Author Topic: 2005 Golden tee  (Read 2397 times)
mikennickiex2
  • Last login:January 27, 2012, 05:45:55 am
2005 Golden tee
« on: January 05, 2012, 08:38:36 pm »
Hi, we bought our son a used 2005 Golden Tee at auction for his game room. all of a sudden the monitor seems to have lost all color except what appears to be blue and black. the picture and sound are there, but the picture is a strange color. what I see seems to be blue and black and no other colors. has anyone seen anything like this before? could it be something simple like a bad connection? something dirty? or is this something expensive? thank you all for any help. and if I have posted in the wrong place please let me know.
lilshawn
  • Last login:November 26, 2025, 03:26:23 pm
Re: 2005 Golden tee
« Reply #1 on: January 09, 2012, 02:42:25 pm »
Maybe a loose connection... check the big long black connector on the edge of the board. If you feel adventurous, remove the board and use a pencil eraser on both sides of the board connector. The little fingers of metal get dirty and sometimes can cause problems.
nordemoniac
  • Weee! Hahaha...
Re: 2005 Golden tee
« Reply #2 on: January 12, 2012, 07:55:06 am »
Check solderpoints. I had a similar problem, and a transistor was to blame. The solder point had broken off from the PCB. A bit of tweaking and resoldering did the trick :)
lilshawn
Re: 2005 Golden tee
« Reply #3 on: January 13, 2012, 03:12:26 pm »
(he would be talking about the board attached to the end of the picture tube)  :P  :cheers:
mikennickiex2
Re: 2005 Golden tee
« Reply #4 on: January 27, 2012, 05:45:54 am »
Thank you VERY much. I will try that all out when I get over to his house soon. I will let you know if that works. ( fingers crossed )
