Author Topic: Rotate DMD in visual Pinball full screen tables. (Solved)  (Read 8557 times)
BobA
  • What Me Worry?
« on: March 12, 2012, 08:35:55 pm »
I have some full screen tables where DMD is 90 degrees off.  Is there a good description how to rotate the DMD display to match the table in Visual Pinball.   I have tried adding to the script and then going to the registry to set ROR=1 but it does not seem to work.
Seems to be a combination of getting both the script change right and then changing the autorol or autoror in the registry.  VpinMame has an entry for each rom and this is where the dmd orientation can be changed for the rom you are using.  It must be the exact rom being used as there are sometimes many variations of the rom. I think that there is also interation with the types of tables and the roms so if the same rom is used for the full screen table and a desktop table it will change the orientation but then the other screen maybe wrong so it has to be worked out on each installation.  Use only the proper type of table for your setup.  :D
« Last Edit: March 14, 2012, 12:37:54 pm by BobA »
