Author Topic: Problem with groovymame32_0144u2.013d / HLSL / Galaga?  (Read 5192 times)
jimmy2x2x
« on: December 13, 2011, 05:01:57 pm »
I am running groovymame32_0144u2.013d and have a problem with Galaga when run with HLSL enabled.
Deleted all .cfg and .ini files
generate new .ini with -cc option
edit mame.ini
video d3d
hlsl 1
monitor vga
groovymame32_0144u2.013d.exe galaga
Galaga boots, shows post screens then after the white grid blacks out the screen, I can get the tab menu to display but no graphics
All other games seem fine
any ideas?
Calamity
  • Moderator
  • Last login:Yesterday at 05:28:27 pm
  • Quote me with care
Re: Problem with groovymame32_0144u2.013d / HLSL / Galaga?
« Reply #1 on: December 14, 2011, 07:55:51 am »
Hi jimmy2x2x,
I've no clue of what can be happening, running galaga here with hlsl and your same settings does work normally.
Steps to create a log:
jimmy2x2x
« Reply #2 on: December 14, 2011, 04:10:58 pm »
Very strange!
Thanks for testing
I will try it out on a  couple of other PC's see whats happening there..
Calamity
  • Moderator
« Reply #3 on: December 14, 2011, 05:22:12 pm »
Try and get a screenshot when there's no video, and check if it's black too.
jimmy2x2x
« Reply #4 on: December 14, 2011, 06:22:30 pm »
Solved, thanks for the tip!
The screenshot showed the graphics
So I disabled the shadow mask texture and now its fine ;)
Must have been an alpha channel issue
« Last Edit: December 14, 2011, 06:43:31 pm by jimmy2x2x »
Calamity
  • Moderator
« Reply #5 on: December 14, 2011, 06:48:20 pm »
Strange... I've tested it on xp32, ATI HD4350, Catalyst 11.??
Please test it with normal MAME too if possible. Also, try using the -monitor lcd option.
