Author Topic: SlikStik Quad Programming Files  (Read 3547 times)
PhoneLine
  • Last login:January 26, 2017, 07:24:08 pm
  • Keyboard Error. Press F1 to continue.
« on: November 23, 2011, 12:52:06 pm »
Hi all,
Does anyone happen to have the IPC and CPL files for the SlikStik Quad in order to reprogram the controller back to its default settings via the WinIpac software?  I did some searches and find the manual and the mame controller cfg files, but have not had any luck with the IPC and CPL files.  Or I'm not searching correctly, but appreciate any help if anyone has them.
Thanks,
James
pyract
  • Last login:August 02, 2025, 03:08:54 am
    • Pyractyc N-Axticide
Re: SlikStik Quad Programming Files
« Reply #1 on: December 02, 2011, 02:49:31 am »
Not sure if this will help, but here's all the Quad files I could find on my old SlikStik cd.
Hoopz
  • Intellivision Rocks!
« Reply #2 on: December 02, 2011, 12:04:40 pm »
If those files don't work or aren't what you're looking for, Slikstik still sells their CPs under a different name or through another vendor.  I can't recall who it is right now though.
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #3 on: December 03, 2011, 07:03:46 pm »
I think its mameroom, but he just took their panel design, I dont think its exactly the same.
My Websites
Hoopz
« Reply #4 on: December 03, 2011, 07:14:22 pm »
I thought someone had the balltop LED joysticks and other stuff.  Not just designs but the actual products.  I've tried to find it without luck so I may be off.   :dunno
I was pretty sure though but I can't find it so who knows.
Gray_Area
  • -Banned-
  • -Banned-
-Banned-
Hoopz
PhoneLine
« Reply #7 on: December 14, 2011, 11:40:35 pm »
Thanks guys, these files and links help much!
