Author Topic: Taito cocktail style refurb  (Read 8237 times)
DamagedGoods
  • Last login:November 24, 2012, 12:39:17 pm
    • CWorks ~ Waste of space
« on: February 11, 2012, 05:16:17 am »
I'm addicted and want more now.
dead monitor working arkanoid but spinners in bad shape
The victim:
« Last Edit: February 20, 2012, 09:42:02 pm by DamagedGoods »
DamagedGoods
chassis rebuild
« Reply #1 on: February 11, 2012, 05:47:14 am »
well I got it working somewhat.
need to check b+ voltage since I can't adjust width.
but I was able to play a game but forgot to take a pic
screen is nice and clear but forgot a pic of that too.
I skipped over a lot of stuff but i'll get to that later.
Spyridon
Re: My first arcade game
« Reply #2 on: February 15, 2012, 10:15:22 am »
Are you planning on restoring it?
Well Fed Games
  • Delicious!
« Reply #3 on: February 15, 2012, 11:28:50 am »
Cool Arkanoid cocktail!  :cheers:
TopJimmyCooks
« Reply #4 on: February 15, 2012, 02:58:15 pm »
Cap kit? check.  Moon pies? check.  Mardi Gras beads?  Check.
alright boyz lets get soldering!
DamagedGoods
A new width kit
« Reply #5 on: February 15, 2012, 05:25:42 pm »
I plan on turning it into a Taito Space Invaders Part II.
After adding everything in the G07 Deluxe Repair Kit I was unable to set the width full screen so I ordered A width kit.
ended up using the smallest chicklet in the bag  (104k)
I ate the rest and they weren't as good as they looked.
the tape on the screen is below the score and game over burn in.
This must have been run like this for a while.
Edit: looking at the pic I notice it's not perfect yet but close enough for now.
right side is curled down a bit.
« Last Edit: February 15, 2012, 07:00:45 pm by DamagedGoods »
DamagedGoods
« Reply #6 on: February 15, 2012, 05:47:39 pm »
I had planned on always getting A cocktail and throwing A pc in it.
but now that I have one I can't and won't do that with this.
DamagedGoods
New control panels
« Reply #7 on: February 15, 2012, 05:57:14 pm »
just picked these up.
DamagedGoods
Monitor chassis location
« Reply #8 on: February 15, 2012, 08:14:32 pm »
stiil trying to figure out where to put it.
it was on the left side and now it's on the right.
but I've seen it also in the center against the front.
also where to find a bezel for the 12" square opening.
I found A pic of A carnival cocktail that had same 12" sq opening.
red line is where it was green is how it sits now, blue is where it might end up.
need more room on left for at least 5 boards (2 games) that are too long to lay down with jamma adapters attached.
« Last Edit: February 15, 2012, 09:13:32 pm by DamagedGoods »
DamagedGoods
goodbye Arkanoid.
« Reply #9 on: February 16, 2012, 10:00:41 am »
Arkanoid ready to ship out.
second pic is of the tinted plexi sitting on the monitor.
need to drop it down about an inch or more.
and the home made brackets holding up the monitor.
plan on adding some tabs that drop down to attach to the tabs on monitor.
on left side this screw isn't even attached to anything but the tab.
« Last Edit: February 16, 2012, 11:52:03 am by DamagedGoods »
DamagedGoods
just 2 more I forgot about
« Reply #10 on: February 16, 2012, 10:14:50 am »
somebody tried to make these fit by cutting with a sawzall.
in first pic these are flipped so look at outer edge in center of bar.
holes closest to edge were the ones holding it up.
DamagedGoods
monitor adjustments
« Reply #11 on: February 17, 2012, 09:48:40 pm »
made some z clips to lower the monitor about an inch.
yea I know a c clip is easier to make but I just love making z's.
I then tried adjusting the screen again and ran into a little problem.
R525 burst into flames.
anyone know what size resistor this is on a g07-fbo
Edit:
Found it 10K Ohm 1/2W Flameproof Resistor. :laugh2:
« Last Edit: February 18, 2012, 03:59:20 am by DamagedGoods »
DamagedGoods
resistor ?
« Reply #12 on: February 20, 2012, 08:07:38 pm »
just wondering before I check.
is this resistor part of the horizontal circuit.
maybe I was too far out of range with the 104k chicklet.
224k was close but 104k was too much and left very little adjustment. (bottom text was a little off and maybe top)(vertical game)(need to get pcb with a test pattern. konami board?)
gonna try the 224k in series with the 334k and see if that is cool with r525.
btw I'm not one to wait for an answer so it will most likely be tried beforehand.
just figured I'd mention if you smell something burning it may not be just because you cleaned the board.
be sure to check the temp of everything after disconnecting the power.
« Last Edit: February 20, 2012, 09:56:44 pm by DamagedGoods »
DamagedGoods
resistance is futile
« Reply #13 on: February 22, 2012, 12:53:47 am »
R420 cooked itself.
am I gonna be going back and forth to the store to get resistors?
if so this is never gonna happen and I should probably just set fire to this.
MaxVolume
  • Last login:November 30, 2012, 01:52:38 pm
« Reply #14 on: June 13, 2012, 03:57:24 pm »
Kitty hiding on the couch? check! ;)
DamagedGoods
Re: Taito cocktail style refurb
« Reply #15 on: June 13, 2012, 04:43:31 pm »
no doggy watching me take pictures of his new pissing post. :angry:
I'll get this finished one of these days. :dunno
MaxVolume
« Reply #16 on: June 14, 2012, 01:12:18 pm »
Oops... the pointy ears threw me. :-[   I made sure I had finished the back door of my mini-cab before moving it into the house for similar reasons.  All it took was seeing how the cat at the sign shop walked right in like it was his home when I picked up after having the sideart applied and I knew my dog would probably do the same, and possibly worse.  So far he hasn't paid much attention to it, but there's nice rubber trim at the bottom to chew on, and he has repeatedly peed on the floor where it's sitting now, so I'm sure it's just a matter of time.  :timebomb:
