Author Topic: 2.25" Trackball - Happ vs. Ultimarc?  (Read 1659 times)
TVisitor
  • Newbie
  • Last login:September 27, 2003, 12:03:13 pm
« on: September 27, 2003, 12:11:42 pm »
Hi all.  I'm relatively new to the game and was doing some research to build a control panel.  I really like Ultimarc's interfaces.  However, in searching for a trackball, I see that Ultimarc has a trackball (with ball) for $26.  Happ has a trackball (with ball) for $88.  The Happ one says it's an Atari Trackball.  The Ultimarc doesn't say.
Anyone have experience with either - Just wondering if something about Happ's Higher price (... The fact that it's an Atari trackball?) makes it worth purchasing over the vastly lower cost Ultimarc one?
Thanks.
Tiger-Heli
    • Tiger-Heli
Re:2.25" Trackball - Happ vs. Ultimarc?
« Reply #1 on: September 27, 2003, 02:21:46 pm »
Thanks.
The ultimarc is the same as the www.wicothesource.com one, which is actually made by SUZO.
Been asked a dozen times before.  Search the FAQ's or the threads.  UrebelScum usually has the goods on which one does what.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: September 28, 2003, 04:54:02 am »
(I have a 3" happs and a 2 1/4" wico TBs.  According to theRealBobRoberts, the happs 3" and 2 1/4" are basically the same thing except at a different size.  I do not have a happs 2 1/4".  With this in mind...)
I think the happs TB will be a slightly higher quality TB, but no where near 3x better than the wico/suzo/ultimarc TB as the prices indicate.
The happs has three full size rollers w/ 2 bearings each; the wico has two rollers w/ 2 bearings each, but for the third the ball rests directly on a single bearing w/ spring support.  From this and the fact my wico doesn't roll for very long, I'm pretty sure the happs 2 1/4" will free spin a lot longer than the wico.
The ball in my wico fells a little "looser" than the one in my happs, but at least some of that has to be because of the heavier 3" ball in my happs.  [shrug]
The wico has a smaller footprint according to happs dimentions, but OTOH is a little deeper.  Both have approx the same amount of ball showing above the panel top.
I like my wico 2 1/4" TB, except I find the 3 inchers much more my size.
IMO, do not get the way too expensive 2 1/4 happs.  Either get a 2 1/4" wico/suzo/ultimarc, or a 3" TB (happs, betson, or wico are all fine), especially since the betson and wico 3 inchers are less than the happs 2 1/4", and the happs 3" sometimes is on sale close to the betson prices.
Robin
Knowledge is Power
