Author Topic: Measurement and Design  (Read 1857 times)
dprush83
  • Last login:January 13, 2020, 12:47:54 pm
« on: March 03, 2012, 11:18:36 pm »
I am creating my control panel now and had a couple of questions. I am having trouble with joystick to button placement. I'm handy enough in photoshop to drop images around and make art, but I don't know how to map out where to put my buttons/joystick. I am going to use a standard joystick with 6 button layout with 3 admin buttons on the panel as well.
On another note, I intend to use a Mag-Stik Plus. It should be here later next week, but in the meantime I'm not sure how I should prepare the cut on the panel. Do you usually just drill press the hole and attach from below, or does clearance need to be made for the stick?
yaksplat
    • Random Projects
Re: Measurement and Design
« Reply #1 on: March 03, 2012, 11:38:02 pm »
A 1-1/8" hole in 3/4" board is enough clearance if bottom mounted.
http://yaksplat.wordpress.com
dprush83
« Reply #2 on: March 03, 2012, 11:54:50 pm »
It is a 3/4" board, thank you! Would you happen to know the thickness of the stick's base? I'm mounting it in a cab that originally didn't have anything more than buttons so I'm not sure if I'll have any issues fitting the stick in the CP box.
yaksplat
    • Random Projects
dprush83
« Reply #4 on: March 04, 2012, 12:46:19 am »
Thank you! I couldn't find those on the site, that helps a ton. In regards to the button layout, does anybody know if there are any "templates" that can be dropped into photoshop to scale? I have my dimensions of the entire control panel in PS, but don't have the button confit accurately to scale.
yaksplat
    • Random Projects
« Reply #5 on: March 04, 2012, 01:10:56 am »
here's a file of a pdf, dwg, dxf, dwf.  One of them should work in PS or AI
JohnEDollar
  • Last login:December 29, 2015, 06:36:55 pm
  • Keep it Smooth...
« Reply #6 on: March 04, 2012, 02:41:01 pm »
For button layout templates, this site is a good start:  http://www.slagcoin.com/joystick/layout.html
(Templates can be converted to PhotoShop format.)
- John
