Author Topic: Virtua Fighter 2 ---> Mame  (Read 3123 times)
Coffein
  • Last login:June 14, 2004, 08:15:41 am
« on: September 24, 2003, 04:53:18 pm »
Hi All
I am just starting on a conversion projekt with my VF 2 cab. I will go with arcadeVGA since the NANAO 29" monitor is switchable from 25 khz to 15 khz.
My problem is, can i use the exsisting power supply ? I would also like to use the audio amplifier, because the speaker sound great and can play really loud and have a ok sound. Or should i make a pure PC solution inside with no use off the exsisting 12v supply and speaker amplifier ?
http://home1.stofanet.dk/coffein/virtuaII.jpg
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Virtua Fighter 2 ---> Mame
« Reply #1 on: September 24, 2003, 05:01:32 pm »
are you going to keep The original game int he cabinet too?
Coffein
« Reply #2 on: September 24, 2003, 05:06:00 pm »
I will leave the original in the CAB, then i always can bring it back to the beginning. There is plenty of space to mount a PC MOBO, HD inside the cab, without removing things from the original.
/Coffein
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
« Reply #3 on: September 24, 2003, 05:15:43 pm »
I have the same cab and kept the Nanao Monitor at Medium Resolution with a Trident Blade 64 card.  I get alot better picture than the Arcade Card since I am at a high resolution. The only problem is that on higher resolutions I get a little flicker with interlace issues.  You might want to take a look at that route.
Dartful Dodger
  • Newer isn't always better.
« Reply #4 on: September 24, 2003, 06:33:17 pm »
Virtual Fighter 2 has a great looking cabinet, wouldn't it be nice if someone would take the time to get and post the original cab dimensions.
SirPoonga
  • Puck'em Up
« Reply #5 on: September 25, 2003, 05:05:14 am »
I ask if it will be int he original cab because you could then run BOTH pcb and computer in the cabinet :)  Use something like multijamma, jpac, and arcadevga :)
Coffein
« Reply #6 on: September 25, 2003, 07:38:52 am »
Superdude, then you are running alot of games in strech mode ? What software are you using to get you Trident to funktion with the monitor.
If i use the arcadeVGA will it be nescessary to use the Ultimarc video amplifier ?
Do you have any pictures inside the cab of you modifactions ?
/Coffein
Superdude
« Reply #7 on: September 25, 2003, 04:12:49 pm »
I used Easy Mame Cab CD as base install.  It has advmame and advmenu for Medium Resolution Monitors using a Trident Blade 64 Card.  The card is 36.45 shipped.
I was able to program all resolution through Advmame without stretching for most games.  It looks really nice, except you will have interlacing on a few games.
If you are going to use the Arcade VGA card you will need to switch the monitor to 15khz.    You will not need a jpac, however it is easy to wire if you have one.  The arcade VGA card is a very good card and I own one.  I have not plugged the monitor straight from the pc.  I do not know if it needs an amplifer.  I doubt it does since the monitor is a newer type.
