Author Topic: Octopus cable -> jamma... Anyone?  (Read 1390 times)
Lilwolf
« on: September 19, 2003, 04:03:38 pm »
I was hoping to use my octopus vga cable to connect to an arcade monitor (hooked to a jamma connector).
Anyone know how to do it?
(btw, only if you got the information... I can get the ohm meter out and figure out which pin is going to what cable... but it seemed like someone might know off the top of their head)
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Octopus cable -> jamma... Anyone?
« Reply #1 on: September 19, 2003, 05:00:47 pm »
http://www.gamesx.com has pinouts for both VGA and Jamma.  You could also get a J-Pac from http://www.ultimarc.com and that would take care of the keyboard encoder too, if you're doing it for a Mame machine.
Lilwolf
« Reply #2 on: September 20, 2003, 10:20:48 am »
It was more the vga -> octopus cable.  I know the others sources.  But I was hoping someone might have already figured it out.
btw, the octopus cable breaks out the rgb stuff.
tom61
« Reply #3 on: September 21, 2003, 07:44:42 pm »
You mean into BNCs? There should a diagram or color coding scheme out there. I think it goes something like Red, Green, and Blue are RGB, white is H-Sync, black is V-Sync. Since you connect the H-Sync and V-Sync together, it doesn't really matter which is which.
TheGatesofBill
  • Last login:August 22, 2018, 09:07:04 am
« Reply #4 on: September 21, 2003, 07:46:27 pm »
This may be helpful: http://www.solvalou.com/arcade_jamma.php . Scroll down and it shows you where everything goes on the harness.
Off topic, but are you a fur, or do you just like wolves?
