Author Topic: Vertical glory  (Read 3421 times)
Nightfalls
  • Last login:December 01, 2003, 11:47:26 am
Vertical glory
« on: September 16, 2003, 04:18:37 am »
I have no words to describe the feeling but I will try. Yesterday I had the most outstanding experience I've ever lived with videogames: I played MAME's vertical games with my TV rotated, and of course using native res with RGB cable and ArcadeVGA. I felt absolutely amazed and shocked about the incredible difference between playing these games in a horizontal monitor and using a vertical screen. All the graphics look so large even if your tv/monitor is a 20' as the unit I used. I had previously used my 17' pc monitor in vertical position for playing these games, but using a TV/Arcade monitor is 100 times better, not only for the extra size but because of the perfection of the display, which is in fact the perfection of the real thing. Games are even more playable and easy (specially vertical shooters) and you see and feel the action on screen much clearly. I was a big fan of vertical shooters before, specially the most modern and spectacular ones, but now my vision of them is even much better. Playing Strikers 1945 II, Dodonpachi, Varth, Dragon Blaze, 19XX... it cannot be compared to anything else, neither in playability nor in capability to amaze the player. But of course you have to play them with the right hardware and with the right orientation. I used my TV on my desk, inclining it a little. For the controls, an Arcade control panel with a T-stick. For audio, headphones. Lights out, and let the experience begin! :D The cons is that from now onwards I
SirPeale
  • Green Mountain Man
Re:Vertical glory
« Reply #1 on: September 16, 2003, 03:34:01 pm »
Okay, I got two sentences into this before giving up.  Think you could edit this and place some paragraphs in there to break things up?
Dr. J
  • Last login:November 26, 2004, 05:53:01 pm
    • DrJsArcade Cabinet
Re:Vertical glory
« Reply #2 on: September 16, 2003, 04:03:31 pm »
LOL!  I did the same thing.  I got two sentences through and skipped down to your response and cracked up.
Nightfalls
Re:Vertical glory
« Reply #3 on: September 16, 2003, 04:34:09 pm »
No need for paragraphs.
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
Re:Vertical glory
« Reply #4 on: September 16, 2003, 05:58:34 pm »
you'd be surprised.
There is SO a spoon.
zero-one
  • Last login:December 17, 2003, 10:30:04 pm
  • Still learning...
Re:Vertical glory
« Reply #5 on: September 16, 2003, 06:07:33 pm »
Paragraphs in text is like playing a vertical game on a vertical monitor. It's the way it should be.
Having suffered through reading your post I must say that I aggree with you. Vertical games on a vertical montor. My cab will have a rotating monitor.
SirPeale
Re:Vertical glory
« Reply #6 on: September 16, 2003, 06:17:26 pm »
No?
Nightfalls
Re:Vertical glory
« Reply #7 on: September 16, 2003, 06:24:25 pm »
Can anyone answer about the problem with MAME not running games when I have my desktop displayed vertically? And what about the issue with the mouse rotation?
zero-one
  • Still learning...
Re:Vertical glory
« Reply #8 on: September 16, 2003, 06:36:50 pm »
Nightfalls,
You should thank Peale. Now people will be able to READ your questions in the second last paragraph and possibly answer them.
Alas, I have no answers for you but I would greatful for the answers as well.
Cheers.
SirPeale
Re:Vertical glory
« Reply #9 on: September 16, 2003, 07:49:27 pm »
Sort-of answer:
Instead of rotating everything, run the games with the -ror or -rol flag (depending on which way you turned your monitor.  If you're running MAME32, then make the option for clockwise or counter-clockwise under Options --> Default Game Options (or right click each game and make the changes that way)
Of course, that will make Windows not look right, but that's what front ends are for.
paigeoliver
  • Awesome face!
Re:Vertical glory
« Reply #10 on: September 16, 2003, 07:53:56 pm »
That sentence seems quite funny when taken out of context.
Nightfalls
Re:Vertical glory
« Reply #11 on: September 17, 2003, 03:20:55 am »
I don't need to configure MAME to rotate vertical games because I'm using the new AVRes utility which creates inis for every game and automatically adds ror 1 to all vertical games. The problem is that if you use windows horizontally, MAME gui is also displayed horizontally and the mouse axis aren't rotated, so it's impossible to select games etc. If you set windows to be viewed vertically, MAME32 doesn't load games, at least in my case. The solution I have right now is to use Joytokey, emulating mouse or keyboard with my Arcade joystick. It can be configured so that when you move the stick right, the mouse cursor moves up, etc
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Vertical glory
« Reply #12 on: September 17, 2003, 04:13:13 am »
Why?
Re:Vertical glory
« Reply #13 on: September 17, 2003, 07:30:36 am »
Why?
To make sure every game uses the correct native resolution (when possible).  MAME's 'resolution auto' does not always do this.  The utility can also be used to set what happens to medium res etc. games (with > 288 vertical lines).
Re:Vertical glory
« Reply #14 on: September 17, 2003, 07:36:06 am »
My advice to you Nightfalls is this:
1) Ditch MAME32
2) Download/setup Windows Commandline MAME
3) Get a cab FE (so no mouse required) which can rotate the screen / work with vertical resolutions
FWIW my FE cannot rotate the screen directly, but using the AVGA's rotational feature combined with a custom vertical layout, it would work...
I am not 100% sure which other FE's can work vertically...from memory EmuTron and...??
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
Re:Vertical glory
« Reply #15 on: September 17, 2003, 08:59:39 am »
As far as I remember Game Launcher had a switch for this, too - though I'm not sure if it supports rotation on the fly.  ???
My frontend supports rotation (even motorized with some special hardware), but is in beta and not yet public available.
SirPeale
Re:Vertical glory
« Reply #16 on: September 17, 2003, 09:55:20 am »
Gamelauncher and ArcadeOS both work vertically.
