Author Topic: 2-in-1 Switcher. Please Help!  (Read 3656 times)
DirkW
  • Last login:February 20, 2013, 02:09:30 pm
« on: March 01, 2012, 02:11:27 pm »
I bought the 2-in-1 Jamma switcher from here:
http://www.jammaboards.com/store/2-in-1-multijamma-switcher-pcb-gbs-8118-gbs-8118.html
After it was already shipped, I reread the description and it is telling me that it is only capable of 4 shooter buttons.  I want to hook up both Killer Instinct 1 and 2 into a KI2 cabinet using this switcher.  Does someone know the process and the other parts I would need?  I would be greatly appreciate for any help you can give!
Re: 2-in-1 Switcher. Please Help!
« Reply #1 on: March 01, 2012, 02:37:44 pm »
You'll have to split your kick harness to go to each board (KI and KI2), and install the appropriate diodes in the kick harness. Search for "multi kick harness"...
DirkW
« Reply #2 on: March 01, 2012, 03:13:28 pm »
I had seen something about these being directly wired to each of the board's extra buttons.  Would this work?
http://www.jammaboards.com/store/microswitch-signal-3-way-splitter-3-waysplitter.html
Tried reading about the kick harnesses.  I need the idiot's guide.
« Reply #3 on: March 01, 2012, 03:20:13 pm »
Um... no. You'll need another kick harness connector that actually plugs into the board, it's a JST part I believe. There is no idiot's guide for this, do some thorough digging and you'll find what you're looking for. I've never done it, but I've come across examples a time or two in my research...
MK3FAN
« Reply #4 on: March 21, 2012, 12:27:18 am »
The idiot's guide? Here it is....
