Author Topic: mounting a u-trak trackball  (Read 1923 times)
mytymaus007
« on: March 16, 2012, 11:55:53 pm »
Has anyone insstalled one of these ultimarck trackballs. i was wondering is it possible to mount it horizontally instead of how they are showing it in the picturei only have 5 inches of mountable space and the track ball size according to picture is 126.5 millimeters = 4.98031496 inches so i should  make it.
BobA
  • What Me Worry?
Re: mounting a u-trak trackball
« Reply #1 on: March 17, 2012, 12:35:16 am »
I don't know the U trak specifically but other trackballs are sensitive to the mounting position because of the 3 rods they run on you can change 90 degrees because you can change the x and y but it does not always roll well.  I would think if a certain position was up then the x and y depend on it so if you change the orientation by 45 degrees all your axis will be wrong.
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
« Reply #2 on: March 17, 2012, 07:44:39 am »
I agree with Boba, I don't think that you can rotate it 45 but 90 you can. I had to do some creative carving with my router to make The U-trak fit in the small panel on my Pacman cab.
mytymaus007
« Reply #3 on: March 17, 2012, 08:10:33 am »
makes sense! ugg
Blanka
« Reply #4 on: March 17, 2012, 10:08:44 am »
Should not be that difficult to write software that allows any direction....
mytymaus007
« Reply #5 on: March 18, 2012, 12:30:40 am »
dude that would be sick if i could mount this horizontal and use it the right way letme know if yu can d this!
ahofle
    • Arcade Ambience Project
« Reply #6 on: March 18, 2012, 01:32:26 am »
I had to pass on the U-Trak because it was just slightly too big for me too.  I really wish they had a smaller 2.5" version.
