Author Topic: closemul - amiga help needed  (Read 2971 times)
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
« on: January 02, 2012, 06:42:45 pm »
hi all,
it's been a while since i've updated my emu's and am doing so now.  unfortunately, i've forgotten how to use some things.
i am running winUAE 2.3.3.0 (for amiga and cd32) and it starts fine thru my front end but i can't seem to get it to quit with ESC; enter closemul.
winUAE uses ctr+f11 to quit.  if i'm not mistaken, i need to enter the ASCII code for CTRL and also F11 into the closemul cfg file.  but i can't seem to find ascii codes for these two keys.
anyone on here using closemul with winUAE?  little help?  pretty please?
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
Re: closemul - amiga help needed
« Reply #1 on: January 03, 2012, 10:42:47 am »
Have you tried using a launcher like WinUAE Loader ( http://headsoft.com.au/index.php?category=winuaeloader )? You can set a global exit key (ESC) that kills WinUAE.
I have used it on my cabinets with great success. :)
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
tony.silveira
    • my baby
« Reply #2 on: January 03, 2012, 05:06:13 pm »
i use it for launching into amiga mode, didn't realize i could use it to launch amiga cd32!  duh!  thanks, i'll give it a try
EDIT: can't seem to figure it out :(
« Last Edit: January 03, 2012, 07:18:39 pm by tony.silveira »
gonzo90017
« Reply #3 on: January 03, 2012, 07:31:45 pm »
You need to enter the ASCII code for the button you want to use to quit the emulator.
Example ESC = 27
tony.silveira
    • my baby
« Reply #4 on: January 03, 2012, 07:36:07 pm »
Example ESC = 27
i've tried looking up ascii tables but cant find ctrl+f11 anywhere
gonzo90017
« Reply #5 on: January 04, 2012, 02:14:53 pm »
You do not need to use Ctrl+F11. You can set ANY key to exit the emulator.
- Exit Key 1:      (ASCII key code). The key that will be used to Exit the Program. Defaults to ESC (27).
tony.silveira
    • my baby
« Reply #6 on: January 04, 2012, 07:29:21 pm »
i've been using closemul wrong all these years?  i was under the impression that closemul "listens" for the "ESC" key to be pressed and THEN sends the user input command listed in the "exit key" lines.
i just tried it with 27 as suggested and it still isn't quitting.  also tried leaving the line blank (default is ESC) and it still didn't do it.
fyi, i just tried an old wrapper i have for the vpinball emulator and it worked!
