Author Topic: changing layouts "on the fly" in mamewah  (Read 1339 times)
nelsonej
  • Last login:October 12, 2011, 11:23:24 am
« on: September 23, 2003, 08:02:06 pm »
I've read from here forever and I finally decided to sign up and post something.  Hopefully you guys can help (just like you've helped 1,000 times before).
I'm putting the finishing touches on my cocktail.  I have control panels so you can play both vertical and horizontal games.  I have many different custom lists, but the two I like the most are Favorite Horizontal and Favorite Vertical.  Could there be a way to have mamewah switch layouts (between horizontal and vertical) when I switch lists?
I haven't experimented with a vertical layout at all, but I'm guessing that Windows has to be rotated for mamewah to be rotated.  If that's the case, it's probably impossible....maybe?
Thanks for any help!
Re:changing layouts "on the fly" in mamewah
« Reply #1 on: September 24, 2003, 01:11:59 pm »
Well, you cannot change layouts per lists, but you could create 2 emulators the same, but have 1 filtered for horizontal, and 1 filtered for vertical games.  This would enable you to use a layout for each orientation...
But I think Windows would have to be rotated to display MAMEWAH vertically...but you could try it out - if you card supports portrait resolutions, it may be able to switch to and from landscape/portrait?...
nelsonej
« Reply #2 on: September 29, 2003, 06:06:36 pm »
I fooled around and I wasn't able to get Windows to rotate the desktop when I changed emulator in Mamewah.
Oh well, I liked the idea.  Guess I'll have to choose which layout I prefer more.  Thanks minwah.
