Author Topic: Monitor ID/Wei-Ya Chassis Replacement (WG-K7000)  (Read 5666 times)
keeganhayes
  • Last login:May 30, 2014, 11:57:00 am
« on: October 16, 2011, 10:20:44 pm »
Picked up an empty TMNT for $5 which I'm in the process of converting to MAME!
The chassis was busted to hell, so my project for this week is getting a new one installed:
1) I think I correctly identified the monitor as a WG K7000. (It has a Zenith tube) Could someone confirm? (If it makes a difference)
2) Forum member Windmill was kind enough to ship me a spare slightly-defective wei-ya chassis. I replaced the Horizontal Output Transistor as he described in this thread: http://forum.arcadecontrols.com/index.php?topic=111904.0
3) I think I have interpreted the connections from chassis to tube correctly, could someone confirm?
This is the old chassis which I believe to be a WG k7000:
The replacement Wei-Ya labeled to the best of my ability:
I think this is the degauss cable which is connected to #1 on the Wei-ya? :
This yoke plug is connected to #3 on the Wei-Ya ?
This wire is flat and wraps around the length of the picture tube. Is this for grounding?
4) How would one go about making a vga breakout cable for a wei-ya chassis? (As I understand, the wei-ya connectors are slightly different from the conventional connectors found on ultimarc and others breakout cables)
I'm sure I've made a mistake somewhere, so let me know where I'm going wrong!
Thanks for any and all help!
Keegan
« Last Edit: October 16, 2011, 11:11:42 pm by keeganhayes »
grantspain
Re: Monitor ID/Wei-Ya Chassis Replacement (WG-K7000)
« Reply #1 on: October 17, 2011, 06:39:45 am »
you look to be all corrct to me,the flat wire(ground) connects to the single header pin on the neck card
everything should be plug and play
Ken Layton
  • Guru
  • Technician
« Reply #2 on: October 17, 2011, 12:24:25 pm »
Looks like your original chassis was a K7000A.
Your Wei-ya chassis will need to be "Americanized" as per my thread:
http://forum.arcadecontrols.com/index.php?topic=97584.0
keeganhayes
« Reply #3 on: October 17, 2011, 04:43:50 pm »
Ken, if I'm hooking this up to MAME via a VGA breakout is it entirely necessary to replace the video/sync connector? Is there some way to splice a VGA to be accepted by the current connector?
