Author Topic: Think my game broke ....  (Read 1122 times)
Mac Green
  • Last login:June 08, 2017, 12:03:59 am
« on: March 23, 2012, 10:46:33 pm »
So heres the story im standing there playing my aero fighters cab i hit the fire button and zip everything goes black no sound except for a hum from the monitor the only light that comes on is the marquee light not even the coin door lights......... :cry: anyone have any tips or suggestions on how to fix it?
Re: Think my game broke ....
« Reply #1 on: March 23, 2012, 11:07:45 pm »
Sounds like a power supply...
Franco B
« Reply #2 on: March 24, 2012, 04:23:33 am »
+1 for the power supply.
The monitor and marquee light are normally powered separately (most likely 110vAC in your case) and it sounds like those are both are working.
Check the 5/12vDC output from your PSU. If you get nothing then check the AC input to your PSU. If you get no input then it may just be a fuse.
Mac Green
« Reply #3 on: March 24, 2012, 07:42:22 am »
ok ill check that today thanks
Mac Green
« Reply #4 on: March 24, 2012, 07:45:45 am »
also smelled like smoke if that helps
Mac Green
« Reply #5 on: March 24, 2012, 04:51:53 pm »
Yup its the PSU it started smoking when i turned it on
