Author Topic: Speaker knob or no speaker knob for bartop?  (Read 2150 times)
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« on: February 01, 2012, 06:21:19 pm »
I added a speaker knob into my last cabinet by hacking up a speaker with the the components integrated into the speaker. It was a royal pain, but it turned out alright.
Is it worth the pain to add a speaker knob into my next cabinet (which will be a bartop)?
Did you add a knob to your bartop?
If so, what kind of speakers did you use, how did you mount your knob, and how easy was it?
If you do not have a knob on your bartop, are you happy with your decision? What have you been doing to adjust your volume?
« Last Edit: February 01, 2012, 06:33:33 pm by emb »
tsaylor
  • Last login:April 20, 2019, 05:16:20 pm
Re: Speaker knob or no speaker knob for bartop?
« Reply #1 on: February 02, 2012, 12:59:43 am »
My cabinet isn't a bartop, but in my case I just went for shifted buttons to control volume up/down (the current Mini-PAC firmware allows volume to be assigned to buttons or shifted buttons).  I've got an amp within that cabinet that does have a volume knob, but it isn't accessible from the outside so I just pick a decent central volume level and then adjust up/down from there at the Windows level (via shifted up/down presses on my joystick).
BobA
  • What Me Worry?
« Reply #2 on: February 02, 2012, 09:44:13 am »
In my bartops I leave the knob on the the amp board or separate amplifier and access it by opening the back of the cabinet.  I leave the amp set at a comfortable volume and usually do not have to change it very often.  The MP3 player has volume controls on screen and Maximus Arcade has a volume control that you can access with one button.
mountain
  • Trade Count: (+9)
  • Last login:January 29, 2025, 08:31:47 am
    • Mountain Jukeboxes
« Reply #3 on: February 02, 2012, 10:27:06 am »
I am using one of these in my current cabinet build. Super easy to install, just wire it between your PC and speaker input.
