Author Topic: pga golf vr-gobal  (Read 232498 times)
ed12
Re: pga golf vr-gobal
« Reply #280 on: August 11, 2012, 02:52:49 pm »
hi
general hello to all
thing's we should have learned
a=bios is a bit#h if the battery fail's
b=ram is the same
c=swapping video card's in a winxp:e: box is not like swapping them in normal window's >they need :special pointer's:<
d=the onboard lan will work and will respond to your modem
proff is to right click mouse in screen
and tell it to go to :ie:,if it bark's it is not set, this a stranded window's setup
e=the window's set is very reduced,u should know this by the size of the harddrive,again if we want to add most likely we will need to add manual .dll's/oxc's,basic program file's >without< bloating or unit
ed
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« Reply #281 on: August 11, 2012, 03:36:53 pm »
im with you on the cold beer but im going to get some more fans in the cabinet before i play it again so this doesnt happen again. cheers :cheers:
WANTED: NINTENDO CABINETS WORKING OR NOT
ed12
« Reply #282 on: August 11, 2012, 04:08:35 pm »
hi
cvn53
i have found 2005
will load onto a hd tonight
and copy it out so i can find where to point u
as i still think u need to try this :example-here:
load the driver's, but first we repont hercule's by placing it in the window's main .dir,then we repoint our installer
:load to where c:\hercule's:
it should pick up it's .dll's it want's
next we write a .bat
c:\pga_2005\hercules\>name of video card<\where the driver's rest >ie< window's\system32
it is much like that
ed
CVN53
  • Last login:December 24, 2013, 10:33:27 am
« Reply #283 on: August 11, 2012, 08:59:24 pm »
Hi Ed
Not real sure on what you want me to try,not sure how to repoint the installer, and you want hercules in windows folder correct.
CVN53
ed12
« Reply #284 on: August 11, 2012, 10:15:43 pm »
hi
cvn53
let me get the pga-2005 loaded on a drive
then i can better help u
ed
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #285 on: August 11, 2012, 11:19:20 pm »
Hi Ed, I hope u got my pm n all is moving along just waiting for ur files n some instructions to get online happening and to unlock some new players courses n items. Thx Joe
CVN53
« Reply #286 on: August 11, 2012, 11:33:59 pm »
Hi Ed
  Thanks I really appreciate the time you have put in to helping me and the others on this forum.
CVN53
dirt
« Reply #287 on: August 11, 2012, 11:51:21 pm »
hi ed,
  i found a fan in my stash in the garage. so it is now blowing on the video card. i also left the back door off to help with cooling. i just finished my 4th beer and second 18 holes. thank you.
i still want to get my card reader fixed and the extra courses and players but for right now im happy. at least i can play it again.
ed12
« Reply #288 on: August 12, 2012, 12:34:29 am »
hi
dirt
good work,that's what i like to hear
i run 90% of my game's less 1 putter side cover for that exact reason u just did
heat,it's a killer for them thing's
card reader's i have a few spare's,the board usally puke's
there  cheap enough at wico or micro specalities about 16.00 usd
if u were in great white north i would just give u 1 exchange
as i repair them all the time
cvn53
thk-u and bear with me
the mobo i was going to use is a hunck of crap so i just through it out
it dose not take 10-time's to resize a disk and load the game
kept comming back no boot disk
and no it was not bios setting's
it would load into ram
then when u rebooted as required
no boot secter found :as if it was loading from the cd again:,so it met a ugly death
all is not lost i have another mobo here ready to lock and load
i am still out as to how i am gonna convice it that i do  have a 6200 vid card
but hey i am game >maybe i will just buy 1<,my main contract would jump for joy if i told him i found a replacement,and need to code it in
bare with me
ed
CVN53
« Reply #289 on: August 12, 2012, 10:07:47 am »
Hi Ed
I have asked this question before,is there a way to run pga on a LCD monitor to test the game without having the game cabinet?The cabinet is 60 miles away and I would like to be sure it works before I take it back.
CVN53
ed12
« Reply #290 on: August 12, 2012, 11:28:29 am »
hi
cvn53
yes it will hook right in
u just may need to hit the auto adjust button on the lcd unit
onto 6200 card
my note's say it was a drop in by gobal vr for the aging 42/4800's
they said something about white detailing >smearing<,i do believe joe told me to look in there proxe for it
i will need to find the fttp in my note's
ed
ed12
« Reply #291 on: August 12, 2012, 12:06:44 pm »
hi
dirt and cvn53
in this .zip there is 3 service b's
1 is for dirt
2 are for cvn53
cvn53 i thought they had did a drop in,it turn's out it is a rescue disk
dirt the sb is on heat and video card and damage it will do
cvn53 i am sure that i have access to that disk,but like i said i will need my
notes to find the fttp #
ed
ed12
« Reply #292 on: August 12, 2012, 10:13:04 pm »
hi
spitfire
i need u to open
pga\c:\gvr\gvr_tools
and see if u can see this script
it is called
firewall enable
code >
'Thanks to Microsoft - MSDN Library
'Ramesh
OPTION EXPLICIT
DIM ICSSC_DEFAULT, CONNECTION_PUBLIC, CONNECTION_PRIVATE, CONNECTION_ALL
DIM NetSharingManager
DIM PublicConnection, PrivateConnection
DIM EveryConnectionCollection
DIM objArgs
DIM con
ICSSC_DEFAULT         = 0
CONNECTION_PUBLIC     = 0
CONNECTION_PRIVATE    = 1
CONNECTION_ALL        = 2
Main( )
sub Main( )
    Set objArgs = WScript.Arguments
'    WScript.Echo( "running enable" )
    if objArgs.Count = 1 then
        con = objArgs(0)
'        WScript.Echo con
        if Initialize() = TRUE then
            GetConnectionObjects()
            FirewallTestByName(con)
        end if
    else
        DIM szMsg
        szMsg = "Invalid usage! Please provide the name of the connection as the argument." & chr(13) & chr(13) & _
                "Usage:" & chr(13) & _
                "       " + WScript.scriptname + " " + chr(34) + "Connection Name" + chr(34)
'        WScript.Echo( szMsg )
    end if
end sub
sub FirewallTestByName(conName)
on error resume next
    DIM Item
    DIM EveryConnection
    DIM objNCProps
    DIM szMsg
    DIM bFound
    bFound = false
    for each Item in EveryConnectionCollection
        set EveryConnection = NetSharingManager.INetSharingConfigurationForINetConnection(Item)
        set objNCProps = NetSharingManager.NetConnectionProps(Item)
        if (ucase(conName) = ucase(objNCProps.Name)) then
            szMsg = "Enabling Firwall on connection:" & chr(13) & _
                    "Name: "       & objNCProps.Name & chr(13) & _
                    "Guid: "       & objNCProps.Guid & chr(13) & _
                    "DeviceName: " & objNCProps.DeviceName & chr(13) & _
                    "Status: "     & objNCProps.Status & chr(13) & _
                    "MediaType: "  & objNCProps.MediaType
'            WScript.Echo(szMsg)
            bFound = true
            EveryConnection.EnableInternetFirewall
            exit for
        end if
    next
'    if( bFound = false ) then
'        WScript.Echo( "Connection " & chr(34) & conName & chr(34) & " was not found" )
'    end if
end sub
function Initialize()
    DIM bReturn
    bReturn = FALSE
    set NetSharingManager = Wscript.CreateObject("HNetCfg.HNetShare.1")
'    if (IsObject(NetSharingManager)) = FALSE then
'        Wscript.Echo("Unable to get the HNetCfg.HnetShare.1 object")
'    else
        if (IsNull(NetSharingManager.SharingInstalled) = TRUE) then
            Wscript.Echo("Sharing isn't available on this platform.")
        else
            bReturn = TRUE
        end if
'    end if
    Initialize = bReturn
end function
function GetConnectionObjects()
    DIM bReturn
    DIM Item
    bReturn = TRUE
    if GetConnection(CONNECTION_PUBLIC) = FALSE then
        bReturn = FALSE
    end if
    if GetConnection(CONNECTION_PRIVATE) = FALSE then
        bReturn = FALSE
    end if
    if GetConnection(CONNECTION_ALL) = FALSE then
        bReturn = FALSE
    end if
    GetConnectionObjects = bReturn
end function
function GetConnection(CONNECTION_TYPE)
    DIM bReturn
    DIM Connection
    DIM Item
    bReturn = TRUE
    if (CONNECTION_PUBLIC = CONNECTION_TYPE) then
        set Connection = NetSharingManager.EnumPublicConnections(ICSSC_DEFAULT)
        if (Connection.Count > 0) and (Connection.Count < 2) then
            for each Item in Connection
                set PublicConnection = NetSharingManager.INetSharingConfigurationForINetConnection(Item)
            next
        else
            bReturn = FALSE
        end if
    elseif (CONNECTION_PRIVATE = CONNECTION_TYPE) then
        set Connection = NetSharingManager.EnumPrivateConnections(ICSSC_DEFAULT)
                set PrivateConnection = NetSharingManager.INetSharingConfigurationForINetConnection(Item)
            next
        else
            bReturn = FALSE
        end if
    elseif (CONNECTION_ALL = CONNECTION_TYPE) then
        set Connection = NetSharingManager.EnumEveryConnection
        if (Connection.Count > 0) then
            set EveryConnectionCollection = Connection
        else
            bReturn = FALSE
        end if
    else
        bReturn = FALSE
    end if
    if (TRUE = bReturn)  then
        if (Connection.Count = 0) then
'            Wscript.Echo("No " + CStr(ConvertConnectionTypeToString(CONNECTION_TYPE)) + " connections exist (Connection.Count gave us 0)")
            bReturn = FALSE
        'valid to have more than 1 connection returned from EnumEveryConnection
        elseif (Connection.Count > 1) and (CONNECTION_ALL <> CONNECTION_TYPE) then
            Wscript.Echo("ERROR: There was more than one " + ConvertConnectionTypeToString(CONNECTION_TYPE) + " connection (" + CStr(Connection.Count) + ")")
            bReturn = FALSE
        end if
    end if
'    Wscript.Echo(CStr(Connection.Count) + " objects for connection type " + ConvertConnectionTypeToString(CONNECTION_TYPE))
    GetConnection = bReturn
end function
function ConvertConnectionTypeToString(ConnectionID)
    DIM ConnectionString
    if (ConnectionID = CONNECTION_PUBLIC) then
        ConnectionString = "public"
    elseif (ConnectionID = CONNECTION_PRIVATE) then
        ConnectionString = "private"
    elseif (ConnectionID = CONNECTION_ALL) then
        ConnectionString = "all"
    else
        ConnectionString = "Unknown: " + CStr(ConnectionID)
    end if
    ConvertConnectionTypeToString = ConnectionString
end function <
end code
if so
place this in front of ever cmd ie:string: ! it is shift and 1 key toghter
to make it look like this
!'Thanks to Microsoft - MSDN Library
!'Ramesh
for now it will rem out the firewall
and turn it off
i will rework the script
so u can tie each other toghter
this cmd >>   if (IsNull(NetSharingManager.SharingInstalled) = TRUE) then
        else
is a real offender
so i will need to rework it
u can open it in note pad
if u do not know how i will edit 1 for u
ed
CVN53
« Reply #293 on: August 13, 2012, 02:00:42 am »
Hi Ed
  When I boot up after loading I get usbio card missing or cable is disconnected fix and reboot how do I get around this error,if you already explained this please point to the page its on I don't seem to find it.
Thanks CVN53
Spitfire
« Reply #294 on: August 13, 2012, 05:33:37 am »
Hi Ed no prob mate I'll let ya know how I go.
Thx Joe
Spitfire
« Reply #295 on: August 13, 2012, 06:21:14 am »
Hi Ed would it be possible after remarking it all out and adding ur tournament file to just run my routers firewall to keep out the unwanted and add the wanted ISP to my routers firewall exceptions???
ed12
« Reply #296 on: August 13, 2012, 11:28:03 am »
hi
cvn53
that is the i/o board is not seening the usb
on the back of the putter
is 2 usb slot's,u could try hooking to 1 of these then go to the :i/o: card where it tie's the game control's in,there will be a spot for the other end of the usb cable,
it will not look like usb but rather a square knotch,that is where the other end of the usb cable goe's,also if u powered the i/o board with the internal power plug
unplug it >the power-plug<,and let the usb do it,now u would note i said to dirt he should be using the pcia usb extenter board,and up-loaded the pdf on it
u can tell if it is working because the green light on the i/o card will come on
spirtfire
i asked and showed u were we need to edit
i just need to do the edit >today<
i will repost,u copy save as .txt,copy your txt and make the new copy calling it vbs,then u rename the main 1 1filename.vbs
and the new 1 filename.vbs
this way hercules will call in our edited 1 and will not see the oringal which we keep for backup in the same .dir
ed
CVN53
« Reply #297 on: August 13, 2012, 02:55:07 pm »
Hi Ed
Thanks green light working, I got it loaded to where u put money in to start a game,because this is where the screen just went blank when actually starting a game when connected to cabinet,so is there a way to start a game using a mouse and keyboard.
CVN53
« Last Edit: August 13, 2012, 03:08:31 pm by CVN53 »
ed12
« Reply #298 on: August 13, 2012, 03:42:36 pm »
hi
cvn53
no need
if u are that far,press test switch.go to control's invoke freeplay,it is there
not sure off the top of my head,but i do think
option's or in coinage
u will find it go slow through all the drop down menu's
once there and set to free play press select
then exit out
it's funny it never barked at u about the card reader?
spitfire
i printed out the file so i can edit better
ed
CVN53
« Reply #299 on: August 13, 2012, 04:48:19 pm »
Hi Ed
I am not in the game cabinet its 60 miles away,I know about the test switch in the cabinet but I need to try and load a course without the cabinet with just the computer and keyboard and mouse.Yes it stalls at no card reader for 10 or 15 secs then continues on,that way I know if the new video card works once we get it pointed to hercules.
CVN53
« Last Edit: August 13, 2012, 06:00:01 pm by CVN53 »
ed12
« Reply #300 on: August 13, 2012, 07:26:01 pm »
hi
cvn53
so u do not have any off the control's ?
if so i have a printout of them into the i/o board..
if u gotten to it to skip past the card reader interface test ?
then u are 50% there..
i will find my note's on the nessary button's,do u have a track ball handy ?,
+ u willl need +5volt's to feed it,also u will need it in free play or it will coin error out on u
ed
Spitfire
« Reply #301 on: August 13, 2012, 07:45:06 pm »
Hi Ed I have ! Remd the whole file as requested. I am
Now awaiting ur next instructions.
Thx Joe
Spitfire
« Reply #302 on: August 13, 2012, 08:08:57 pm »
Hi Ed I also see all the golfers in the Pga 2006\players folder 43 in total will u also be providing instructions on how to unlock n be able to select these players?
Thx Spitfire
dirt
« Reply #303 on: August 13, 2012, 09:16:07 pm »
hi ed,
  after adding the extra fan and leaving the back door off the cabinet i have had no issues except the card reader. do you think both of my card readers are bad or maybe something else. some backround, the game came with a card reader in it and when the game could not see it i bought another that was suppose to be tested working from ebay. im a realist and i know there is a chance that the ebay card reader is dead too. if i plug the card reader into my laptop and goto, control panel, add hardware, what should i be looking for? basicly what would it be named?
ed12
« Reply #304 on: August 13, 2012, 09:50:39 pm »
hi
dirt
if u hook it to windows xp
the first thing u should c is new hardware found
from there it will want driver's
i believe i posted u on the mfg and model #
in a post on this thread
plug 1 in first if it dose that >found new hard-ware< unplug it
wait,for window's to settle down and or restart window's,some times
window's get's confused,anyway's after reboot try the other 1
if it say's the same thing?, find load driver's,and u should see it in control panel
spitfire
yes
and congrad's on vb scripting
ed
dirt
« Reply #305 on: August 13, 2012, 10:09:58 pm »
i plugged it in to my laptop and first it said "mo1002" then new found hardware usb human interface device then your new found hardware is ready to use. it never asked for drivers.
ed12
« Reply #306 on: August 13, 2012, 10:12:28 pm »
hi
dirt
is that lappie running 7 ?
if so that is why
so reboot and chk the other 1
ed
Spitfire
« Reply #307 on: August 13, 2012, 10:21:16 pm »
Hi Ed tgx for the pat on the back. Have read ur thread a few times n am starting to understand what to do now. Ha ha eagerly awaiting ur next instructions as I can't wait to unlock new players n items n also setup online play against my buddies.
Thx Joe
CVN53
« Reply #308 on: August 13, 2012, 10:24:19 pm »
Hi Ed
Thats right I have none of the controls,I might have a track ball how would I get +5 volts for it if I do.How's it coming on the stuff to get the new video card to be reconized by hercules.
Thanks CVN53
« Last Edit: August 13, 2012, 10:26:12 pm by CVN53 »
dirt
« Reply #309 on: August 13, 2012, 10:27:06 pm »
The laptop is XP its my daughters old dell.
Sent from my LG-P509 using Tapatalk 2
ed12
« Reply #310 on: August 13, 2012, 10:40:46 pm »
hi
dirt
huh ?
she must have usb2
because usb1 in xp dose not do that call
it say's new hardware found,etc,etc,etc
and a proff in the pudding is to take a usb stick and plug it in
to a usb port,it had better say new hardware,and then a min or less come back with new hardware installed and ready to use
spirtfire
i will be on for the next few evening's
the am's i will be moving equipment around,but as i said i printed out the vbs
so i can do a better edit :)
cvn53
a spare putter power supply will do the job
do u have a connector that will  fit the interface plug to the i/o board ?
if so can u solder wire's ? i truly hope so or u are doing a 60 mile road trip,if
u have a female plug 37pin's i do believe and know how to solder i can walk u through a test head,we olny need a few button's and the track ball,with a common
ground to our pga unit,after we set to free play we olny need
test/start/trackball
ed
ed12
« Reply #311 on: August 13, 2012, 10:51:09 pm »
hi
dirt
i just did it
on my home unit
both usb1 and 2
and same thing came up
found new hardware stc-11-sdkdevice
which is what it should be
and on my wife's 7
it say's your new human interface is ready to use
and this box is xp-sp3 driven  ?
your #'s  make no sense to me
spec the mfg and model  # so i can get to the bottom of this please
cvn53 the card is on it's way
ed
dirt
« Reply #312 on: August 13, 2012, 11:03:53 pm »
The card reader is xico model 7101usb
The laptop is dell latitude x300
CVN53
« Reply #313 on: August 14, 2012, 12:29:46 am »
Hi Ed
I guess once we get the video card drivers figured out I'll have to make a road trip.In the mean time I will try to locate a connector and track ball.Update  have a track ball,searching for connector.
CVN53
« Last Edit: August 14, 2012, 06:44:31 pm by CVN53 »
ed12
« Reply #314 on: August 14, 2012, 08:17:26 pm »
hi
cvn53 i should have card on thursday
spitfire
if u open script
u will c a dim statment this is a gobal call for vb
the line dim everyconnectioncollection >stay's<
what leave's is connection public = 0
that make's it first on the list for call in's
we simply remove it
but for now we rem it out
until i find the rest of it
sorry i did not work alot on it today as i was moving machine's around
brought in a sweet repair
29" monitor shrunk on 4 side's
smp's is my best thought until i peel the back off it and have a peek
that will ramp up the ol pay chk
ed
ed12
« Reply #315 on: August 14, 2012, 10:36:50 pm »
hi
spitfire
isccc_default =0 should now reflect =1 leave the rest of that call for now
as i am stripping out the dim for it
it's comming along
ed
Spitfire
« Reply #316 on: August 15, 2012, 01:14:14 am »
Hi Ed been a busy day here in OZ also have 3 multigame driving cabs linked that I need to configure. I will look at PGA tonight. Maybe I'll wait to u have it all working and do all the editing at once. Thx Joe
Spitfire
« Reply #317 on: August 15, 2012, 11:17:37 pm »
Hi Ed how's it all going hopefully close to unlocking all players items etc n getting an online game with mate going?
Thx Joe
ed12
« Reply #318 on: August 16, 2012, 01:06:02 am »
hi
spitfire
yes thing's are going good so far mate
u are right to wait for the final script
thk's for pointing that out to me
as vb  can get real ass bitchy real fast
ie 1 typo
and u restart
welcome to my world
hence the reason i printed it out
so i can foot note what can come out what can stay etc..this time around if 1 person dose it,instead of a collictive...it should come out error free
which so far is good
p.s i have pinged u :):)
u just did not know it
no fear's mate i just made sure i could see u
would u do me a fav?
and grab a dlink router,?,u know 1 of then 4 port job's
and hook the pga into it along with your home box <as it serv's> as the dchp host :ip:,from there on the pga we turn on :sharing: of the hard-drive-pga-box-olny,
your home box's do not need to be shared...so again no fear's,and if u want u can firewall them to be sure,we just want the dchp connection to your router..
so u can read into everyone else's pga's >THEY MUST DO THE SAME<,
the script's for 0-9..u can expand if u want
i have left it open ended...
0=ed
can not be changed,DO NOT EVEN TRY...
u may need a few .dll's from microsoft
i will chk into it,..side note here how did the linking go ?
as i have done tunrnnie's with cursing usa..up to 6
u caught me with the 3 :):)
ed
Spitfire
« Reply #319 on: August 16, 2012, 05:19:56 am »
Hi Ed I am directly connected via LAN cable to a dlink 8 port wireless router which inturned is connected to a speedstream 4200 modem. All ip addresses are controlled by the dlink router is this ok?
Please let me know?
Thx Joe
