Author Topic: solved: Is anyone using joytokey with instant sheller?  (Read 4725 times)
Gray_Area
  • -Banned-
  • -Banned-
« on: October 14, 2011, 12:40:13 am »
Over here, Instant Sheller seems to defeat joytokey/not allow it to load.
Edit: Instant Sheller, per se, wasn't the issue here. It was that Explorer wasn't active, hence no applications could load via 'start-up', etc.
« Last Edit: October 17, 2011, 07:49:49 pm by Gray_Area »
-Banned-
Gray_Area
  • -Banned-
  • -Banned-
Re: Is anyone using joytokey with instant sheller?
« Reply #1 on: October 15, 2011, 12:03:31 am »
topic re-vamped
-Banned-
gonzo90017
« Reply #2 on: October 15, 2011, 12:30:20 pm »
If you're using XP, you should try loading Joytokey as a service. You can use XYNTService to accomplish this.
abispac
  • Last login:January 08, 2026, 11:34:54 pm
« Reply #3 on: October 15, 2011, 04:16:49 pm »
I felt you pain , i had to the same problem in the past, they way i solve'it was to create a batch file to load joy to key first then the front end, then use batch to exe converter and use that in instantsheller to start my cab.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: October 16, 2011, 02:14:58 pm »
Thanks for the link....but, you have to be a member to download the....source code (??).....and I can't find it anywhere else. Developers sometimes seriously elude me.
Yeah, that's not happening.
So I thought I'd load joytokey via Mala's emulator pre-command feature. I assumed the pre-command syntax would be "dir>joytokey.exe", and joytokey does load. However, the game doesn't load/Mala sticks on the loading screen. Exiting/canceling joytokey allows Mala to continue and load the game. ".
What does the syntax need to be?
« Last Edit: October 16, 2011, 04:09:12 pm by Gray_Area »
-Banned-
gonzo90017
« Reply #5 on: October 16, 2011, 05:56:27 pm »
Download it from here. I set it up with AtomicFe to give you an idea.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #6 on: October 16, 2011, 11:40:10 pm »
I forgot to install it. Now it works, although it takes several seconds to load after Mala displays. Kludgy, but functional. Thank you.
-Banned-
gonzo90017
« Reply #7 on: October 17, 2011, 06:05:39 pm »
No problem.
gman314
  • Last login:July 02, 2013, 03:12:39 pm
Re: solved: Is anyone using joytokey with instant sheller?
« Reply #8 on: November 11, 2012, 11:46:27 pm »
Does anyone know if instant sheller will allow joytokey to load using the Maximus Arcade frontend?  The reason that I ask is that MA has a feature which allows you to launch a program at the same time that an emulator us launched.  Will this feature negate the fact that windows explorer isn't technically active?  I would also like to note that this feature of MA did indeed launch joytokey when I directed my pc to autoboot MA without using the instant sheller program.
