Author Topic: Is this switch 12v or 110v ?  (Read 1188 times)
cmarion1024
  • Last login:December 04, 2013, 11:25:47 am
« on: October 15, 2011, 10:54:11 pm »
On an original arcade cabinet (like mine) is the power on/off switch that is mounted on top 12v or 110v? I don't want to replace it if its 110v. It is a metal toggle on/off switch recessed in a cutout just above the marquee. There is no writing or notations on it to determine. I searched with no answer on original switches, checked google too.
I want to use it to be the switch for my HD power strip mounted inside.
BobA
  • What Me Worry?
Re: Is this switch 12v or 110v ?
« Reply #1 on: October 15, 2011, 11:39:44 pm »
On a real arcade cab the power switch switches 120 VAC.
cmarion1024
« Reply #2 on: October 16, 2011, 12:19:03 am »
Thank you!  :applaud:
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #3 on: October 16, 2011, 11:38:25 am »
A switch doesn't care what voltage is on it, with exception to specialty high voltage switches where arcing can be a problem, and lighted switches. The voltage rating relates to the current rating. IE, a switch may be rated for 10a at 120vac, and 5a at 240vac. Ratings for ac and dc are different as well (arcing when the contacts break).
