Author Topic: Rotate WahCade in Groovymame  (Read 6195 times)
strontium
  • Last login:December 02, 2021, 05:12:52 pm
« on: October 10, 2011, 11:22:52 am »
Hi can anyone help me with this question, I have a fresh build using GroovyMame which works great, the only thing that I'm having problems with is that my cab is only for vertical games and I don't seem to be able to get WahCade to rotate 90 degrees to fit a vertical monitor setup  :angry:. The games run correctly and rotate fine it just seems to be the frontend which won't play dice. I have assigned the key to rotate the retro black theme but it does nothing. Is this a bug or am I missing something. I have noticed when I start wahcade from the command line it mentions that PIL (Python Image Libary) is missing and so will not support rotated images. I am using the latest LIVECD ISO 1.565
Any help will be really appreciated
Strontium
mattr69
  • Last login:May 01, 2020, 05:24:01 pm
Re: Rotate WahCade in Groovymame
« Reply #1 on: November 03, 2012, 05:55:35 pm »
Bump. Just wondering if anyone has an answer to this.. ?
General_Faliure
  • Last login:March 01, 2022, 07:30:40 am
    • My Arcade Cab
« Reply #2 on: November 04, 2012, 06:25:32 am »
Have you tried posting in the Wahcade forum: http://www.anti-particle.com/wahcade.shtml
My Arcade cab: https://goo.gl/photos/yE1KACHryQjCaaCj7
Core2 duo8400 @3.6 Ghz, 4Gb of mem, Geforce 9500.
Linux Mint 17.3 XFCE, Mame, Mess, Daphne FS-Uae, Mednafen and some more.
Mah!cade
oxy
  • Last login:August 31, 2019, 09:06:27 pm
« Reply #3 on: August 12, 2014, 11:16:28 am »
You need to rotate everything, no just the frontend and mame. I used two wahcade configurations:  normal for horizontal games and a modified layout wahcade-tate for vertical games
