Author Topic: Dreamcast Battery?  (Read 7724 times)
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
Dreamcast Battery?
« on: September 18, 2003, 10:10:41 am »
My Dreamcast recently stopped remembering the date. I opened it up and found the CMOS battery was corroded...so I pulled it. Now for my question. Does anyone know if I can replace the battery in the Dreamcast with a generic CMOS battery (eg. Maxell CR2032 (3v)--have a few laying around). The battery I pulled is a SANYO ML2430 (3v). I realize it won't fit exactly the same. I'm not concerned with that as I bent the posts pretty badly removing the battery anyway. Thanks in advance.
All Your Base Are Belong To Us!
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Dreamcast Battery?
« Reply #1 on: September 18, 2003, 03:30:51 pm »
A 3V battery is a 3V battery. The only difference is that the one in the Dreamcast was rechargable.
Spaced Invader
« Reply #2 on: September 18, 2003, 09:52:37 pm »
I realize a battery is a battery is a battery buuut...The CR 2032 is also a CMOS battery hence rechargable (so no difference there)...what I was wondering was whether the charge rate (current draw) of the CR2032 vs. the original would cause a problem. <---Sorry 'bout that big 'ole run on sentence. I should have been more specific with my concerns in my original post (must have sounded like a knucklehead from the simplistic answer I got).
Anyway, I put it in. Hopefully there won't be a problem. Thanks for tryin'.
Oops...I did some research (should have done that first), and it appears the CR 2032 is not rechargable (yes I really AM a knucklehead). Which still leaves me with a delima. If the DC is expecting a rechargabel battery (and sending a trickle charge) then won't the battery be damaged by the console?  ???
« Last Edit: September 19, 2003, 07:44:31 am by Spaced Invader »
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
« Reply #3 on: September 18, 2003, 10:44:11 pm »
the cr-2032's are rechargable?
does that mean that If I plug in an old motherboard with a old powersupply, and put in a dead CR-2032 battery, it'll act as a battery recharger for my VMU's?
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
Spaced Invader
« Reply #4 on: September 19, 2003, 07:45:22 am »
Nope...see my post above...sorry.  :-[
tom61
« Reply #5 on: September 19, 2003, 05:04:28 pm »
I got to thinking about the trickle charge issue not long after I posted, not sure if that would cause troubles. If it does, it's only $30 to get another DC.
I think getting the same model of rechargable battery would probably be best though. Do a Froogle search for the model number of the battery.
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
« Reply #6 on: November 05, 2003, 02:12:33 pm »
Anyone find out anything more on this issue?  I ask because my DC is now exhibiting the same behavior as was described previously (I have to set the Time/Date every time I power the DC on).  Another Dreamcast may only be $30, but I'd rather not have to replace my DC every 7 months (I got mine in April).  I'll open mine up and see what the search engine gods have to say about it.
If no one feeds the trolls, we're just going to keep eating your goats.
Cameronj
  • Last login:August 03, 2012, 12:59:01 pm
  • I'm a Super llama!
« Reply #7 on: November 05, 2003, 02:47:25 pm »
here is a site that has some rechargeable sanyos...
http://www.tnrtechnical.com/lithium-batteries.html
Spaced Invader
« Reply #8 on: November 10, 2003, 01:27:50 am »
That's it! Thank you, thank you, thank you...I may have to name a child after you...or a puppy...or something.  ;D
abrannan
« Reply #9 on: November 10, 2003, 11:32:51 pm »
Here a site that takes the repair a different route:
http://www.namakoteam.com/dcbattery.html
