Author Topic: Multi Ms.Pacman/Galaga Reunion cab!!!!!!  (Read 4583 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: September 26, 2003, 03:53:00 am »
http://www.bigjimsarcade.com/mspacmangalagareunioncab.html
this is a sad story. i dunno what happened to it but it was out back next to the dumpster of a local distributor in my area. It was totally gutted and I had to fit it with all of the mspac stuff i had but it looks good. I need to add new t molding and touch up the paint on the mspac side but a custom cp and cpo based around the reunion theme are on there way.   Thanks to a little help from Chutltutktltuke ;)  I need to learn photoshop one of these days  >:(
anyone have any comments or questions?
thx again d88
paigeoliver
  • Awesome face!
Re:Multi Ms.Pacman/Galaga Reunion cab!!!!!!
« Reply #1 on: September 26, 2003, 06:44:44 am »
You can probably just order a reunion control panel overlay from Namco. It is a current game and I imagine they still stock the parts. I wouldn't bother with a reunion marquee though, the quality on those are terrible (they really truly look like an inkjet print).
pathdoc2
  • Last login:January 11, 2006, 08:49:53 pm
  • Your friendly pathologist
« Reply #2 on: September 26, 2003, 09:08:41 am »
I'm glad to see you saved that one from the junk yard.  Good luck with you project, looks pretty darn good.
mkdevo
  • Last login:February 09, 2024, 09:31:59 pm
« Reply #3 on: September 26, 2003, 09:20:46 am »
nice work!
what did you use to restore that top corner? could you go into detail? bondo? putty? i'm in a similar situation, and yours looks like it came out pretty good. thanks!
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #4 on: September 27, 2003, 12:49:04 pm »
I'm pretty clueless about this reunion cab, where is the fire button for Galaga?
paigeoliver
  • Awesome face!
« Reply #5 on: September 27, 2003, 07:46:17 pm »
He has a reunion cabinet with an original Ms. Pac-Man control panel, thus no fire button.
A reunion machine control panel has it to the right of the joystick.
delta88
« Reply #6 on: September 29, 2003, 01:43:04 am »
the corners were repaired by sanding down the break smooth and cutting a peice of new wood to fit in the broken spot. then cut the t-molding slit and thats it.. now I need to take the color codes and get some paint to finish the mspac side.
yeah its all mspac stuff now but I would like to go with the reunion theme.
