Author Topic: pga golf vr-gobal  (Read 219348 times)
ed12
Re: pga golf vr-gobal
« Reply #840 on: January 19, 2013, 11:50:50 pm »
hi
ok i have had it with dropbox
it wanted 55 min's to up-load a 200k file ? freg that crap
here is a walk through,this will run u straight up to sp3
get any fresh windows xp box by fresh i mean with NO other running program's in it
expect window's xp..not a tall order
next we plug in a usb stick,again not a tall order
next we copy c:\window's\system >complete< name it as such so u do not get confused,
next we copy c:\window's\system32 >complete< name as such
so now u have to file's on your usb stick system and system32
now we plug stick into back of pga machine,
and as per my insturction's on how to bust the pga into window's
we go look for the usb stick it should show up as e:\
open it
copy e:\system to c:\window's\system,same apply's for system32 so c:\window's\system32
remove stick
colse out windows session as per my insturction's..
reboot pga,bing bang boom u are going to get a screen that say's it want's to load in 97 update's,tell it no not at this time,then go to window's update through ie set to ASK and COUSTOM,so u can pick and chose..DO NOT DOWNLOAD IE8 OR U WILL MESS THE PGA UP BUT GOOD,now BEFORE U DO ANY OF THIS COPY YOUR CURRENT PGA.IMG TO A CDROM,so u have it as back-up
now with this in hand u have a box,that once u follow the upper step's will report back to
window's sp3..u are now running all current window's dll's expect a few,that we can add at will,to chk your system bust down to window's as i explained,open control panel,go to system,double click system
your 2002 should be gone and replaced with verision 2010
sp3
your key should not have changed,if it did all is not lost,i can send u market-relm
it is a key changer
if u did the proper step's as i out linded and did not become a hero..u can now fully play with the pga..enjoy
and btw i fuc#king hate dropbox
ed
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
« Reply #841 on: January 19, 2013, 11:54:48 pm »
I will try this tomorrow. What's next on the agenda?
Sorry you are having such difficulties with Dropbox. I've never had any issues personally.
« Last Edit: January 20, 2013, 12:55:59 am by stpcore »
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
ed12
« Reply #842 on: January 20, 2013, 01:51:46 am »
hi
it's windows doing it
pm me your e-me again
i will send u what we require
can keep them under 1gig so they should fly through
ed
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #843 on: January 20, 2013, 03:23:18 am »
Hi Ed you have been very busy. Now this walkthru explained above what does this do? Unlock all the goodies in the game? Or something different please explain? As don't want to tamper with working PGA all access areas machine just yet for no real gain. Thx mate
Spitfire
Spitfire
« Reply #844 on: January 20, 2013, 03:36:05 am »
Hi Stp,
My card reader is just plugged into a USB point at the back of PC which supply's the 5v it needs to run. Should be a simple plug n play on team challenge machine. I do have a dedicated 4 port USB card on my pc which it plugs into not the motherboard USB points. There is also a card reader test in the actual game settings which u can try to see if that helps.
Thx Spitfire
stpcore
« Reply #845 on: January 20, 2013, 10:24:41 am »
Hi Stp,
Thx Spitfire
Same thing with my card reader but I have 2 USB ports toward the top and 2 on the bottom.  I've tried each port.  It doesn't do anything during the card reader test either as I tried that originally.  So I'm hoping that the drivers need to be reinstalled as Ed is suggesting.
Also, I think that the USB loading that Ed has posted above is simply getting a running PGA on XP SP 3 so that when it hooks into the bot or he gives us additional code everything else will be unlocked.  I don't see how this could unlock anything as is.
ed12
« Reply #846 on: January 20, 2013, 02:12:44 pm »
hi
i shot a e-mail off to the @ in question
once i get the name again i will open an account
and we can run with it
the fact both card reader's not working in the pga but in normal window's lead's me to believe that the driver's have been kicked out,the 4 port usb board
is for usb 2,this olny allow's to increase the speed of the usb crap
as the mobo's in these box's are all usb1,the 2 make's it that much more robust
but for pga's running 512k ram,it really dose not matter
u would never knotice the lag..unless u are doing speed chk's?,and at that point i would have to say 1.7gig micro and 512k ram..wtf are u thinking?
so in short u CAN ditch the usb2 card and go back to the native usb1
rember the i/o plug's into 1 of the usb1 port's
it can be lopped back into the usb2 port but then again i go why are u strapping driver's into this box u do not require ? myself on the other hand open the resource's of the box up,pull the dial-up modem..dam that is hound
keep the audio board OFF board,free it up even more
ed
ed12
« Reply #847 on: January 20, 2013, 02:33:33 pm »
hi
i got the reply from the @ in question
mediafire is the site
i will reg this afternoon
so we can get this show on the road
right now i am out on the road to get some part's
but rem i am off tommrow so we got time
ed
ed12
« Reply #848 on: January 20, 2013, 08:59:29 pm »
hi
ok once it allow's me to create the account
the show goe's on the road
thk's in advance for your pantice
the first file up will be properdll's
they are your system32 dll's
then i will upload system file's
this should fix most problem's
with a little help from window's
also i will put market-relm up there for good mesaure
if a exe is needed i will need to know
NOW once u get the file's d/l they are zipped
so u will pul them in on your home putter
and unzip them to your usb stick
then follow what i laid out
1 set of file's at a time
no need to get in a hurry
ed
Spitfire
« Reply #849 on: January 20, 2013, 09:42:54 pm »
Hi Ed,
I have cloned my Pga HD so good to go as instructed. Has anyone attempted the walkthru and if so how did you go? Can't wait to get this game online again and play against u lovely people ha ha.
Till then.
Thx Spitfire
ed12
« Reply #850 on: January 20, 2013, 09:59:07 pm »
hi
very good spitfire u got a clone :):)
now u have no fear's mate
the dll's will cause no damage as they are all navite window's xp spk3
the olny dif now is when u use your pga to go on line it will be a ---steaming pile of meadow muffin--- load easier
+ u can go get hk-patch's
which u cannot do right now
and also u can now kill resource's at will
handy when u want to do edit's and such
plus u can run if need scan's to chk for maleware and such nastie's
which u cannot do with xpe
NOW  it did dawn on me gvr is going to be the file we need to edit the most
i will whip up a walk through and patch for u ppl once mediafile is running right
the reason for this is hercule's and gvr work toghter  hand in hand as it is,
so to put it simple if we kill a cmd in hercule's we need to kill it in gvr
as the system run's on gvr
to prove it
bust to window's
u will see the left hand scroll bar
colse gvr
open gvr
that stand's for gobal vr,
which btw has a stupied set of encoded 3d file's.
so u never get to see the mpeg's etc
which we are about to fix,as that .co in question will not play in my sandbox with me
ed
ed12
« Reply #851 on: January 21, 2013, 12:22:05 am »
hi
MOD'S  stop editing my post's
if i cus it is because it is the context of the fregging txt
knock it off please
if u are worried about someone taken offince i will deal with it
ed
stpcore
« Reply #852 on: January 21, 2013, 12:25:01 am »
I don't think anyone is editing your text. In your user settings you can change the option to see all words as typed or substitute words will be assigned automatically for cuss words. Adjust your forum settings, Ed.
Spitfire
« Reply #853 on: January 21, 2013, 04:19:18 am »
Ha ha ha Ed I hope ur not finally losing it mate. Hold it together for a few more days mate it seems we are so close to the holy grail. Lol awaiting ur instructions.
ed12
« Reply #854 on: January 21, 2013, 12:32:28 pm »
hi
ya it could have been me lol
anyway's i chatted the @ about mediafire,and i am not the olny person having that issuie,so the @ thought ftp or ptp might be in order,so i d/l both piece's
after lunch i will put them in pga bot,and see what happen's
talk about pulling out your hair >which btw i do not enough of anymore<
ed
ed12
« Reply #855 on: January 21, 2013, 12:54:00 pm »
hi
ok i am moving them now
let's see where this 1 goe's
ed
lilshawn
  • Last login:Yesterday at 05:55:53 pm
« Reply #856 on: January 21, 2013, 01:32:51 pm »
yes there is a filter you can enable and disable. If you typed "B 4" (without the space) instead of "before" in your post it gets changed to "bingo!" and "s--t" (the poop expletive) gets changed to "meadow muffin" things like that.
you can go into your profile "look and layout" and set the "leave words uncensored" to on and your post appears normal. (by default it's censored)
sorry it's a little funny seeing people freak out about it getting changed since your posts appear normal to me, and i'm like "wut?!"  ;D
don't worry, it's happened a few times that iv'e seen now. your posts are going through just fine.
ed12
« Reply #857 on: January 21, 2013, 01:38:53 pm »
hi
yes i kinda caught that afer the fact :) but thk-u for pointing it out to me
more interesting new's pga-bot is now going viturial
the ftp is in i just need to add name's and permission's
i think i need to put in client also ?
i will chk
if all goe's well i will post the how and way
ed
stpcore
« Reply #858 on: January 21, 2013, 01:39:39 pm »
Let me know if I can help in any way. Thanks, Ed.
ed12
« Reply #859 on: January 21, 2013, 02:06:34 pm »
hi
my ip is assinged
it should be 14147 easy 1 for a start
if i find to many or much traffic i will find a cleaner port
let me work the kink's out
thk-u @ for pointing
thk's for the offer stpcore if i get into trouble i will
def ring your bell,if u do not mind?
just want to get the show on the road
ed
Spitfire
« Reply #860 on: January 21, 2013, 09:11:07 pm »
Hi Ed, sounds great mate just point us on what we need to do our end. Can't wait to get things up and running.
Thx Spitfire
ed12
« Reply #861 on: January 21, 2013, 09:18:47 pm »
hi
spitfire and crew your end's are easy u just need client control
which u can shut down at any time
i am just shoving it into my test pga now
the server was the dog
ed
stpcore
« Reply #862 on: January 23, 2013, 01:53:44 pm »
How are we looking at this point? Anything new to share?
Spitfire
« Reply #863 on: January 23, 2013, 09:11:04 pm »
Hi STP have u tried the win xp sp3 upgrade yet? N if so how did it go?
stpcore
« Reply #864 on: January 23, 2013, 09:13:47 pm »
I have not tried it yet. I want to see if it is worth it to do at this point. Not sure what Ed is planning so I prefer not to mess anything up until I can see everything through. Not sure if that makes sense how I explained it!
stpcore
« Reply #865 on: January 25, 2013, 02:08:19 pm »
Does anyone happen to have the full drivers for the card reader? I haven't had any luck finding them on my own. Thank you.
Spitfire
« Reply #866 on: January 25, 2013, 09:35:45 pm »
Can Dropbox my system files for u if that's what's needed? As my reader works
Perfectly.
stpcore
« Reply #867 on: January 26, 2013, 10:36:06 pm »
Perfectly.
Thanks. Ed said he had the drivers but I haven't heard back from him in a while. Don't even know where they are supposed to go and I don't feel like reinstalling if I don't have to.
Seems like we are derailed here again. Every time it seems we are gaining momentum we stall out! We need Ed to go on strike with his full time job for about a week so we can just get this done and over with once and for all. What do you say, Ed?
Dirt...Ed fixed and installed his code on your machine, right? Are you unlocked and waiting for the rest of us? Please share with us as Im curious how its working on your end.
ed12
« Reply #868 on: January 27, 2013, 12:01:36 am »
it's nothing
i hooked pga bot on line and had to re-reg
stand down for the love of the lord
dirt i will look into it
explained to u i am listed by your :home-land: crap,what a joke they are
the dll's as i pointed out are olny window's :sp3:
if u have a clean box..clean meaning u just loaded in window's >xp<
copy them to a usb stick >thumb-drive< >ram-stick< call it what u may
place them into to there proper folder's,system/system32
nobody should have any real problem's,that u cannot :walk: around
the start/play button is your best friend
for the ppl locked out of turney
u will want to copy the next patch i post
AND PLACE IT EXACTLEY WHERE I TELL U TO
it's about that simple
and not really that hard
this is :window's: after all
not rocket stuff
now yes they made me re-password
some one is in a pms mode.....go fig
this to shall pass
but to attack me..is beyound any or all responiable belief
media fire  suck's
sorry @ but that is the way i c it
dropbox about the same
u ppl HAVE TO UNDERSTAND i use this box to CODE with...
AND I AM VERY FUSSY ABOUT REG,PERMISSION'S
to the point where i never use IE for my e-me's
i go in through firefox
ed
stpcore
« Reply #869 on: January 27, 2013, 03:12:18 am »
it's nothing
not rocket stuff
this to shall pass
media fire  suck's
ed
I really don't have any idea what this all means.  :dunno
I wasn't attacking you, Ed. If this process is so easy why is it so difficult for us to be able to participate?. I know you are volunteering time for this project and we are all appreciative of that but when expectations are set, people (including myself) start to count on those expectations.
Im not trying to come off as rude, impatient, or ungrateful here but online play, character and course unlock, along with the dongle bypass have been sticking points for all of us for months with no real end in sight as far as I can tell. I can't speak for anyone but myself but the reason I keep asking you about these things is simple...because you said you've done it...and we will be able to as well.  When you tell me that its easy, it gets me eager to move forward. I've read this entire thread countless times and the progression stops and switches direction almost every time we are on the cusp of something major.
If you are just stuck for some reason...just say it as Im sure we could all understand.  I'm thinking that buying the damn All Access would be easier at this point (hahaha!),
I've received a lot of help from this forum and I've tried to offer help here and in additional threads in any way that I could. If ultimately we stay at a standstill with PGA then that's OK. I can honestly say that I've made some friends here (especially you) and Im happy for that.  If we get a chance to play each other online, unlock a course/player or two, awesome! I would only ask that you set realistic expectations so that I'm not disappointed at the conclusion of this very long endeavor.
Spitfire
« Reply #870 on: January 29, 2013, 08:51:14 am »
Hi All,
Just back from our Australia Day long weekend holiday and glad to see not much has changed. Ha ha ha ha oh well thx for the laugh anyway. I hope it gets back on track in the near future.
stpcore
« Reply #871 on: February 01, 2013, 04:58:31 pm »
So is this the end here? Anyone else wanting to try to move forward?
ed12
« Reply #872 on: February 01, 2013, 11:15:31 pm »
hi
i am here
just had a few bad week's with the boss >biatch<
so mind my temper
button pushing right now is not a good idea
take the drift from the point
99% of the code is done and proffed
U PPL WILL BE UPDATED AS I GO
EASY AS THAT,relax play your game's
ed
Spitfire
« Reply #873 on: February 03, 2013, 03:59:05 am »
The beast has awoken! Ha ha sounds good to me Ed ill be playing away waiting for ur next update.
Cheers mate
ed12
« Reply #874 on: February 03, 2013, 01:25:02 pm »
hi
spitefire it is
i just chatted him today on the phone
he asked me why i did not answer to his service call request's?
i replyed u do not come in on wed's and tell 2 ppl they have until tuesday off
then turn around and expect them to do call's...some thing is wrong with that math
his reply was there is no budget for 2 ppl
my reply was simple..i will stand down,let the other 1 do the job
he went what do u mean?
i repeated my-self,then i added
it will just cost u double is all
make's no never mind to me:):)
now u know where my head has been at
the other proffer got back to me last night
i should have 100% lock and load code tonight or in the am..what ever his hour's are?
now rember i told u ppl make a .img of your running pga harddrive as a back-up
that is very very important
as this code over right's the full thing....
once loaded it will WILL hick-up and burb once
this is because we are running legacey board's
that was a hurdel to walk around
here is what is in the code
window's xp sp3
opti controller u can toss the other i/o board
u can toss the dial up modem >it will not look at it<
u can connect your on board lan
u no longer have fear of TROGAN'S/MALWARE..DO NOT ASK HOW I DID IT I WILL NOT RESPOND >PERIOD<
u no longer need the player's card,if u up-date..it's hard coded in to SAVE
IT will AUTO HOOK TO ME,WITH AN ASSINGED AND SECURE CODE..DO NOT TRY TO HACK IT OR IT WILL SHUT  DOWN
for u ppl to know PGA BOT HAS BEEN ON LINE LONG BEFORE X-MASS
i was just working detail's out with ROGER'S my isp provider
and testing with the other coder's
i will follow up with more
ed
Spitfire
« Reply #875 on: February 03, 2013, 09:54:55 pm »
Hi Ed,
All sounds good mate. Just to clarify by .img u mean clone the PGA harddrive is that correct?
If so this I have already done but nothing more.
Thx
ed12
« Reply #876 on: February 04, 2013, 12:33:42 am »
hi
spitfire that is 100% correct
u now have a back-up
the new s/w can and will like to be run from a usb stick
ie: u plug in the usb stick to the pga, game in q
power-game down/re-power game/break into BIOS-SETUP
FIRST BOOT DEVICE :>OTHER<:/save
if your board is of newer gen?
it will see it then USE USB AS FIRST BOOT DEVICE.
if not u may need to spec it.
IF NOT IT IS A OLDER GEN BOARD ? this is where the code tie up is
I AM TESTING THIS IN THE AM..I WANT THIS SEEMLESS
IE LOCK AND LOAD GO PLAY..
to recap i olny have a few kink's to get over
player's/read-card player's once or not at-all >for info olny<,as the new code will not even look for the reader after first load,ie u load code re-boot,it will seek all out board device's,load into it's ref libary the stuff from let's say card reader
then on second boot it will no longer look for it
it is all in a .lib file
WINDOW'S XP SP3 no INDEXING IS ALLOWED
if u need to change the video card
u no longer need to point gvr/hercules
niftie little up-date >olny took 2 year's< thk-u un-named..that's the coder btw
the second it load's up
u will see it search for a server >LEAVE IT ALONE<
it will tie to >PGA-BOT<
this is all in a 8gig usb stick
it will self extract
let me dust some garbage up
and away we go
ed
stpcore
« Reply #877 on: February 04, 2013, 12:48:59 pm »
Ed, will everyone have to be playing Team Challenge to tie into the bot? For instance, if someone is running Challenge and not Team Challenge will they need to find a dongle and upgrade to Team Challenge? Also, will there be additional courses and players or is this for online tournament play? Thank you.
ed12
« Reply #878 on: February 04, 2013, 01:15:36 pm »
hi
any challange can get in and share
it of course must be :gobal-vr:
but aside from that there good
a little up-date
i found a hole in the code
so i sent it back to un-named with the patch
to be tech
the hole would allow for maleware/trogan's
it came in under a > h-key value<
so as i said i sent it back for a patch with the re-write code
this should not take long
ed
ed12
« Reply #879 on: February 04, 2013, 01:22:28 pm »
hi
i did forget to add this part in my last few post's
WITH THE NEW CODE U NO LONGER NEED THE DONGLE
as it was used for CID/RID i got rid of it
let me get this hole patched up
ed
