Author Topic: EZ-Off LED Button Wiring  (Read 4770 times)
EvilGreenDevil
  • Last login:June 10, 2016, 01:50:45 pm
    • press start to continue
« on: March 24, 2012, 04:55:26 pm »
hey all, just got an order in from Paradise Arcade and they were nice enough to include a handful of their EZ Off pieces in the box for a delayed shipment. How are we suppose to use these? The description on their website doesn't answer it for me unless I'm missing something.
Here is how I have it wired.
ideally, I would like to have the push button always on and go off only for the short time that it is pressed. The buttons I have are 12v and powered by my psu.
Thoughts?
Xbox360 GT - EvilGreenDevil | twitter - dcmyers
My First Bartop Build
EvilGreenDevil
Re: EZ-Off LED Button Wiring
« Reply #1 on: March 27, 2012, 10:19:50 pm »
anyone? :-)
« Reply #2 on: March 27, 2012, 11:02:37 pm »
Take the ground off the loose end (what you have labelled as LED ground). That should work.
« Last Edit: March 27, 2012, 11:05:08 pm by Nephasth »
daillest319
  • Last login:April 04, 2012, 08:48:41 am
« Reply #3 on: March 30, 2012, 02:48:38 pm »
@EvilGreenDevil
I had the same issue trying to figure out how to use them as well.
I'm just curious how do you light the LED Pushbuttons? im very new at this stuff FYI
what are you using to light them and what wires do i need and how do i wire them?
EvilGreenDevil
« Reply #4 on: March 30, 2012, 10:48:24 pm »
@EvilGreenDevil
First you need to figure out if the lights you got were 5v or 12v. Then you power them accordingly. The easiest for me was using my computers power supply. I took an extra molex connector and spliced  the 12v line (yellow) and the black one next to it (ground) the other two wires on the molex connector are the other ground (black) and 5v line (red).
Connect the hot line to one of the led terminals and the ground to the other.
