Author Topic: Playstation to JAMMA Video Problems  (Read 1293 times)
meatball
  • Newbie
  • Last login:September 23, 2003, 04:31:17 am
« on: September 23, 2003, 04:41:06 am »
I'm making a Playstation to JAMMA converter. I have the controls wired, they are working perfectly. For the video, I've used the output of a Playstation SCART cable with an LM1881 circuit to generate the proper sync (as described in the console section of the PC2JAMMA page).
With the Playstation plugged in, the monitor on my cabinet displays a recognisable picture. However, it is extremely dark. No adjusting of the monitor controls can fix it. Is this likely just a case of bad connections/soldering, or has anyone any other ideas?
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Playstation to JAMMA Video Problems
« Reply #1 on: September 23, 2003, 04:34:20 pm »
The brightness knob is usually on the flyback, real easy to miss.
Also, you might try adding 220uF capacitors to the RGB lines, that helps sometimes.
