Author Topic: What are the Benefits of smoked plexi  (Read 9629 times)
Mrephunk
  • Last login:July 17, 2012, 12:56:47 am
« on: October 27, 2011, 01:09:51 pm »
I am wondering what the benefits of smoked or tinted plexi are for an arcade cab monitor.I am at the point in my build where I need to purchase the plexi that will go over my monitor and have seen it used alot here but am wondering why? I am using an LCD monitor and have made a custom bezel art for it.My plan was to put the bezel art behind the plexi so can I even use smoked plexi?
Re: What are the Benefits of smoked plexi
« Reply #1 on: October 27, 2011, 01:30:23 pm »
If you want smoked plexi and bezel art, sandwich the art between clear plexi and smoked plexi. thefearsomefearful posted a good comparison pic in his last build thread, smoked plexi makes the image look better IMO.
« Last Edit: October 27, 2011, 01:37:34 pm by Nephasth »
Mrephunk
« Reply #2 on: October 27, 2011, 04:46:03 pm »
I can see what you mean about it looking better but what if the games I plan on playing are new like the new street fighter or mortal kombat
Mrephunk
« Reply #3 on: October 27, 2011, 05:25:49 pm »
Also is 1/8" plexi thickness good enough or should I really get the 1/4"?
Vulgar Soul
  • Last login:October 23, 2015, 07:48:57 pm
  • Make Some Noise!
« Reply #4 on: October 27, 2011, 05:37:34 pm »
1/4" is a bit overkill. Most cabinets used 1/8" plastic.
I'd also love to see some examples of tinted plexi cabinets!
« Reply #5 on: October 27, 2011, 05:43:11 pm »
There's The Armoircade. Smoked plexi looks good on it too.
« Reply #6 on: October 27, 2011, 05:54:47 pm »
Smoked plexi gives you better contrast between lights and darks.
Blacks look darker, lines look clearer (without that monitor fuzzy blur from the lit phosphors), and colours tend to "bleed" less.
It is also great for hiding your monitor shroud, and gives the image a floating feeling.
This is great for 2D sprite games, but if you're playing 3D games like the Street Fighter 4, then smoked plexi won't help much there.
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
« Reply #7 on: October 27, 2011, 07:21:53 pm »
Which cabinets are those? I thought 1/4" thick was standard. It would seem that anything less than that would flex too much.
Darren Harris
Staten Island, New York.
« Last Edit: October 27, 2011, 07:23:51 pm by D_Harris »
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
Vulgar Soul
  • Make Some Noise!
« Reply #8 on: October 27, 2011, 08:19:50 pm »
Darren Harris
With exception of Cocktails, I don't think I ever saw a cab with thick, window-like glass. Always thought most cabs had jus a thin 1/8" glass cut to size of the monitor area so it cant bend or flex. I could be wrong.
And shout outs to Shaolin!  :cheers:
« Last Edit: October 27, 2011, 08:21:22 pm by Vulgar Soul »
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #9 on: October 27, 2011, 08:30:39 pm »
It also hides minor screen burn in.  You have a new system and not an issue; however, it is not uncommon for someone to remove a monitor from a tinted cab to find screen burn they never knew existed.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #10 on: October 28, 2011, 12:31:01 am »
I have it on my cab, it hides the bezel really well, makes the whole thing look more sleek and polished
mgb
  • North East, US
« Reply #11 on: October 28, 2011, 09:59:31 am »
I agree that the smoked plexi makes the picture pop nicely with good contrast. It also makes it easier to look at, reducing glare. I just installed solar gray 1/8" plexi from Tap Plastics and I love the way it looks.its like tinted windows on a car.
Every game I have worked on seems to have 1/8" thick plexi. Sometimes I think the actual glass ones may be 3/16".  I say go with 1/8" because its cheaper and more readily available.
I definitely agree on the hiding screen burn mention. I have had monitors with minor screen burn and I didn't even realize until I removed the tinted glass.
Mrephunk
« Reply #12 on: October 28, 2011, 12:07:29 pm »
has anyone used this http://www.tapplastics.com/shop/product.php?pid=515&PHPSESSID=201110272252002053991728
It says it is glare free, would that be any good to use? And if I do go with smoked plexi I would need to sandwich a piece of clear on top over my bezel art, would the two doubled up affect the image?
Savannan
  • Last login:December 22, 2012, 10:53:06 pm
« Reply #13 on: October 28, 2011, 12:36:21 pm »
I never had smoked plexi glass but I have 1/4" greylite 31 glass on my mame cabinet and I'l never go back to standard glass again with my arcade machines.
Jack Burton
« Reply #14 on: October 28, 2011, 12:38:54 pm »
Every cab I've owned has come with 1/4" glass.  Not plexiglass.
That's
Mortal Kombat
Super Chase
Ms. Pac Man
Super Pac man
Rampage
I had a little Sony PVM monitor that had a smoked glass covering over the screen like this:
The image on it was amazing.  Black backgrounds in games were a deep solid true black compared to a duller grey without the tint.  It also helped the colors quite a bit.
I did play more modern games on it too.  My favorite game of all time is Super Street Fighter II Turbo, and I have seen that game running on every setup you can imagine.  The best I have ever seen it was on that little pvm through the smoked glass.
« Last Edit: October 28, 2011, 12:43:37 pm by Jack Burton »
Mrephunk
« Reply #15 on: October 28, 2011, 01:12:45 pm »
If I do double up the plexi for the bezel art will the double up affect the image? Or would it be better to adhere the art to the outside of the plexi and not sandwich it?
« Reply #16 on: October 28, 2011, 01:48:43 pm »
No.
Don't put it outside the plexi.  Sandwich it between the clear and the smoked. This is kinda obvious, no?
Mrephunk
« Reply #17 on: October 28, 2011, 03:03:56 pm »
I mean if I didn't buy the clear and only the smoked. My bezel art has an adhesive backing
Mrephunk
« Reply #18 on: November 03, 2011, 12:56:55 pm »
I know most of my questions have been answered but I have 1 more. I am going to be playing newer 3d games like the new MK and SF but there are also a whole slew of old school games to play on xbox live arcade. So my question is would the smoked plexi hinder my newer 3d gaming? If it doesn't I would get it in order to improve my Old School games
RandyT
  • Last login:September 29, 2025, 06:30:20 am
    • GroovyGameGear.com
« Reply #19 on: November 03, 2011, 01:21:44 pm »
It probably depends on the type of game.  I wouldn't go as far as to say that it would "hinder" anything, but you may wish to increase the gamma on 3D games where this is an option.  Otherwise, you may lose some of the darker details in the 3D imagery.  Most will crank up the output of the monitor a bit to compensate anyway, so you will likely just end up with enhanced contrast for those titles as well.
