Author Topic: Hacking a Happs Trackball.  (Read 1450 times)
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
« on: September 26, 2003, 12:40:05 pm »
Once upon a time online, I saw instructions on how to tear a mouse apart and hook it's circuit card into a happs mouse. (This would eliminate the need for an OPTI-pac...
Does anyone have the instructions or experience with doing this?
zero-one
  • Last login:December 17, 2003, 10:30:04 pm
  • Still learning...
Re:Hacking a Happs Trackball.
« Reply #1 on: September 26, 2003, 01:04:07 pm »
Hi,
I've just did one. It worked first time. I used a very old IBM PS/2 Mouse that I had laying around for the past 12 years or so.
I want to do one with a USB mouse but I haven't found a suitable one yet. I've taken apart many mice and found that Logitech mice use very fine encoder wheels and sometimes the receivers have 4 pins instead of the normal and desirable 3 pins. Therefore, I would stay away from Logitech mice for this hack.
Here are a few links to get you started:
http://www.members.shaw.ca/bakaye/tballhack.htm
http://www.mameworld.net/massive/How-to/Trackball_Hack/trackball_hack.html
http://www.mamecab.com/Howtos/How%20to%20Hack%20Happs.htm
http://www.ionpool.net/arcade/tech/Mouse_to_Trackball_Instructions.pdf
Good luck.
zero-one
  • Still learning...
« Reply #2 on: September 26, 2003, 01:09:24 pm »
Zeitgeist
  • Last login:June 05, 2013, 05:57:51 pm
« Reply #3 on: September 27, 2003, 08:33:06 am »
Here is mine:
http://www.arcadecontrols.com/files/Miscellaneous/Mouse_to_Trackball_Instructions.pdf
Drop me an IM if you have any questions.
Enjoy
Z
Edit:
Didn't realize this when I saw Zero-One's  previous response but apparantly you already had a link to my tutorial since unbeknownst to me, it has been mirrored at this fellow's site as well ;):
I actually used all of the excellent tutorials & websites listed so far in this post, including Oscar's & some others not yet mentioned in order to write the .PDF linked above.
Z
« Last Edit: September 27, 2003, 09:25:01 am by Zeitgeist »
There is a theory which states that if ever anyone discovers what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: September 27, 2003, 08:41:45 am »
Robin
Knowledge is Power
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #5 on: September 27, 2003, 09:23:41 am »
I hacked my Happ/GT trackball a couple of weeks ago and have been having a small problem with it:
I wired it to an old PS/2 wheelmouse I had lying around and it works fine for Mame, but when using it to move around in Windows it seems to think I'm trying to use the mouse-wheel sometimes and selects windows that the mouse pointer is just passing by.
At first it was scrolling up+down randomly in a window, I installed TweakUI and disabled the wheel-scroll function and this problem cleared itself up.
But I'm still having the strange 'selecting windows I don't want to be in' problem. I removed the mouse-wheel's receiver and it's still doing it. ???
Zeitgeist
« Reply #6 on: September 27, 2003, 09:33:21 am »
JoyMonkey,
I haven't attempted a hack on a wheel mouse yet, they were all three button PS2s & USBs so I'm not familiar with what's happening in your case.
Have you gone over all of your connections; it's a shot in the dark but perhaps two of your traces have been inadvertantly connected.
One thing I do when soldering connections that are close to one another is run an exacto knife between the traces to make sure that the solder from one connection I made didn't bleed over to the next.
If so the razor will cut it.
I dunno???
You could always try to desolder the main lead for the wheel I suppose...
Goodluck
Z
zero-one
  • Still learning...
« Reply #7 on: September 27, 2003, 09:35:18 am »
Joymonkey,
Looks like you've done a good job at troubleshooting so far. The only thing I can suggest is to check that the wheel (3rd) button is not pressed somehow.
Zeitgeist
« Reply #8 on: September 27, 2003, 02:45:00 pm »
Zero-One,
The USB mouse that I have used on several hacked interfaces are the Kensington VaulMouse 3 button type.
Z
