Author Topic: possible input bug in mame... Please confirm.  (Read 1036 times)
freppa
  • Last login:September 30, 2004, 08:45:31 am
« on: September 23, 2003, 10:00:08 am »
I have noticed a possible input bug in mame. I'm using a hacked keyboard for inputs so I don't use the standard keymap. I've setup controllerfiles and they seem to work except for one thing.
In some games which I havn't played before, I get passed the legal nagscreen by wiggling the joy, but I can't get pass the following impefectsoundwarningscreen in the same way. It does work fine if I set joystick=1 in mame.ini, but not if it's joystick=0
If I get the game started using the above joysticksetting, I can start the game again without setting joystick=1, and everything is fine since the legal nagscreen is gone.
If I then delete the cfg file for the game I'm back at square 1.
It happens with several games, but the one I was testing yesterday was Teki Paki (tekipaki.zip). I don't think this occurs if you use the standard keymap (UI mapped to arrowkeys). I've tested it with smoothmame 0.71 to 0.73 and FastMame 0.73.
Can anyone else confirm this as a bug or is this a flaw in my controllerfiles?
/Freppa
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:possible input bug in mame... Please confirm.
« Reply #1 on: September 23, 2003, 12:47:06 pm »
Since I have always had joystick=1 I have not noticed this problem.  I will check it out sometime.
