Author Topic: ArcadeOS and mame  (Read 3324 times)
Velcro
ArcadeOS and mame
« on: June 14, 2002, 06:16:59 am »
I looked everywhere for an answer and found only more people with my problem but no solution. Here it is, I run ArcadeOS and windows mame (too many reasons why I'm not using DOS mame) and when I run a game from ArcadeOS everything is good, it's when I exit that it minimizes ArcadeOS until I click it or Alt+TAB. But that is not the ideal solution for an arcade cabinet.
Does anyone know how to make AOS pop itself back up after running a game?
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re: ArcadeOS and mame
« Reply #1 on: June 14, 2002, 11:36:36 am »
So you have AOS running full screen and every thing is fine. You pick a game to run and everything is fine. You press the escape key once, and when the game exits, AOS minimizes?
I don't have that problem with AOS. Are you running AOS from a .pif file? Check to make sure it's set to "full screen" and maximized.
Bob
Velcro
« Reply #2 on: June 14, 2002, 04:02:58 pm »
check.
check.
CHECK!
I am running it from a shortcut file that is placed in the startup menu, but yes fullscreen and maximized are CHECKED!
Jakobud
  • Last login:Today at 11:28:14 am
« Reply #3 on: June 14, 2002, 07:04:42 pm »
If I were you I would forget about ArcadeOS.  It's not that good.  Id look elsewhere for a better frontend ( GameLauncer hint hint).
jakobud
Velcro
« Reply #4 on: June 15, 2002, 12:53:50 am »
same thing happens with gamelauncher hint hint  :-/
  • Last login:Today at 12:17:00 am
« Reply #5 on: June 17, 2002, 01:41:52 pm »
That's because both of these fe's are dos-based.  Try a true windows front-end (hint hint).
(Yes I know gl is now ported to dos, but the author hasn't really optimized it for windows yet.)
Pieter Hulshoff
Re:ArcadeOS and mame
« Reply #6 on: July 23, 2002, 04:39:31 pm »
Hmm, I seem to remember this problem. Try starting a DOS windows, and set the properties by right-clicking on the top of the window. I don't remember exactly which setting it was, but I'm sure trial and error might get you a long way. :)
Tweder
  • Last login:August 31, 2002, 09:38:44 pm
« Reply #7 on: July 23, 2002, 08:51:04 pm »
Lucky you! I cant even get the roms to appear! can someone please tell me!? I am putting it in my cab later this week which I buit today :)
Darke
  • Last login:October 06, 2002, 03:26:23 am
  • Master Of The Obvious!
« Reply #8 on: July 26, 2002, 03:06:47 am »
Never heard of this problem before....but then again I run ArcadeOs in DOS with AdvanceMame and have 0 problems.
Wherever you go, There you are.
