Author Topic: Unstupid's Ms. PacMan style cocktail table... Second cocktail table underway!!!  (Read 142057 times)
sandheaver
I can post The DWG files if you want...
Ah, that would be excellent.  Thank you.
I requested that earlier but you didn't respond, so I assumed you were unwilling or unable.
Thank you.
Unstupid
Thank you.
sorry must have skimmed over it.
Unstupid
Here it is:  http://www.unstupid.com/myimages/Unstupids-Cocktail-Table.zip
Couple things to note...
The recess in the Top piece is to fit the sitdown 19" LCD monitor bezel here: http://na.suzohapp.com/monitors/49276500.htm
The notch in the back panel is to fit the cabinet hinge available here (Flush Style 14): http://www.mcmaster.com/#standard-cabinet-hinges/=mp3h8g
The power receptacle cutout is to fit the receptacle available here: http://www.amazon.com/Amico-IEC320-Module-Switch-Socket/dp/B0050HH70E
The coin box has been oversized to fit this one here: http://www.twistedquarter.com/index.php?main_page=product_info&cPath=171_174&products_id=250&zenid=jibsqr91b0kvdj34s1kt85k865
The hole in the front is made to fit a midway coin door but I didn't cut out extra space for the 3 screws on the hinge since mine doesn't have em.
There is slots on the control panel sides to insert and hold a 1/8" piece of white frosted plexiglass.  Had to do it this way since the no longer sell/make the z-brackets that was used to hold it in the past.
Let me know if you have any questions!
« Last Edit: May 13, 2013, 07:03:37 pm by Unstupid »
bmo
  • Last login:October 24, 2013, 11:25:19 am
are you using the metal cocktail controllers or did you create your own wood ones? i may have missed it.
bmo
whoops.. missed the list of parts. I really like those clips though.. do you know where I can get them in 1"? Reason being, I'm using 3/4" tabletop for my cab and 1/4"plexi. Most people use a 1" top so finding good clips like yours is hard.
Unstupid
There is a problem with the cad files that I posted earlier....  The spacing of the holes for the coin box on the bottom panel is wrong...  I'll fix and reupload....
Unstupid
http://www.mikesarcade.com/cgi-bin/store.pl?sku=CTCLIPS34
bmo
that was quick! thanks man.. pretty pricey though.. ouch. oh well.. gotta make it look good :)
Unstupid
