Author Topic: WIP Lucky 7 arcade  (Read 9250 times)
said7
  • Last login:January 24, 2012, 02:24:47 pm
  • "I smell..... NERDS" - Ogar
    • www.said7.com
WIP Lucky 7 arcade
« on: September 18, 2003, 09:59:11 am »
Well this is what been taking up my time the last 3 months. It a real non traditional cab and if im not mistaken the first made in this style.
Ill have a full website and plans comming out when i finish.
I still need to do my artwork (something really cool started)
Speaker panel and plexi front. Everything else is pretty much done.
Check out my site: http://www.said7.com
Arcade site comming soon.
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
Re:WIP Lucky 7 arcade
« Reply #1 on: September 18, 2003, 10:07:31 am »
Pretty cool bud.
What size monitor are you going to end up with in there?
I know you're not keeping that little 19" in there... :-\
I like the industrial theme...
You ought to go for a MAMEy... hehe... It's definately an original.
I'm not a freak!...
Oh wait...
Yes I am...
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
« Reply #2 on: September 18, 2003, 10:32:41 am »
Absolutely cool!   :o
This should take place in a scene of the next Alien-film. Good work!  :D
SpAwN
  • Last login:August 09, 2006, 01:41:48 pm
  • Mame Cab done, working on restoring a Wurlitzer
« Reply #3 on: September 18, 2003, 10:34:35 am »
I like your cab design. Very artistic with cup holders!
Is that red glow at the bottom on purpose?
Carsten Carlos
« Reply #4 on: September 18, 2003, 10:36:04 am »
It's sure an evil machine. Be careful!
said7
    • www.said7.com
« Reply #5 on: September 18, 2003, 10:41:21 am »
Thank all :)
The red glow is a string of red rope lite that goes all the way around the cabs bottom. looks real cool at night.
As far as monitor goes im gonna upgrade to a 27 inch TV or monitor im mstill debating, but i gotta wait till its in the budget :(
tmasman
  • Hello...
« Reply #6 on: September 18, 2003, 10:46:39 am »
That's cool... I just wanted to make sure you weren't planning on abusing that piece of art with such a small monitor for the rest of it's life... ;)
I'm not a freak!...
Oh wait...
Yes I am...
zero-one
  • Last login:December 17, 2003, 10:30:04 pm
  • Still learning...
« Reply #7 on: September 18, 2003, 10:47:38 am »
Very nice and original.
What are the overall dimensions? ie. height, width, and depth. Just trying to gauge the size of it.
Will it be deep enough for a 27" monitor?
Thanks.
said7
    • www.said7.com
« Reply #8 on: September 18, 2003, 11:01:24 am »
Its about 7 feet tall and about 30 inches wide from the front.
Monitor depth will be an issue I think this 19 inch i have is right up against the back.
When i get to that point im just gonna have to see maybe i can get a tv that would fit.
Worst case scenerio I cut some "venting" holes.  ;D
3dmacman
  • Last login:December 24, 2010, 01:34:30 pm
  • Gaming, its a way of life.
« Reply #9 on: September 18, 2003, 11:23:03 am »
Just curious, the wires coming from the control panel, do they serve a function or just decoration. If functional, good use of wiring! ;D
pathdoc2
  • Last login:January 11, 2006, 08:49:53 pm
  • Your friendly pathologist
« Reply #10 on: September 18, 2003, 11:34:04 am »
One of the most original cabs I've ever seen.   Strong work.
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #11 on: September 18, 2003, 02:28:36 pm »
Very cool...VERY, VERY COOL! God it's nice to see something original!  8)
All Your Base Are Belong To Us!
Apollo
    • Eight Bells
« Reply #12 on: September 18, 2003, 05:17:18 pm »
WOW that is cooool. Love the red light at the bottom. Kinda makes my cab project seem a bit feeble now lol.
Well done.
I bet that control panel still isn't finished in 6 months lol.
DAmnb
  • Last login:July 28, 2011, 03:35:40 pm
  • R-Type for president!
    • TheGameCollector
« Reply #13 on: September 18, 2003, 06:36:06 pm »
I like it, cant wait for the website and more pics of this goodie!  :D
SNAAAKE
  • -Banned-
« Reply #14 on: September 18, 2003, 08:43:37 pm »
~ :D WOAH !
Very...futuristic(spelling?))
How did you paint the cab like that though  ???
VERY nice work...its modeled after the sega virtua tennis cab right ?
those wires are REALLY kewl :o
« Last Edit: September 18, 2003, 09:07:16 pm by SNAAAKE »
paigeoliver
  • Awesome face!
« Reply #15 on: September 18, 2003, 09:49:58 pm »
Is that white thing on the control panel a small spinner, or a soda bottle cap?
said7
    • www.said7.com
« Reply #16 on: September 19, 2003, 08:43:43 am »
Hi guys, Thanks for the compliments i am really suprised how well recieved my cab would be.
They are only cosmetic the real wired run through the bottom of the CP.
Thanks snake. I painted the cab with primer/sand/primer/ Then i used some gray paint i got at home depot and mixed in some metalic paint though the metallic didnt show up that much. I wanted to do like an airplane type theme.
I then put 2 or 3 base coats sanding in-between. I recently got into airbrushing so i took a shot a doing it on the cab. I went for a metallic plate look if you look close you can see i painted over 100 rivets. For the red parts I cut stencils out using illustrator and gave it a sloppy red  overlay I then poly eurethaned the whole thing 3 times with a spray gun.
It came out very well it almost looks and fells like laminate and is very stain and wear resistant. I was a little dissapointed with the pictures make the paint look sloppy.
Heres some other stuff i recently airbrushed,
said7
    • www.said7.com
« Reply #17 on: September 19, 2003, 08:47:05 am »
Bottle cap  ;D er  i mean a limited edition evian spinner. Oscar told me not to leak it out  ;)
hyiu
    • www
« Reply #18 on: September 19, 2003, 09:59:31 am »
although I talked to you briefly...
still have to say.... VERY NICE CAB !!!....
a very good and special theme for it !!!....
very cool..... ;) ;D
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #19 on: September 19, 2003, 08:15:22 pm »
Eeeek. Is that Aluminum diamondplate for a floor mat!??!?!?!?!
You realize the reason they bolt metal down in a car is because it can decapitate you, right????
Broken glass for a floor mat looks even cooler..... it's all sparkley. Looking forward to the future Darwin award.
p.s. Nice paint on the cab, I'm not a fan of the overspray look in the car but the rest is nice. Ever do models? Looks very similar to many techniques used on armour.
If you build a frankenpanel, chances are I don't care for you as a person.
kspiff
  • Last login:February 02, 2016, 09:15:36 pm
  • Love of the game, baby.. love of the game..
« Reply #20 on: September 21, 2003, 05:19:48 am »
I was thinking that, too, but I think those might be clear plastic floor mats.. just catching light..?
k-spiff
said7
    • www.said7.com
« Reply #21 on: September 22, 2003, 08:25:29 am »
Nope they are diamond plate.
The odds of me getting decapitated by a floormat... ill take my chances.
The floormats are for car shows. I dont use them all the time because i dont want to scuff them with my shoes.
pathdoc2
« Reply #22 on: September 22, 2003, 03:45:54 pm »
I love diamond plate.  I've even considered making portions of an arcade cab out of it.  Again nice work.  The light coming from the bottom of the cab is another nice touch.  If you added some small wings your cab would almost look like an aircraft of some sort.  Could be cool.
said7
    • www.said7.com
« Reply #23 on: September 23, 2003, 09:27:57 am »
Thanks Pathdoc
Diamond plate is awesome but it is very difficult to cut. I was thinking about the wing idea when i started but i figured it would look less bulky without it.
I really think my CP and marquee art is gonna make the cab. Now if i can just get to it.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #24 on: September 26, 2003, 10:55:53 am »
Good job man... I knew when I saw some of your car mods originally you were gonna come up with something cool...
Rampy
said7
    • www.said7.com
« Reply #25 on: September 26, 2003, 12:23:18 pm »
Thanks Rampy.
You were very helpful when i was trying to figure everything out.
Just to update...
Picked up some smoked plexi from Lowes and im gonna try and put that on this weekend. Still debating velcro or screws to hold it down on 1x1s screwed to the inside. Any ideas? I should also be getting my speaker grills, piano hinge, and latches this weekend.
And I actually started working on my CP art but im still far away on that :(
