Author Topic: NT-2701 HORIZONTAL Collapse (SOLVED)  (Read 8423 times)
smartbomb2084
  • Last login:January 13, 2021, 03:14:53 pm
  • Having a SMART phone will make you DUMB.
« on: January 14, 2012, 07:58:34 pm »
Hey all,
Got one of these NEOTEC NT-2701 monitors in which the HOT and Flyback were replaced a little over two years ago and suddenly, the other day, it developed the dreaded Tick Tick Tick.
I check the HOT and sure enough it is blown. I replace the HOT and check the board over and can't find anything else wrong. I fire up the monitor and it now has Horizontal collapse...
As far as I can tell IC 401, IC 501, Q 501, and the yoke are all good.
I am missing something here... What is it?
« Last Edit: April 18, 2012, 06:23:42 pm by smartbomb2084 »
Ken Layton
  • Guru
  • Technician
Re: NT-2701 HORIZONTAL Collapse
« Reply #1 on: January 16, 2012, 01:07:50 am »
Check the width coil. Look for cold solder joints.
JBARAHONA55
  • Last login:July 26, 2012, 07:20:25 pm
« Reply #2 on: January 16, 2012, 07:13:12 am »
check horizontal yoke resistance
if yoke is ok call jbmonitorrepair.com
if yoke is ok
check this link jbmonitorrepair.com ask for jose b
smartbomb2084
« Reply #3 on: January 16, 2012, 05:41:51 pm »
I checked the width coil (L401) and it seems good.
I don't know if it is the right value but I do know that it is not 'open' and that it has continuity within the circuit.
I solderd the Hell out of everything in sight.    I still have the same condition...
Could Q501 be bad even though it tests good out of circuit?
Any chance of IC301 causing this?
grantspain
« Reply #4 on: January 16, 2012, 05:54:20 pm »
should you not be looking at the horizontal yoke circuit,there are a couple of diodes,a resistor plus the hot(looks like a bu25xx) can't see if its q401 as the schem is poor
smartbomb2084
« Reply #5 on: January 17, 2012, 05:34:02 pm »
Well... back to square one.
Blew the replacement HOT today... I knew it wouldn't last.
I'm feeling the pain.
 :banghead:
lilshawn
  • Last login:Yesterday at 11:14:57 am
« Reply #6 on: January 21, 2012, 07:48:56 pm »
i dont have a schematic handy for the 2701 but there is a chip that sends out the horizontal pulses for the HOT. they often go.
i think it's like a LM7823 or 7830 or some TDA like a 8172... something like that.
MKFan4Life
  • Last login:July 24, 2023, 08:18:00 am
  • My arcade machines...
« Reply #7 on: January 22, 2012, 04:49:35 am »
grantspain
« Reply #8 on: January 22, 2012, 01:33:27 pm »
if the hot is blowing constantly and the high voltage caps on the collector are reading fine then i suggest you remove and check the yoke for burning internally
i have had 2 x d9200 monitors in last few weeks with failing yokes,they read fine but when operation they short and destroy the horizontal deflection circuit
smartbomb2084
« Reply #9 on: January 23, 2012, 08:28:49 am »
Thank you gentlemen for the replies.
I have had to shelve this monitor temporarily until I get some more HOTs.
The Horizontal control IC is IC401 an LA7851 which has been replaced.
The above drawings from MKFan4Life are the original series and the monitor I have is the later series from 2004. I need to upload these drawings as they seem to be impossible to find on the web for download.
I am not sure how horizontal collapse is even possible.  If I have horizontal collapse doesn't that indicate that the HOT is good and switching and that the flyback is good too?
How can I check the yoke for internal shorts?  I checked the yoke on a known good WG 27D9200 and I got the same resistance reading of .05 Ohms.
grantspain
« Reply #10 on: January 23, 2012, 11:37:43 am »
no horizontal deflection but HOT ok could be missing voltage,i.e a safety resistor blown
can't read faulty yokes as such,read fine when off but short when power applied-well thats the case with 6 x d9200 i have had in last 2 months
ed12
« Reply #11 on: January 23, 2012, 01:40:32 pm »
i know them bugger's are famous for
a short in the foucs circuit of the high voltage divder control's
ie foucs and screen
u will note  it on the side of the hot
right betwenn the control's and or right beside it
the will arc to ground
now i have trided to contact the mfg but there phone's no longer work
and i have not been able to source out a flyback
maybe ken could help as i have 4 of them the same way
ed
grantspain
« Reply #12 on: January 23, 2012, 02:13:33 pm »
« Last Edit: January 23, 2012, 02:16:49 pm by grantspain »
MKFan4Life
« Reply #13 on: January 23, 2012, 07:01:32 pm »
Oh, sorry about that.  This manual came with my monitor in the Gauntlet Legends cab when I got it.  Seems like users on here told me my chassis itself was odd, 'cause I showed pics of it where the neckboard has the NT-2701 designation on the attached cardboard, but on a metal plate on the chassis it showed NT-27E.  Schematics in the manual seems to match well though.  Lol.  :dunno
smartbomb2084
« Reply #14 on: January 23, 2012, 07:48:47 pm »
No need to be sorry, I appreciate the gesture in providing information.
I tried to do the PDF scan of the later manual but can only seem to get one page at a time without having to 'subscribe' to the Adobe system of 'online' PDF creation.  Looks like its the JPEG route for me next.
I have ordered some HOTs (BU2532AL) and they are in transit.
I am suspecting that C423 (924J / 400V) is bad but can't find one anywhere.
Flyback MRCFT-252 is the same one I have used too.
smartbomb2084
« Reply #15 on: April 18, 2012, 06:21:43 pm »
FINALLY got back to working on this recently...
Turns out C423 IS bad, OPEN actually.  Couldn't find a film cap rated at .92 mF so I ended up with a 1.0 mF film cap instead.
Picture is nice and wide now and still has plenty of Horizontal width adjustment.
THANKS, as always, to those who helped out.
MKFan4Life
« Reply #16 on: April 18, 2012, 07:43:00 pm »
Glad you got it working man.   :applaud:
