Author Topic: Twilight Zone Switch Question  (Read 2383 times)
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« on: February 07, 2012, 06:42:09 pm »
Think I am having an Opto Sensor issue on my Twilight Zone Pinball.  Can anyone out there check to see what the normal position of Switch 73 is under the the tests menu?  Mine says open but I think the normal position should be closed.  I can see that the LED is working but think the receiver may have gone bad.  Thank you!
Dawgz Rule
Re: Twilight Zone Switch Question
« Reply #1 on: February 07, 2012, 09:25:27 pm »
Thank you.  I'll let you know what happens.
Dawgz Rule
« Reply #2 on: February 09, 2012, 07:46:22 am »
No beeps.  I also did some reflowing of the solder on the receiver but that didn't seem to do anything.  The transmitter looks good.  I looked at it with a digital camera and it is on.  Did a disconnect and reconnect of all of the connection points too.  Looks like I need a new receiver.  Any recommendations as to where to purchase?  In the past I have gone to Marco but am always interested in what others are doing?
Dawgz Rule
« Reply #3 on: February 09, 2012, 07:25:41 pm »
Thank you.  Much appreciated.  Should be an easy enough fix.
