Author Topic: MAME32 Plus problem  (Read 2688 times)
jbarnatt
  • Last login:March 19, 2014, 05:38:03 pm
  • I built it, now I have to push it.
    • Let me build your arcade cabinet
MAME32 Plus problem
« on: February 13, 2012, 09:29:57 pm »
So I was in a game in the settings menu. The one that you press "Tab" to get into. I accidentally set my UI select key to "none". How do I fix this?
I'd also like to know if there is anyone who can tell me how to find which version of MAME is running. All my Rome work great, but I want to use a central front end. So I need to ditch 32Plus and just run regular MAME. But which version?
Thanks,
Josh
Grimoz
  • Last login:August 06, 2018, 02:11:22 am
Re: MAME32 Plus problem
« Reply #1 on: February 14, 2012, 12:19:45 am »
You should be able to go to the cfg folder in your mame32 folder inside windows explorer and just delete the config file I believe.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #2 on: February 14, 2012, 04:04:13 am »
Right, because ((jbarnatt)), the 'TAB' menu is a MAME feature.
-Banned-
jbarnatt
« Reply #3 on: February 14, 2012, 06:10:52 am »
Yeah, I knew it was the MAME portion of the software. I'm assuming you mean the file I open in notepad. I was looking through the various CFG files in different folders, trying to manually change the setting back. Just plane deleting it should work? Then on restart MAME will generate a new one with default settings?
jbarnatt
« Reply #4 on: February 14, 2012, 12:41:41 pm »
Ha!!!!! Thanks guys.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #5 on: February 17, 2012, 06:37:00 pm »
Yeah, you can delete it, or you can find the entry in the main cfg file and change it. I prefer this, because then I don't have to remap anything.
-Banned-
