Author Topic: Choping edges of TV to fit in cab  (Read 2133 times)
megaarcadeuser
  • Last login:October 31, 2011, 04:50:37 pm
« on: October 31, 2011, 04:50:37 pm »
Hi all,
I'm considering sawing off the plastic case edges (~1 inch per side) off a TV that is slightly too wide for my cab instead of de-casing.  I plan to first drill a hole and look inside to make sure I don't cut anything that isn't plastic.  I will leave the TV off for 24 hours before attempting this.  My questions are:
1. How dangerous is this?  (Do I need to worry about the same issues you need to think about when completely decaseing a tv?)
2. How safe is it to leave a TV without sides in my cab?  (Do I need to cover them with plexi or another material?  Could this burn start a fire, etc?)
Thanks,
  • Last login:December 02, 2025, 03:23:14 pm
Re: Choping edges of TV to fit in cab
« Reply #1 on: October 31, 2011, 04:55:16 pm »
1.  You're gonna die.  I hope you write a will before you attempt this.
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #2 on: October 31, 2011, 05:17:46 pm »
Hi all,
Thanks,
All I can picture in my head is someone taking a sawzall to their TV and it getting ridiculously out of control. Why not just decase it? What I picture you doing in my head seems much more dangerous then just taking off a few screws and lifting the plastic off.
« Reply #3 on: October 31, 2011, 05:20:22 pm »
+1
why not take the screws off, take the back cover off, and see what you can trim?
Jack Burton
« Reply #4 on: October 31, 2011, 08:21:20 pm »
Just get a different TV.  There are some models out there than aren't much more than a couple of inches wider than the tube itself.  That's more than enough to fit properly inside any cabinet.  If it still won't fit then you probably just need to get a smaller display.
AlienInferno
« Reply #5 on: October 31, 2011, 09:16:40 pm »
I agree with these guys.  Would probably be safer to decase it.
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #6 on: November 01, 2011, 05:40:20 am »
but if you still do it anyway, use a Sawzall and post a video of the process (:
« Reply #7 on: November 04, 2011, 02:43:23 pm »
I think the OP might be dead. so sad.
newmanfamilyvlogs
« Reply #8 on: November 04, 2011, 06:24:25 pm »
Does that make us responsible for goading him on? D:
He logged into Hyperspin forums earlier today :P
http://www.hyperspin-fe.com/forum/member.php?u=43414
