Author Topic: Side covering...  (Read 1010 times)
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
Side covering...
« on: September 25, 2003, 10:40:35 am »
I'll give you a quick Low-Down Of what I've got going on first...
I'm restoring a Street FighterII Champion Edition (giant cabinet!) & converting an old Devastators cabinet to a Neo-Geo 2 cart system.
The SFII cab has this sticker-like covering on the wood kind of like the side art I've seen on a lot of cabinets, but this stuff was just 1 big solid colored piece of.... um... vinyl?  I would assume you could get something similar to it at a local sign shop (maybe).
Has anyone come across this stuff (or something else suitable)?
I don't want to spend $40 per side & front (laminate aint cheap!!!) and I was hoping that I could find something like this original stuff that would come in a solid color.
I'll be calling all the local sign/graphics shops to find out what type of stuff they have & dimensions. If I find anything worth-while I'll let you guys know, but I also wanted to check to see if you guys had found anything similar.
I'm attaching an image of the SFIIce Cab that I've got for reference. I'd like to replace that blue with a similar blue... (I'm replacing it because it's in terrible condition & this cab will end up in our living room. (JAMMA set-up, trying to get my hands on a SFIIce board & I've already got a J-PAC... I might get a Dual JAMMA interface, but I'll probably just end up swapping the harness around for a while.)
« Last Edit: September 25, 2003, 10:41:47 am by tmasman »
I'm not a freak!...
Oh wait...
Yes I am...
