Author Topic: pga golf vr-gobal  (Read 237707 times)
ed12
Re: pga golf vr-gobal
« Reply #320 on: August 16, 2012, 04:19:44 pm »
hi
yes that should be fine
u come of the pga using the main lan onboard of the mobo
if u want u can tie it in at any time
and if i can explain sharing (unless u already know),it is a tad different on these
critter's
ed
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #321 on: August 16, 2012, 07:58:23 pm »
Hi Ed that's good to hear that setup is
Ok. How long till we can get this working?
Can't wait to teach u a golfing lesson Ed ha ha
Thx Joe
CVN53
  • Last login:December 24, 2013, 10:33:27 am
« Reply #322 on: August 16, 2012, 09:28:11 pm »
Hi Ed
 I had to order a 37 pin connector those are very rare, just let me know when your ready with the 6200 card.
Thanks CVN53
ed12
« Reply #323 on: August 16, 2012, 10:08:06 pm »
hi
cvn53
i get card in morning
it came to onwer of company today,have pga on side so i can better walk u through it..
spitfire
go to your bios of pga
do this by re-booting and hitting delete
go to advanced
find >lwake-up-on-lan<  :enable this please:...
dirt
go to bios
advanced find the >usb on control<
enable it please
plug card reader back in all should be good
ed
ed12
« Reply #324 on: August 16, 2012, 11:01:06 pm »
hi
cvn53
that conecter is old centronic's cable if i rem right
u just go to a salvage shop drop your 10 cent's and get 1
cut off the centronic's end
and wa-la we have our conector
ed
CVN53
« Reply #325 on: August 16, 2012, 11:15:29 pm »
Hi Ed
no salvage shops in this area
CVN53
ed12
« Reply #326 on: August 17, 2012, 12:20:36 am »
hi
cvn53
dang
ed
cgriffinb
  • Last login:March 06, 2013, 01:16:35 am
« Reply #327 on: August 17, 2012, 12:52:31 pm »
Hey Ed,
Were you ever able to upload all of the courses that you mentioned last month?
Sincerely,
Griffin
ed12
« Reply #328 on: August 17, 2012, 01:38:06 pm »
hi
cgriffinb
i cannot upload them
there far to big
but if u read through u will see where i am enabling
sharing,this will inculde allowing u to peek through my g:\ drive
it hold's all of the data
let me get our ausie folk's done first..
if u read the thread u will c the code set nessary to do it
as i realse it
some will be in copy/paste/edit at will
some will be .zip-driver's as required
also i have spoken about bios setting's and what we need
ed
Spitfire
« Reply #329 on: August 17, 2012, 07:15:33 pm »
Hi Ed, I have changed the bios setting as requested. I hope things are close to working?
Thx Joe
ed12
« Reply #330 on: August 18, 2012, 05:23:26 pm »
hi
sorry forgot to .zip the file
my bawd
ed
« Last Edit: August 18, 2012, 10:33:50 pm by ed12 »
ed12
« Reply #331 on: August 18, 2012, 11:05:26 pm »
hi
i just looked over my last post
and what i wanted to tell u is not there
so let me try this again
firewall.zip is the firewall.vbs script
i have changed it to firewall.xvb
so u can edit on the fly in a window's shell
now u d/l winexp.zip it is the window's explorer script by dexter
i have used it for it seem's like a hundered year's
open the script go to tool's/ options
and turn on line #'s
once u open the script u will see where line's are commeted out
ie >>'<< just the '
this is where u do edit's in and out of
when u want to test the final script
rename it to reflect .vbs :ie firewall.vbs:
winexp will no longer see it but hercule's will
i will call the final name in a day or 2
in this attachment is sct10en.exe
this allow's winexplorer to run right
ed
« Last Edit: August 18, 2012, 11:07:20 pm by ed12 »
CVN53
« Reply #332 on: August 19, 2012, 12:34:46 am »
Hi Ed
Having any luck with that 6200 video card
CVN53
ed12
« Reply #333 on: August 19, 2012, 12:57:25 am »
hi
yes cnv53
i am putting it to .zip
need to ask a q
are u south or north border ?
as i have spare's for the header u need
u are welcome to a few free <my fav word>
ed
Spitfire
« Reply #334 on: August 19, 2012, 01:27:44 am »
Hi Ed, should I com ahead n do what u ask now or do I need to wait for any other files or instructions?
Thx Ed
Spitfire
« Reply #335 on: August 19, 2012, 06:55:23 am »
Hi Ed I have done as you asked and have the win explorer.exe file loaded on the c drive in its own folder n have the script line numbers on and can open the firewall file in it.  What needs to be done from here? Is this firewall file the replacement for the firewallenable.vbs file I edited previously? If so should replace it or does it need to be edited further n if so do I edit in in the winexplorer.exe file? Awaiting ur further instructions? I also have added an extra 256mb of ram to my machine that I had which I now have 768mb ram total.
Thx Joe
ed12
« Reply #336 on: August 19, 2012, 11:39:45 am »
hi
spitfire
yes that is the file
and can't go wrong with more ram
ed
CVN53
« Reply #337 on: August 19, 2012, 11:42:26 am »
Hi Ed
  I am in Washington State
CVN53
ed12
« Reply #338 on: August 19, 2012, 02:30:22 pm »
hi
cvn53
i need everyone to do as i ask in the setup stuff
once i invoke full sharing
u can peek in my g:\team\driver's\.dll's
and snag what u need
this will be alot faster,and easiser for u
and me also
ed
CVN53
« Reply #339 on: August 19, 2012, 03:57:27 pm »
Hi Ed
Have u already done the info for sharing or is that coming,that sounds good to me.
CVN53
ed12
« Reply #340 on: August 19, 2012, 04:50:23 pm »
hi
cvn53
yes most is done
as spitfire is waiting for it also
>he will be the first  to test the turnnie<
then u can all join in
my g:\team will be open for all to use
unless i need to reboot >not that much anymore<
but i will be ramming up for the extra load
have a 24/7 pga here which i will move to my wharehouse
and u guy's can have it
just sit back have a coffee or a beer >beer< for me,and just settle down u will see the .zip's,with the nessary info
ed
Spitfire
« Reply #341 on: August 19, 2012, 10:55:51 pm »
Hi Ed I will replace firewallenable.vbs With the file u sent me. Waiting for instructions on how to start these tournaments. Let me know if I have to change the firewall file in any way?
And what other files if any are needed to get these tournies working? Thx Spitfire
ed12
« Reply #342 on: August 19, 2012, 11:20:00 pm »
hi
spitfire do not replace yet
as i asked cvn53
we need to sit for a byte
while i get my pga here on the bench ready
i want this to be a seemless move for eveyone involved
detailed .ins are comming
u will see all the nessary .zip's
just packing them up now
u will be linking my real pga on line real time
i just need to decied where it slides into my server
ie >g< or >h< or ?
so i can point my software to it
your's and your bud's will be c:\pga >your pga box it's-self<
now this one has a even smaller window's xpe .ins set
so i may put it into the readme to have your mate's chk there machine's so
i can tell what to add in the system32 file system
ed
Spitfire
« Reply #343 on: August 19, 2012, 11:42:43 pm »
Hi Ed, no prob mate I will relax n have a few beers for ya n Play some 3way linked car racing as all configed now it great fun. We are all excited here to get this golf tournie going. Thx once again for all ur hard work. Thx Joe
ed12
« Reply #344 on: August 20, 2012, 12:49:18 am »
hi
spitfire i have a q for u
can all of the ppl get into the window's part of there pga ?
if not ask them to fire it up and hit >alt-f4 < if it goes to a screen that want's
a password i need to know asap
as they will be running under a reduced window's set
and i will need to do a un-lock disk
glad u are linked  with the driving machine's
i rem when i did my william's crusising usa
it was very fun..a few pop's and the mate's lol at each other
ed
Spitfire
« Reply #345 on: August 20, 2012, 08:26:05 am »
 Hi Ed alt f4 gives an option to restart. No password required. Let me know if anything else is needed.
Thx Spitfire
ed12
« Reply #346 on: August 20, 2012, 12:35:55 pm »
hi
no i found it spitfire
it is missing a file set
+ the ram is getting flackey
so i am going to change ram
i will upload the password fix disk ltr tonight
ed
Spitfire
« Reply #347 on: August 20, 2012, 09:35:56 pm »
Hi Ed that sounds great mate. Waiting for ur next instructions.
Thx
ed12
« Reply #348 on: August 20, 2012, 11:23:05 pm »
hi
well today went 50/50
turn's out i had a blown stick of ram and a blown cd-player
this dose not to be done right now
but before we turn on vpn
for our pourpse we will need to go to control panel
then we go to internet/connection's
and in the :vpn: window u will type the #'s i give u lrt this week
u will then turn on sharing
this is done to the pga's
as it is part of window's i cannot control off board
the program's will be up-loaded soon enough
have a usb flah stick
then u burn to cd >the olny way u can load it<
so when u burn the cd put a self boot track on it
load cd/shut machine off/turn machine back on with cd in
it will load the proggie's
then remove cd reboot machine :hard-boot:,u are now .net ready
ed
ed12
« Reply #349 on: August 21, 2012, 12:21:25 am »
hi
this file is olny for them whom want to turnnie
also open pga normal
go to setting's in the game menu
enable turnnie play
this file is a system32.dll file
i will explain more
u need to get pga to window's safe mode
>i will fix that problem child<
once there u should beable to load this file :once u un-zip it on your home putter:
DO NOT INSTALL TO YOUR PUTTER,this is olny for pga
copy it to a usb stick,plug stick into pga
it should see it
if not just place it on your main unit where u have the other pga stuff
once i am done up-loading the boat load of file's u need
we can burn to cd and auto-run it
this is your call
ed
Spitfire
« Reply #350 on: August 21, 2012, 04:18:46 am »
Hi Ed should the above file n instructions be done now or should I wait for the other files?
Thx Spitfire
CVN53
« Reply #351 on: August 21, 2012, 09:44:31 am »
Hi Ed
You mentioned you had spare 37 pin connector, is it possible to send one. If so I can PM my mailing address,if not I'll keep searching.
CVN53
ed12
« Reply #352 on: August 21, 2012, 04:12:48 pm »
hi
cvn53
yes i have a spare,will need to dig it out
from the warehouse tommrow
side note here for u
it just became your lucky day
nvidia is going to send me the nessary file's :with-out-there-installer:
the request is going to the eng dept now
ed
CVN53
« Reply #353 on: August 21, 2012, 07:12:10 pm »
Hi Ed
Thanks I PM my address to you,did you find it?That sounds great on drivers & dll's without the installer will be waiting for further instructions.
CVN53
« Last Edit: August 21, 2012, 07:13:52 pm by CVN53 »
ed12
« Reply #354 on: August 21, 2012, 07:49:36 pm »
hi
cvn53
i will open my pm in a byte
will dig up plug for u..as i said free
also side note
nvidia has set me up with a eng account
so thing's should move rather fast now
ed
ed12
« Reply #355 on: August 21, 2012, 09:09:35 pm »
hi
cvn53
here is the poop
what we have is a product winxpe >sp1< with olny limteded >sp2<
so we are going to be adding a wack of stuff,if u have a nvidia folder
in your pga,your doing good
if not make 1
this attachment is directx 9c it is the min the 6200 will work on
and the max for that matter
it will not work under 6 and is flackey under 7
because the runtime's do not support it
there is a full list of dll's on the window's devloper page i need to get and have u install,plus u will be need a few more for :ie:,because without them
the runtime's will not work right,i am picking apart cuda and cuda sdk right now
plus i will get your dll list from the dev page
bare with me
ed
ed12
« Reply #356 on: August 21, 2012, 10:16:06 pm »
hi
cvn53
this attachment
will fix some of the problem
place it in nvidia >the .zip then un-zip to the same<
i will instruct as to how to place in the system once i get it fully built
ed
Spitfire
« Reply #357 on: August 22, 2012, 01:09:40 am »
Hi Ed, just confirming that the above 2 files are they for me at all or to fix Cs problem ?
Thx Spitfire
Spitfire
« Reply #358 on: August 22, 2012, 08:51:10 am »
Hi Ed, just inserted the shlwapi.dll in system32 on my PGA machine n the machine gave me
A kernal32 error file not found every time I booted up. Had to take the hard drive out and install on other pc to insert the original file to fix the problem. Awaiting ur instructions to what I'm doing wrong?  Also my graphics card is starting to play up. I am running a 128m card and I would like to install a x1650Pro 512mb card to increase performance. Can u instruct me on how to make this work or point me to the right page on this thread as I think the original card wont last long. Please advice.
Thx in advance.
Joe
CVN53
« Reply #359 on: August 22, 2012, 09:40:34 am »
Hi Ed
Ok the n4.zip is in the nvidia folder tried to install dxwebsetup.exe but this version os not supported,I am thinking the dll's and extra stuff I need is to allow dxwebsetup to install correct. I have internet on Pga but no virus protection but to install dxwebsetup you need the internet to install it, I did this and got the error not supported by this Os.I looked in system32 for my drectx version it is Version directx 9.0c (4.09.0000.0904) just for your info.
Do I need to install the directx_9c_eulas.exe?
Thanks CVN53
« Last Edit: August 22, 2012, 10:23:11 am by CVN53 »
