Author Topic: Resolution 640 x 480 = screens flickering  (Read 3706 times)
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« on: January 11, 2012, 02:24:31 am »
Hi all,
Hoping someone can help.
Under Mala I'm running it at 640 x 480 on a Arcade Screen (15 Khz) using soft 15Khz. At this resolution there is screen flicker (only way I can describe it). I read some where that this is a interlace resolution and will cause this symptom. I changed it to 312 x 240 and the flicker stopped, but I could only see part of the screen, as the image was way to large!!
Games don't seem to do it, just the front end.
Anyone got a fix??
Thanks in advance
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
Re: Resolution 640 x 480 = screens flickering
« Reply #1 on: January 11, 2012, 07:50:25 pm »
Correct on the interlace.  In order to display that high of a resolution, the monitor will go to interlaced mode.  I use GameEx on my front end and there is an option to set the resolution which I have at 640x288.  I would imagine this could be done by changing the Mala layout.
sega_mad
« Reply #2 on: January 11, 2012, 10:08:37 pm »
Hi,
Thanks for the reply.
I tried that....no success  :'(
On closer inspection, the games do show some flickering (all though not noticeable behind a dark tinted screen).
If I remember correctly (from ages ago), the developer of soft 15Khz said it couldn't be fixed when I asked about it.
I don't believe soft 15Khz has any display setting options, and the video card (Radeon 9600) can only go down to 640X480
How do you play your games at a lower resolution???
Thanks again for trying
« Last Edit: January 11, 2012, 10:45:09 pm by sega_mad »
MTPPC
« Reply #3 on: January 24, 2012, 02:59:40 am »
Use catalyst 6.5 for the video card driver and quickres to set low resolutions. Then use this tool to create your ini files: http://www.ultimarc.com/avres.zip.
Sorry I can't give better details, but it's been a couple months since I did it and don't remember exactly how I did it. I do remember that I needed to figure out valid resolutions for my setup and then edit the avres config file to set only those that work.
http://pinballmd.com/
sega_mad
« Reply #4 on: January 24, 2012, 03:16:43 am »
Hi.
What does Catalyst 6.5 do?
how is that different to the one I'm running?
Have used Avres before, but with no luck.
Cheers..
« Last Edit: January 24, 2012, 03:19:01 am by sega_mad »
PaTrYcK
  • Last login:May 02, 2020, 05:22:19 am
« Reply #5 on: January 24, 2012, 07:47:55 am »
Hi, disinstall driver , then install this driver
(download Radeon Omega Drivers 3.8.252  - This release is based on ATI Catalyst 6.5. )
http://www.ngohq.com/home.php?page=Files&go=cat&dwn_cat_id=14
After reboot use quickres for change resolution  (http://files.arianchen.de/soft15khz/quickres.zip)
Dawgz Rule
« Reply #6 on: January 24, 2012, 12:12:26 pm »
Funny, just ran into a similar issue but at all resolutions.  My fix was to remove the ATI driver and install again clean.  Probleme solved.  Go figure the luck of that one.
sega_mad
« Reply #7 on: January 27, 2012, 04:41:05 pm »
Thanks very much......all sorted now.
Just got to sort out the resolutions on CPS3 emulator. (have posted in the software section if someone can help)
Thanks again  ;D
