace
ModeLine          "1016x576x50.00" 20.237600 1016 1056 1152 1312 576 578 584 617 -HSync -VSync interlace
ModeLine          "1008x576x50.00" 20.114200 1008 1048 1144 1304 576 578 584 617 -HSync -VSync interlace
ModeLine          "992x576x50.00" 19.867400 992 1032 1128 1288 576 578 584 617 -HSync -VSync interlace
ModeLine          "976x576x50.00" 19.373800 976 1016 1104 1256 576 578 584 617 -HSync -VSync interlace
ModeLine          "960x576x50.00" 19.127000 960 1000 1088 1240 576 578 584 617 -HSync -VSync interlace
ModeLine          "952x576x50.00" 19.003600 952 992 1080 1232 576 578 584 617 -HSync -VSync interlace
ModeLine          "936x576x50.00" 18.756800 936 976 1064 1216 576 578 584 617 -HSync -VSync interlace
ModeLine          "920x576x50.00" 18.386600 920 960 1048 1192 576 578 584 617 -HSync -VSync interlace
ModeLine          "904x576x50.00" 18.139800 904 944 1032 1176 576 578 584 617 -HSync -VSync interlace
ModeLine          "888x576x50.00" 17.646200 888 920 1000 1144 576 578 584 617 -HSync -VSync interlace
ModeLine          "880x576x50.00" 17.399400 880 912 992 1128 576 578 584 617 -HSync -VSync interlace
ModeLine          "864x576x50.00" 17.152600 864 896 976 1112 576 578 584 617 -HSync -VSync interlace
ModeLine          "848x576x50.00" 16.905800 848 880 960 1096 576 578 584 617 -HSync -VSync interlace
ModeLine          "832x576x50.00" 16.659000 832 864 944 1080 576 578 584 617 -HSync -VSync interlace
ModeLine          "824x576x50.00" 16.535600 824 856 936 1072 576 578 584 617 -HSync -VSync interlace
ModeLine          "808x576x50.00" 16.165400 808 840 920 1048 576 578 584 617 -HSync -VSync interlace
ModeLine          "800x576x50.00" 15.918600 800 832 904 1032 576 578 584 617 -HSync -VSync interlace
ModeLine          "800x288x50.97" 16.328000 800 832 912 1040 288 289 292 308 -HSync -VSync
ModeLine          "800x288x50.00" 15.892800 800 832 904 1032 288 289 292 308 -HSync -VSync
ModeLine          "800x280x52.33" 16.328000 800 832 912 1040 280 281 284 300 -HSync -VSync
ModeLine          "800x272x53.77" 16.327999 800 832 912 1040 272 273 276 292 -HSync -VSync
ModeLine          "792x576x50.00" 15.795200 792 824 896 1024 576 578 584 617 -HSync -VSync interlace
ModeLine          "792x288x50.97" 16.202400 792 824 904 1032 288 289 292 308 -HSync -VSync
ModeLine          "792x288x50.00" 15.769600 792 824 896 1024 288 289 292 308 -HSync -VSync
ModeLine          "792x280x52.33" 16.202400 792 824 904 1032 280 281 284 300 -HSync -VSync
ModeLine          "792x272x53.77" 16.202399 792 824 904 1032 272 273 276 292 -HSync -VSync
ModeLine          "784x576x50.00" 15.671800 784 816 888 1016 576 578 584 617 -HSync -VSync interlace
ModeLine          "784x288x50.97" 15.951200 784 816 888 1016 288 289 292 308 -HSync -VSync
ModeLine          "784x288x50.00" 15.646400 784 816 888 1016 288 289 292 308 -HSync -VSync
ModeLine          "784x280x52.33" 15.951200 784 816 888 1016 280 281 284 300 -HSync -VSync
ModeLine          "784x272x53.77" 15.951199 784 816 888 1016 272 273 276 292 -HSync -VSync
ModeLine          "776x576x50.00" 15.548400 776 808 880 1008 576 578 584 617 -HSync -VSync interlace
ModeLine          "776x288x50.97" 15.825600 776 808 880 1008 288 289 292 308 -HSync -VSync
ModeLine          "776x288x50.00" 15.523200 776 808 880 1008 288 289 292 308 -HSync -VSync
ModeLine          "776x280x52.33" 15.825600 776 808 880 1008 280 281 284 300 -HSync -VSync
ModeLine          "776x272x53.77" 15.825599 776 808 880 1008 272 273 276 292 -HSync -VSync
ModeLine          "768x576x50.00" 15.301600 768 800 872 992 576 578 584 617 -HSync -VSync interlace
ModeLine          "768x288x50.97" 15.700000 768 800 872 1000 288 289 292 308 -HSync -VSync
ModeLine          "768x288x50.00" 15.276800 768 800 872 992 288 289 292 308 -HSync -VSync
ModeLine          "768x280x52.33" 15.700000 768 800 872 1000 280 281 284 300 -HSync -VSync
ModeLine          "768x272x53.77" 15.699999 768 800 872 1000 272 273 276 292 -HSync -VSync
ModeLine          "760x576x50.00" 15.178200 760 792 864 984 576 578 584 617 -HSync -VSync interlace
ModeLine          "760x288x50.97" 15.574400 760 792 864 992 288 289 292 308 -HSync -VSync
ModeLine          "760x288x50.00" 15.153600 760 792 864 984 288 289 292 308 -HSync -VSync
ModeLine          "760x280x52.33" 15.574400 760 792 864 992 280 281 284 300 -HSync -VSync
ModeLine          "760x272x53.77" 15.574399 760 792 864 992 272 273 276 292 -HSync -VSync
ModeLine          "752x576x50.00" 15.054800 752 784 856 976 576 578 584 617 -HSync -VSync interlace
ModeLine          "752x288x50.97" 15.323200 752 784 856 976 288 289 292 308 -HSync -VSync
ModeLine          "752x288x50.00" 15.030400 752 784 856 976 288 289 292 308 -HSync -VSync
ModeLine          "752x280x52.33" 15.323200 752 784 856 976 280 281 284 300 -HSync -VSync
ModeLine          "752x272x53.77" 15.323199 752 784 856 976 272 273 276 292 -HSync -VSync
ModeLine          "744x576x50.00" 14.931400 744 776 848 968 576 578 584 617 -HSync -VSync interlace
ModeLine          "744x288x50.97" 15.197600 744 776 848 968 288 289 292 308 -HSync -VSync
ModeLine          "744x288x50.00" 14.907200 744 776 848 968 288 289 292 308 -HSync -VSync
ModeLine          "744x280x52.33" 15.197600 744 776 848 968 280 281 284 300 -HSync -VSync
ModeLine          "744x272x53.77" 15.197599 744 776 848 968 272 273 276 292 -HSync -VSync
ModeLine          "736x576x50.00" 14.808000 736 768 840 960 576 578 584 617 -HSync -VSync interlace
ModeLine          "736x288x50.97" 15.072000 736 768 840 960 288 289 292 308 -HSync -VSync
ModeLine          "736x288x50.00" 14.784000 736 768 840 960 288 289 292 308 -HSync -VSync
ModeLine          "736x280x52.33" 15.072000 736 768 840 960 280 281 284 300 -HSync -VSync
ModeLine          "736x272x53.77" 15.071999 736 768 840 960 272 273 276 292 -HSync -VSync
ModeLine          "728x576x50.00" 14.684600 728 760 832 952 576 578 584 617 -HSync -VSync interlace
ModeLine          "728x288x50.97" 14.946400 728 760 832 952 288 289 292 308 -HSync -VSync
ModeLine          "728x288x50.00" 14.660800 728 760 832 952 288 289 292 308 -HSync -VSync
ModeLine          "728x280x52.33" 14.946400 728 760 832 952 280 281 284 300 -HSync -VSync
ModeLine          "728x272x53.77" 14.946399 728 760 832 952 272 273 276 292 -HSync -VSync
ModeLine          "720x576x50.00" 14.561200 720 752 824 944 576 578 584 617 -HSync -VSync interlace
ModeLine          "720x288x50.97" 14.820800 720 752 824 944 288 289 292 308 -HSync -VSync
ModeLine          "720x288x50.00" 14.537600 720 752 824 944 288 289 292 308 -HSync -VSync
ModeLine          "720x280x52.33" 14.820800 720 752 824 944 280 281 284 300 -HSync -VSync
ModeLine          "720x272x53.77" 14.820799 720 752 824 944 272 273 276 292 -HSync -VSync
ModeLine          "712x576x50.00" 14.191000 712 744 808 920 576 578 584 617 -HSync -VSync interlace
ModeLine          "712x288x50.97" 14.695200 712 744 816 936 288 289 292 308 -HSync -VSync
ModeLine          "712x288x50.00" 14.168000 712 744 808 920 288 289 292 308 -HSync -VSync
ModeLine          "712x280x52.33" 14.695200 712 744 816 936 280 281 284 300 -HSync -VSync
ModeLine          "712x272x53.77" 14.695199 712 744 816 936 272 273 276 292 -HSync -VSync
ModeLine          "704x576x50.00" 14.067600 704 736 800 912 576 578 584 617 -HSync -VSync interlace
ModeLine          "704x288x50.97" 14.569600 704 736 808 928 288 289 292 308 -HSync -VSync
ModeLine          "704x288x50.00" 14.044800 704 736 800 912 288 289 292 308 -HSync -VSync
ModeLine          "704x280x52.33" 14.569600 704 736 808 928 280 281 284 300 -HSync -VSync
ModeLine          "704x272x53.77" 14.569599 704 736 808 928 272 273 276 292 -HSync -VSync
ModeLine          "696x576x50.00" 13.944200 696 728 792 904 576 578 584 617 -HSync -VSync interlace
ModeLine          "696x288x50.97" 14.192800 696 728 792 904 288 289 292 308 -HSync -VSync
ModeLine          "696x288x50.00" 13.921600 696 728 792 904 288 289 292 308 -HSync -VSync
ModeLine          "696x280x52.33" 14.192800 696 728 792 904 280 281 284 300 -HSync -VSync
ModeLine          "696x272x53.77" 14.192799 696 728 792 904 272 273 276 292 -HSync -VSync
ModeLine          "688x576x50.00" 13.820800 688 720 784 896 576 578 584 617 -HSync -VSync interlace
ModeLine          "688x288x50.97" 14.067200 688 720 784 896 288 289 292 308 -HSync -VSync
ModeLine          "688x288x50.00" 13.798400 688 720 784 896 288 289 292 308 -HSync -VSync
ModeLine          "688x280x52.33" 14.067200 688 720 784 896 280 281 284 300 -HSync -VSync
ModeLine          "688x272x53.77" 14.067199 688 720 784 896 272 273 276 292 -HSync -VSync
ModeLine          "680x576x50.00" 13.697400 680 712 776 888 576 578 584 617 -HSync -VSync interlace
ModeLine          "680x288x50.97" 13.941600 680 712 776 888 288 289 292 308 -HSync -VSync
ModeLine          "680x288x50.00" 13.675200 680 712 776 888 288 289 292 308 -HSync -VSync
ModeLine          "680x280x52.33" 13.941600 680 712 776 888 280 281 284 300 -HSync -VSync
ModeLine          "680x272x53.77" 13.941599 680 712 776 888 272 273 276 292 -HSync -VSync
ModeLine          "672x576x50.00" 13.327200 672 696 760 864 576 578 584 617 -HSync -VSync interlace
ModeLine          "672x288x50.97" 13.816000 672 704 768 880 288 289 292 308 -HSync -VSync
ModeLine          "672x288x50.00" 13.305600 672 696 760 864 288 289 292 308 -HSync -VSync
ModeLine          "672x280x52.33" 13.816000 672 704 768 880 280 281 284 300 -HSync -VSync
ModeLine          "672x272x53.77" 13.815999 672 704 768 880 272 273 276 292 -HSync -VSync
ModeLine          "664x576x50.00" 13.203800 664 688 752 856 576 578 584 617 -HSync -VSync interlace
ModeLine          "664x288x50.97" 13.690400 664 696 760 872 288 289 292 308 -HSync -VSync
ModeLine          "664x288x50.00" 13.182400 664 688 752 856 288 289 292 308 -HSync -VSync
ModeLine          "664x280x52.33" 13.690400 664 696 760 872 280 281 284 300 -HSync -VSync
ModeLine          "664x272x53.77" 13.690399 664 696 760 872 272 273 276 292 -HSync -VSync
ModeLine          "656x576x50.00" 13.080400 656 680 744 848 576 578 584 617 -HSync -VSync interlace
ModeLine          "656x288x50.97" 13.313600 656 680 744 848 288 289 292 308 -HSync -VSync
ModeLine          "656x288x50.00" 13.059200 656 680 744 848 288 289 292 308 -HSync -VSync
ModeLine          "656x280x52.33" 13.313600 656 680 744 848 280 281 284 300 -HSync -VSync
ModeLine          "656x272x53.77" 13.313599 656 680 744 848 272 273 276 292 -HSync -VSync
ModeLine          "648x576x50.00" 12.957000 648 672 736 840 576 578 584 617 -HSync -VSync interlace
ModeLine          "648x288x50.97" 13.188000 648 672 736 840 288 289 292 308 -HSync -VSync
ModeLine          "648x288x50.00" 12.936000 648 672 736 840 288 289 292 308 -HSync -VSync
ModeLine          "648x280x52.33" 13.188000 648 672 736 840 280 281 284 300 -HSync -VSync
ModeLine          "648x272x53.77" 13.187999 648 672 736 840 272 273 276 292 -HSync -VSync
ModeLine          "640x576x50.00" 12.833600 640 664 728 832 576 578 584 617 -HSync -VSync interlace
ModeLine          "640x288x50.97" 13.062400 640 664 728 832 288 289 292 308 -HSync -VSync
ModeLine          "640x288x50.00" 12.812800 640 664 728 832 288 289 292 308 -HSync -VSync
ModeLine          "640x280x52.33" 13.062400 640 664 728 832 280 281 284 300 -HSync -VSync
ModeLine          "640x272x53.77" 13.062399 640 664 728 832 272 273 276 292 -HSync -VSync
ModeLine          "632x576x50.00" 12.710200 632 656 720 824 576 578 584 617 -HSync -VSync interlace
ModeLine          "632x288x50.97" 12.936800 632 656 720 824 288 289 292 308 -HSync -VSync
ModeLine          "632x288x50.00" 12.689600 632 656 720 824 288 289 292 308 -HSync -VSync
ModeLine          "632x280x52.33" 12.936800 632 656 720 824 280 281 284 300 -HSync -VSync
ModeLine          "632x272x53.77" 12.936799 632 656 720 824 272 273 276 292 -HSync -VSync
ModeLine          "624x576x50.00" 12.586800 624 648 712 816 576 578 584 617 -HSync -VSync interlace
ModeLine          "624x288x50.97" 12.811200 624 648 712 816 288 289 292 308 -HSync -VSync
ModeLine          "624x288x50.00" 12.443200 624 648 704 808 288 289 292 308 -HSync -VSync
ModeLine          "624x280x52.33" 12.811200 624 648 712 816 280 281 284 300 -HSync -VSync
ModeLine          "624x272x53.77" 12.811199 624 648 712 816 272 273 276 292 -HSync -VSync
ModeLine          "608x576x50.00" 12.093200 608 632 688 784 576 578 584 617 -HSync -VSync interlace
ModeLine          "608x288x50.97" 12.434400 608 632 688 792 288 289 292 308 -HSync -VSync
ModeLine          "608x288x50.00" 12.073600 608 632 688 784 288 289 292 308 -HSync -VSync
ModeLine          "608x280x52.33" 12.434400 608 632 688 792 280 281 284 300 -HSync -VSync
ModeLine          "608x272x53.77" 12.434399 608 632 688 792 272 273 276 292 -HSync -VSync
ModeLine          "600x576x50.00" 11.969800 600 624 680 776 576 578 584 617 -HSync -VSync interlace
ModeLine          "600x288x50.97" 12.183200 600 624 680 776 288 289 292 308 -HSync -VSync
ModeLine          "600x288x50.00" 11.950400 600 624 680 776 288 289 292 308 -HSync -VSync
ModeLine          "600x280x52.33" 12.183200 600 624 680 776 280 281 284 300 -HSync -VSync
ModeLine          "600x272x53.77" 12.183199 600 624 680 776 272 273 276 292 -HSync -VSync
... continues in next post ...
« Last Edit: April 06, 2012, 11:53:57 am by Lomaxx »
Lomaxx
« Reply #24 on: April 06, 2012, 11:52:30 am »
Code: [Select]
ModeLine          "592x576x50.00" 11.846400 592 616 672 768 576 578 584 617 -HSync -VSync interlace
ModeLine          "592x288x50.97" 12.057600 592 616 672 768 288 289 292 308 -HSync -VSync
ModeLine          "592x288x50.00" 11.827200 592 616 672 768 288 289 292 308 -HSync -VSync
ModeLine          "592x280x52.33" 12.057600 592 616 672 768 280 281 284 300 -HSync -VSync
ModeLine          "592x272x53.77" 12.057599 592 616 672 768 272 273 276 292 -HSync -VSync
ModeLine          "584x576x50.00" 11.723000 584 608 664 760 576 578 584 617 -HSync -VSync interlace
ModeLine          "584x288x50.97" 11.932000 584 608 664 760 288 289 292 308 -HSync -VSync
ModeLine          "584x288x50.00" 11.704000 584 608 664 760 288 289 292 308 -HSync -VSync
ModeLine          "584x280x52.33" 11.932000 584 608 664 760 280 281 284 300 -HSync -VSync
ModeLine          "584x272x53.77" 11.931999 584 608 664 760 272 273 276 292 -HSync -VSync
ModeLine          "576x576x50.00" 11.599600 576 600 656 752 576 578 584 617 -HSync -VSync interlace
ModeLine          "576x288x50.97" 11.806400 576 600 656 752 288 289 292 308 -HSync -VSync
ModeLine          "576x288x50.00" 11.580800 576 600 656 752 288 289 292 308 -HSync -VSync
ModeLine          "576x280x52.33" 11.806400 576 600 656 752 280 281 284 300 -HSync -VSync
ModeLine          "576x272x53.77" 11.806399 576 600 656 752 272 273 276 292 -HSync -VSync
ModeLine          "568x576x50.00" 11.476200 568 592 648 744 576 578 584 617 -HSync -VSync interlace
ModeLine          "568x288x50.97" 11.680800 568 592 648 744 288 289 292 308 -HSync -VSync
ModeLine          "568x288x50.00" 11.457600 568 592 648 744 288 289 292 308 -HSync -VSync
ModeLine          "568x280x52.33" 11.680800 568 592 648 744 280 281 284 300 -HSync -VSync
ModeLine          "568x272x53.77" 11.680799 568 592 648 744 272 273 276 292 -HSync -VSync
ModeLine          "560x288x50.97" 11.555200 560 584 640 736 288 289 292 308 -HSync -VSync
ModeLine          "560x288x50.00" 11.211200 560 584 640 728 288 289 292 308 -HSync -VSync
ModeLine          "560x280x52.33" 11.555200 560 584 640 736 280 281 284 300 -HSync -VSync
ModeLine          "560x272x53.77" 11.555199 560 584 640 736 272 273 276 292 -HSync -VSync
ModeLine          "552x576x50.00" 11.106000 552 576 632 720 576 578 584 617 -HSync -VSync interlace
ModeLine          "552x288x50.97" 11.429600 552 576 632 728 288 289 292 308 -HSync -VSync
ModeLine          "552x288x50.00" 11.088000 552 576 632 720 288 289 292 308 -HSync -VSync
ModeLine          "552x280x52.33" 11.429600 552 576 632 728 280 281 284 300 -HSync -VSync
ModeLine          "552x272x53.77" 11.429599 552 576 632 728 272 273 276 292 -HSync -VSync
ModeLine          "544x288x50.97" 11.178400 544 568 624 712 288 289 292 308 -HSync -VSync
ModeLine          "544x288x50.00" 10.964800 544 568 624 712 288 289 292 308 -HSync -VSync
ModeLine          "544x280x52.33" 11.178400 544 568 624 712 280 281 284 300 -HSync -VSync
ModeLine          "544x272x53.77" 11.178399 544 568 624 712 272 273 276 292 -HSync -VSync
ModeLine          "536x576x50.00" 10.859200 536 560 616 704 576 578 584 617 -HSync -VSync interlace
ModeLine          "536x288x50.97" 11.052800 536 560 616 704 288 289 292 308 -HSync -VSync
ModeLine          "536x288x50.00" 10.841600 536 560 616 704 288 289 292 308 -HSync -VSync
ModeLine          "536x280x52.33" 11.052800 536 560 616 704 280 281 284 300 -HSync -VSync
ModeLine          "536x272x53.77" 11.052799 536 560 616 704 272 273 276 292 -HSync -VSync
ModeLine          "528x288x50.97" 10.927200 528 552 608 696 288 289 292 308 -HSync -VSync
ModeLine          "528x288x50.00" 10.595200 528 552 600 688 288 289 292 308 -HSync -VSync
ModeLine          "528x280x52.33" 10.927200 528 552 608 696 280 281 284 300 -HSync -VSync
ModeLine          "528x272x53.77" 10.927199 528 552 608 696 272 273 276 292 -HSync -VSync
ModeLine          "520x576x50.00" 10.489000 520 544 592 680 576 578 584 617 -HSync -VSync interlace
ModeLine          "520x288x50.97" 10.801600 520 544 600 688 288 289 292 308 -HSync -VSync
ModeLine          "520x288x50.00" 10.472000 520 544 592 680 288 289 292 308 -HSync -VSync
ModeLine          "520x280x52.33" 10.801600 520 544 600 688 280 281 284 300 -HSync -VSync
ModeLine          "520x272x53.77" 10.801599 520 544 600 688 272 273 276 292 -HSync -VSync
ModeLine          "512x288x50.97" 10.550400 512 536 584 672 288 289 292 308 -HSync -VSync
ModeLine          "512x288x50.00" 10.225600 512 536 584 664 288 289 292 308 -HSync -VSync
ModeLine          "512x280x52.33" 10.550400 512 536 584 672 280 281 284 300 -HSync -VSync
ModeLine          "512x272x53.77" 10.550399 512 536 584 672 272 273 276 292 -HSync -VSync
ModeLine          "504x576x50.00" 10.118800 504 528 576 656 576 578 584 617 -HSync -VSync interlace
ModeLine          "504x288x50.97" 10.424800 504 528 576 664 288 289 292 308 -HSync -VSync
ModeLine          "504x288x50.00" 10.102400 504 528 576 656 288 289 292 308 -HSync -VSync
ModeLine          "504x280x52.33" 10.424800 504 528 576 664 280 281 284 300 -HSync -VSync
ModeLine          "504x272x53.77" 10.424799 504 528 576 664 272 273 276 292 -HSync -VSync
ModeLine          "496x576x50.00" 9.995400 496 520 568 648 576 578 584 617 -HSync -VSync interlace
ModeLine          "496x288x50.97" 10.173600 496 520 568 648 288 289 292 308 -HSync -VSync
ModeLine          "496x288x50.00" 9.979200 496 520 568 648 288 289 292 308 -HSync -VSync
ModeLine          "496x280x52.33" 10.173600 496 520 568 648 280 281 284 300 -HSync -VSync
ModeLine          "496x272x53.77" 10.173599 496 520 568 648 272 273 276 292 -HSync -VSync
ModeLine          "488x288x50.97" 10.048000 488 512 560 640 288 289 292 308 -HSync -VSync
ModeLine          "488x288x50.00" 9.856000 488 512 560 640 288 289 292 308 -HSync -VSync
ModeLine          "488x280x52.33" 10.048000 488 512 560 640 280 281 284 300 -HSync -VSync
ModeLine          "488x272x53.77" 10.047999 488 512 560 640 272 273 276 292 -HSync -VSync
ModeLine          "480x576x50.00" 9.748600 480 504 552 632 576 578 584 617 -HSync -VSync interlace
ModeLine          "480x288x50.97" 9.922400 480 504 552 632 288 289 292 308 -HSync -VSync
ModeLine          "480x288x50.00" 9.732800 480 504 552 632 288 289 292 308 -HSync -VSync
ModeLine          "480x280x52.33" 9.922400 480 504 552 632 280 281 284 300 -HSync -VSync
ModeLine          "480x272x53.77" 9.922399 480 504 552 632 272 273 276 292 -HSync -VSync
ModeLine          "472x288x50.97" 9.796800 472 496 544 624 288 289 292 308 -HSync -VSync
ModeLine          "472x288x50.00" 9.609600 472 496 544 624 288 289 292 308 -HSync -VSync
ModeLine          "472x280x52.33" 9.796800 472 496 544 624 280 281 284 300 -HSync -VSync
ModeLine          "472x272x53.77" 9.796799 472 496 544 624 272 273 276 292 -HSync -VSync
ModeLine          "464x576x50.00" 9.501800 464 488 536 616 576 578 584 617 -HSync -VSync interlace
ModeLine          "464x288x50.97" 9.671200 464 488 536 616 288 289 292 308 -HSync -VSync
ModeLine          "464x288x50.00" 9.486400 464 488 536 616 288 289 292 308 -HSync -VSync
ModeLine          "464x280x52.33" 9.671200 464 488 536 616 280 281 284 300 -HSync -VSync
ModeLine          "464x272x53.77" 9.671199 464 488 536 616 272 273 276 292 -HSync -VSync
ModeLine          "456x288x50.97" 9.545600 456 480 528 608 288 289 292 308 -HSync -VSync
ModeLine          "456x288x50.00" 9.363200 456 480 528 608 288 289 292 308 -HSync -VSync
ModeLine          "456x280x52.33" 9.545600 456 480 528 608 280 281 284 300 -HSync -VSync
ModeLine          "456x272x53.77" 9.545599 456 480 528 608 272 273 276 292 -HSync -VSync
ModeLine          "448x576x50.00" 8.884800 448 464 504 576 576 578 584 617 -HSync -VSync interlace
ModeLine          "448x288x50.97" 9.420000 448 472 520 600 288 289 292 308 -HSync -VSync
ModeLine          "448x288x50.00" 8.870400 448 464 504 576 288 289 292 308 -HSync -VSync
ModeLine          "448x280x52.33" 9.420000 448 472 520 600 280 281 284 300 -HSync -VSync
ModeLine          "448x272x53.77" 9.419999 448 472 520 600 272 273 276 292 -HSync -VSync
ModeLine          "440x576x50.00" 8.761400 440 456 496 568 576 578 584 617 -HSync -VSync interlace
ModeLine          "440x288x50.97" 9.168800 440 464 512 584 288 289 292 308 -HSync -VSync
ModeLine          "440x288x50.00" 8.747200 440 456 496 568 288 289 292 308 -HSync -VSync
ModeLine          "440x280x52.33" 9.168800 440 464 512 584 280 281 284 300 -HSync -VSync
ModeLine          "440x272x53.77" 9.168799 440 464 512 584 272 273 276 292 -HSync -VSync
ModeLine          "432x288x50.97" 8.792000 432 448 488 560 288 289 292 308 -HSync -VSync
ModeLine          "432x288x50.00" 8.624000 432 448 488 560 288 289 292 308 -HSync -VSync
ModeLine          "432x280x52.33" 8.792000 432 448 488 560 280 281 284 300 -HSync -VSync
ModeLine          "432x272x53.77" 8.791999 432 448 488 560 272 273 276 292 -HSync -VSync
ModeLine          "424x576x50.00" 8.514600 424 440 480 552 576 578 584 617 -HSync -VSync interlace
ModeLine          "424x288x50.97" 8.666400 424 440 480 552 288 289 292 308 -HSync -VSync
ModeLine          "424x288x50.00" 8.500800 424 440 480 552 288 289 292 308 -HSync -VSync
ModeLine          "424x280x52.33" 8.666400 424 440 480 552 280 281 284 300 -HSync -VSync
ModeLine          "424x272x53.77" 8.666399 424 440 480 552 272 273 276 292 -HSync -VSync
ModeLine          "416x288x50.97" 8.540800 416 432 472 544 288 289 292 308 -HSync -VSync
ModeLine          "416x288x50.00" 8.377600 416 432 472 544 288 289 292 308 -HSync -VSync
ModeLine          "416x280x52.33" 8.540800 416 432 472 544 280 281 284 300 -HSync -VSync
ModeLine          "416x272x53.77" 8.540799 416 432 472 544 272 273 276 292 -HSync -VSync
ModeLine          "408x576x50.00" 8.144400 408 424 464 528 576 578 584 617 -HSync -VSync interlace
ModeLine          "408x288x50.97" 8.415200 408 424 464 536 288 289 292 308 -HSync -VSync
ModeLine          "408x288x50.00" 8.131200 408 424 464 528 288 289 292 308 -HSync -VSync
ModeLine          "408x280x52.33" 8.415200 408 424 464 536 280 281 284 300 -HSync -VSync
ModeLine          "408x272x53.77" 8.415199 408 424 464 536 272 273 276 292 -HSync -VSync
ModeLine          "400x288x50.97" 8.164000 400 416 456 520 288 289 292 308 -HSync -VSync
ModeLine          "400x288x50.00" 8.008000 400 416 456 520 288 289 292 308 -HSync -VSync
ModeLine          "400x280x52.33" 8.164000 400 416 456 520 280 281 284 300 -HSync -VSync
ModeLine          "400x272x53.77" 8.163999 400 416 456 520 272 273 276 292 -HSync -VSync
ModeLine          "392x576x50.00" 7.897600 392 408 448 512 576 578 584 617 -HSync -VSync interlace
ModeLine          "392x288x50.97" 8.038400 392 408 448 512 288 289 292 308 -HSync -VSync
ModeLine          "392x288x50.00" 7.884800 392 408 448 512 288 289 292 308 -HSync -VSync
ModeLine          "392x280x52.33" 8.038400 392 408 448 512 280 281 284 300 -HSync -VSync
ModeLine          "392x272x53.77" 8.038399 392 408 448 512 272 273 276 292 -HSync -VSync
ModeLine          "384x288x50.97" 7.912800 384 400 440 504 288 289 292 308 -HSync -VSync
ModeLine          "384x288x50.00" 7.761600 384 400 440 504 288 289 292 308 -HSync -VSync
ModeLine          "384x280x52.33" 7.912800 384 400 440 504 280 281 284 300 -HSync -VSync
ModeLine          "384x272x53.77" 7.912799 384 400 440 504 272 273 276 292 -HSync -VSync
ModeLine          "376x288x50.97" 7.787200 376 392 432 496 288 289 292 308 -HSync -VSync
ModeLine          "376x288x50.00" 7.638400 376 392 432 496 288 289 292 308 -HSync -VSync
ModeLine          "376x280x52.33" 7.787200 376 392 432 496 280 281 284 300 -HSync -VSync
ModeLine          "376x272x53.77" 7.787199 376 392 432 496 272 273 276 292 -HSync -VSync
Lomaxx
« Reply #25 on: April 06, 2012, 11:53:05 am »
In addition here are those I found with "lrmc", which offer no new resolutions to the above, but differ very slightly in the refreshrate:
Code: [Select]
    Modeline "1296x288x50.08"  24.875000  1296 1328 1448 1592  288 293 296 312  -HSync -VSync
    Modeline "1288x288x50.08"  24.750000  1288 1328 1448 1584  288 293 296 312  -HSync -VSync
    Modeline "1280x288x50.08"  24.625000  1280 1320 1432 1576  288 293 296 312  -HSync -VSync
    Modeline "1272x288x50.08"  24.500000  1272 1312 1424 1568  288 293 296 312  -HSync -VSync
    Modeline "1264x288x50.08"  24.250000  1264 1296 1408 1552  288 293 296 312  -HSync -VSync
    Modeline "1256x288x50.08"  24.125000  1256 1288 1400 1544  288 293 296 312  -HSync -VSync
    Modeline "1248x288x50.08"  24.000000  1248 1288 1400 1536  288 293 296 312  -HSync -VSync
    Modeline "1240x288x50.08"  23.875000  1240 1280 1392 1528  288 293 296 312  -HSync -VSync
    Modeline "1232x288x50.08"  23.750000  1232 1272 1384 1520  288 293 296 312  -HSync -VSync
    Modeline "1224x288x50.08"  23.500000  1224 1256 1368 1504  288 293 296 312  -HSync -VSync
    Modeline "1216x288x50.08"  23.375000  1216 1248 1360 1496  288 293 296 312  -HSync -VSync
    Modeline "1208x288x50.08"  23.250000  1208 1240 1352 1488  288 293 296 312  -HSync -VSync
    Modeline "1200x288x50.08"  23.125000  1200 1240 1352 1480  288 293 296 312  -HSync -VSync
    Modeline "1192x288x50.08"  22.875000  1192 1224 1328 1464  288 293 296 312  -HSync -VSync
    Modeline "1184x288x50.08"  22.750000  1184 1216 1320 1456  288 293 296 312  -HSync -VSync
    Modeline "1176x288x50.08"  22.625000  1176 1208 1312 1448  288 293 296 312  -HSync -VSync
    Modeline "1168x288x50.08"  22.500000  1168 1200 1304 1440  288 293 296 312  -HSync -VSync
    Modeline "1160x288x50.08"  22.250000  1160 1192 1296 1424  288 293 296 312  -HSync -VSync
    Modeline "1152x288x50.08"  22.125000  1152 1184 1288 1416  288 293 296 312  -HSync -VSync
    Modeline "1144x288x50.08"  22.000000  1144 1176 1280 1408  288 293 296 312  -HSync -VSync
    Modeline "1136x288x50.08"  21.875000  1136 1168 1272 1400  288 293 296 312  -HSync -VSync
    Modeline "1128x288x50.08"  21.750000  1128 1160 1264 1392  288 293 296 312  -HSync -VSync
    Modeline "1120x288x50.08"  21.500000  1120 1152 1256 1376  288 293 296 312  -HSync -VSync
    Modeline "1112x288x50.08"  21.375000  1112 1144 1248 1368  288 293 296 312  -HSync -VSync
    Modeline "1104x288x50.08"  21.250000  1104 1136 1232 1360  288 293 296 312  -HSync -VSync
    Modeline "1096x288x50.08"  21.125000  1096 1128 1224 1352  288 293 296 312  -HSync -VSync
    Modeline "1088x288x50.08"  20.875000  1088 1120 1216 1336  288 293 296 312  -HSync -VSync
    Modeline "1080x288x50.08"  20.750000  1080 1112 1208 1328  288 293 296 312  -HSync -VSync
    Modeline "1072x288x50.08"  20.625000  1072 1104 1200 1320  288 293 296 312  -HSync -VSync
    Modeline "1064x288x50.08"  20.500000  1064 1096 1192 1312  288 293 296 312  -HSync -VSync
    Modeline "1056x288x50.08"  20.250000  1056 1080 1176 1296  288 293 296 312  -HSync -VSync
    Modeline "1048x288x50.08"  20.125000  1048 1080 1176 1288  288 293 296 312  -HSync -VSync
    Modeline "1040x288x50.08"  20.000000  1040 1072 1168 1280  288 293 296 312  -HSync -VSync
    Modeline "1032x288x50.08"  19.875000  1032 1064 1160 1272  288 293 296 312  -HSync -VSync
    Modeline "1024x288x50.08"  19.750000  1024 1056 1152 1264  288 293 296 312  -HSync -VSync
    Modeline "1016x288x50.08"  19.500000  1016 1040 1128 1248  288 293 296 312  -HSync -VSync
    Modeline "1008x288x50.08"  19.375000  1008 1040 1128 1240  288 293 296 312  -HSync -VSync
    Modeline "1000x288x50.08"  19.250000  1000 1032 1120 1232  288 293 296 312  -HSync -VSync
    Modeline "992x288x50.08"  19.125000  992 1024 1112 1224  288 293 296 312  -HSync -VSync
    Modeline "984x288x50.08"  18.875000  984 1008 1096 1208  288 293 296 312  -HSync -VSync
    Modeline "976x288x50.08"  18.750000  976 1000 1088 1200  288 293 296 312  -HSync -VSync
    Modeline "968x288x50.08"  18.625000  968 1000 1088 1192  288 293 296 312  -HSync -VSync
    Modeline "960x288x50.08"  18.500000  960 992 1080 1184  288 293 296 312  -HSync -VSync
    Modeline "952x288x50.08"  18.250000  952 976 1064 1168  288 293 296 312  -HSync -VSync
    Modeline "944x288x50.08"  18.125000  944 968 1056 1160  288 293 296 312  -HSync -VSync
    Modeline "936x288x50.08"  18.000000  936 960 1048 1152  288 293 296 312  -HSync -VSync
    Modeline "928x288x50.08"  17.875000  928 960 1048 1144  288 293 296 312  -HSync -VSync
    Modeline "920x288x50.08"  17.750000  920 952 1032 1136  288 293 296 312  -HSync -VSync
    Modeline "912x288x50.08"  17.500000  912 936 1016 1120  288 293 296 312  -HSync -VSync
    Modeline "904x288x50.08"  17.375000  904 928 1008 1112  288 293 296 312  -HSync -VSync
    Modeline "896x288x50.08"  17.250000  896 920 1000 1104  288 293 296 312  -HSync -VSync
    Modeline "888x288x50.08"  17.125000  888 920 1000 1096  288 293 296 312  -HSync -VSync
    Modeline "880x288x50.08"  16.875000  880 904 984 1080  288 293 296 312  -HSync -VSync
    Modeline "872x288x50.08"  16.750000  872 896 976 1072  288 293 296 312  -HSync -VSync
    Modeline "864x288x50.08"  16.625000  864 888 968 1064  288 293 296 312  -HSync -VSync
    Modeline "856x288x50.08"  16.500000  856 880 960 1056  288 293 296 312  -HSync -VSync
    Modeline "848x288x50.08"  16.250000  848 872 952 1040  288 293 296 312  -HSync -VSync
    Modeline "840x288x50.08"  16.125000  840 864 936 1032  288 293 296 312  -HSync -VSync
    Modeline "832x288x50.08"  16.000000  832 856 928 1024  288 293 296 312  -HSync -VSync
    Modeline "824x288x50.08"  15.875000  824 848 920 1016  288 293 296 312  -HSync -VSync
    Modeline "816x288x50.08"  15.750000  816 840 912 1008  288 293 296 312  -HSync -VSync
    Modeline "808x288x50.08"  15.500000  808 832 904 992  288 293 296 312  -HSync -VSync
    Modeline "800x288x50.08"  15.375000  800 824 896 984  288 293 296 312  -HSync -VSync
    Modeline "792x288x50.08"  15.250000  792 816 888 976  288 293 296 312  -HSync -VSync
    Modeline "784x288x50.08"  15.125000  784 808 880 968  288 293 296 312  -HSync -VSync
    Modeline "776x288x50.08"  14.875000  776 792 864 952  288 293 296 312  -HSync -VSync
    Modeline "768x288x50.08"  14.750000  768 792 864 944  288 293 296 312  -HSync -VSync
    Modeline "760x288x50.08"  14.625000  760 784 856 936  288 293 296 312  -HSync -VSync
    Modeline "752x288x50.08"  14.500000  752 776 848 928  288 293 296 312  -HSync -VSync
    Modeline "744x288x50.08"  14.250000  744 760 824 912  288 293 296 312  -HSync -VSync
    Modeline "736x288x50.08"  14.125000  736 752 816 904  288 293 296 312  -HSync -VSync
    Modeline "728x288x50.08"  14.000000  728 752 816 896  288 293 296 312  -HSync -VSync
    Modeline "720x288x50.08"  13.875000  720 744 808 888  288 293 296 312  -HSync -VSync
    Modeline "712x288x50.08"  13.750000  712 736 800 880  288 293 296 312  -HSync -VSync
    Modeline "704x288x50.08"  13.500000  704 720 784 864  288 293 296 312  -HSync -VSync
    Modeline "696x288x50.08"  13.375000  696 712 776 856  288 293 296 312  -HSync -VSync
    Modeline "688x288x50.08"  13.250000  688 712 776 848  288 293 296 312  -HSync -VSync
    Modeline "680x288x50.08"  13.125000  680 704 768 840  288 293 296 312  -HSync -VSync
    Modeline "672x288x50.08"  12.875000  672 688 752 824  288 293 296 312  -HSync -VSync
    Modeline "664x288x50.08"  12.750000  664 680 736 816  288 293 296 312  -HSync -VSync
    Modeline "656x288x50.08"  12.625000  656 672 728 808  288 293 296 312  -HSync -VSync
    Modeline "648x288x50.08"  12.500000  648 672 728 800  288 293 296 312  -HSync -VSync
    Modeline "640x288x50.08"  12.250000  640 656 712 784  288 293 296 312  -HSync -VSync
    Modeline "632x288x50.08"  12.125000  632 648 704 776  288 293 296 312  -HSync -VSync
    Modeline "624x288x50.08"  12.000000  624 640 696 768  288 293 296 312  -HSync -VSync
    Modeline "616x288x50.08"  11.875000  616 632 688 760  288 293 296 312  -HSync -VSync
    Modeline "608x288x50.08"  11.750000  608 632 688 752  288 293 296 312  -HSync -VSync
    Modeline "600x288x50.08"  11.500000  600 616 672 736  288 293 296 312  -HSync -VSync
    Modeline "592x288x50.08"  11.375000  592 608 664 728  288 293 296 312  -HSync -VSync
    Modeline "584x288x50.08"  11.250000  584 600 656 720  288 293 296 312  -HSync -VSync
    Modeline "576x288x50.08"  11.125000  576 592 648 712  288 293 296 312  -HSync -VSync
    Modeline "568x288x50.08"  10.875000  568 584 632 696  288 293 296 312  -HSync -VSync
    Modeline "560x288x50.08"  10.750000  560 576 624 688  288 293 296 312  -HSync -VSync
    Modeline "552x288x50.08"  10.625000  552 568 616 680  288 293 296 312  -HSync -VSync
    Modeline "544x288x50.08"  10.500000  544 560 608 672  288 293 296 312  -HSync -VSync
    Modeline "536x288x50.08"  10.250000  536 552 600 656  288 293 296 312  -HSync -VSync
    Modeline "528x288x50.08"  10.125000  528 544 592 648  288 293 296 312  -HSync -VSync
    Modeline "520x288x50.08"  10.000000  520 536 584 640  288 293 296 312  -HSync -VSync
    Modeline "512x288x50.08"  9.875000  512 528 576 632  288 293 296 312  -HSync -VSync
    Modeline "504x288x50.08"  9.750000  504 520 568 624  288 293 296 312  -HSync -VSync
    Modeline "496x288x50.08"  9.500000  496 512 560 608  288 293 296 312  -HSync -VSync
    Modeline "488x288x50.08"  9.375000  488 504 552 600  288 293 296 312  -HSync -VSync
    Modeline "480x288x50.08"  9.250000  480 496 536 592  288 293 296 312  -HSync -VSync
    Modeline "472x288x50.08"  9.125000  472 488 528 584  288 293 296 312  -HSync -VSync
    Modeline "464x288x50.08"  8.875000  464 472 512 568  288 293 296 312  -HSync -VSync
    Modeline "456x288x50.08"  8.750000  456 472 512 560  288 293 296 312  -HSync -VSync
    Modeline "448x288x50.08"  8.625000  448 464 504 552  288 293 296 312  -HSync -VSync
    Modeline "440x288x50.08"  8.500000  440 456 496 544  288 293 296 312  -HSync -VSync
    Modeline "432x288x50.08"  8.250000  432 440 480 528  288 293 296 312  -HSync -VSync
    Modeline "424x288x50.08"  8.125000  424 432 472 520  288 293 296 312  -HSync -VSync
    Modeline "416x288x50.08"  8.000000  416 432 472 512  288 293 296 312  -HSync -VSync
I was hoping to find more varation for the vertical resolution than  just 576,288,280 and 272, but it seems that there are none. Unless someone tells me the opposite and that there should be more, I will stop testing for now.
Lomaxx
« Reply #26 on: April 19, 2012, 03:05:06 pm »
A little update about the resolutions with a height of 280 and 272 (to be found in the long list of modeline two posts above):
 I noticed that my TV simply leaves out the last 8 (when using 280) or 16 lines (272) compared to the normal 288 lines. So in the end you simple are left with some black space at the bottom. You can NOT use that somehow for a little vertical scaling of the picture like I was hoping.
 So most of you can leave these modes out as well. I only found a 272-mode useful once when using some pseudo-fullscreen-work-around for the vice-emulator in order to hide the statusbar at the bottom of the vice-window.
 In addition 280- and 272-modes confuse my TV in such a way that the OSD-menu does not show up anymore when using them.
I guess I was trying to bend the laws of CRT-TV-physics, which can't work.  ;)
« Last Edit: April 19, 2012, 03:06:44 pm by Lomaxx »
Paradroid
  • Last login:December 05, 2025, 10:28:19 pm
    • SCART Hunter
« Reply #27 on: April 19, 2012, 10:08:13 pm »
Hmm...
If I were in your part of the world, I'd be grabbing a Grundig/Blaupunkt/Siemens with a CUC 5xxx or 6xxx series chassis. From what I understand, they're reasonably to easy to come by in Germany. After searching high and low in Australia, I now have a few of these and (using an ATI under Windows XP) the compatibility and picture quality is very good. These TVs have analogue controls (quick to adjust overscan) and have beautiful arcade-like pictures with no digital artifacts. I recently acquired a Grundig CUC 6330 chassis and the picture is possibly the best I've seen (analogue chassis and black matrix tube). Much better than the average arcade monitor IMHO.
Anyway, it's just a thought. You seem pretty keen to get on top of all this and in my experience having the right SCART TV to start with makes the task a whole lot easier. :)
My MAME/SCART/CRT blog: SCART Hunter
Lomaxx
« Reply #28 on: April 20, 2012, 04:16:45 am »
Ah, well ... at the moment I'm just using the old, unused TV left in the household. Right now I'm not heading for the best equipment, but for getting the most out of the hardware I got. Still i appreciate your info. Maybe someday there will be an opportunity to get one of these chassis. Sounds interesting.
 So far I am already please with the picture I got - as long as I can stick to progressive modes. I got scanlines. I got nice colours. I got a big screen. I even don't care that much about some black borders as long as i can get the correct 4:3-ratio done.
Calamity
  • Moderator
« Reply #29 on: April 20, 2012, 04:32:20 am »
I guess I was trying to bend the laws of CRT-TV-physics, which can't work.  Wink
Not really, CRT-TVs are generally way more flexible than what your model seems to be. Was it a Nokia? That behaviour doesn't respond to the modeline math logic but probably to some over-simplified processing chip built in that chasis. The problem is that being forced to use 288-lines (or whatever above 256) you can't get any of the 60 Hz modes which are required for emulation. I agree Paradroid, if you ever test this on a more flexible TV you'll know what we mean.
Lomaxx
« Reply #30 on: April 20, 2012, 10:06:50 am »
Maybe I will test it with my old Commodore Amiga 1081-monitor some time. That one has got a scart-socket and potis for adjusting, though it's not that large. On the other hand I might not, as I wouldn't like to damage it somehow although the chance is low.
« Last Edit: April 20, 2012, 10:13:04 am by Lomaxx »
Paradroid
    • SCART Hunter
« Reply #31 on: April 20, 2012, 06:21:13 pm »
Nice. A friend of mine has one of those SCART equipped Commodore monitors. Kind of rare in our part of the world.
Really, I wouldn't be too scared to test it out. It is designed for this kind of thing, you know. ;)
Check out the Plogue Chiptunes blog. David has been using a Commodore monitor for his arcade PCB hacking/testing.
