Author Topic: Finaly Got My First Build Under Way (updated) :)  (Read 2117 times)
jggamer
  • Last login:February 16, 2012, 08:40:25 pm
« on: October 06, 2011, 07:41:38 pm »
Well, after joining the forum and reading a lot, then posting my ideas, I finally got my cabinet underway.  Attached are a few pics of my progress so far.  Its closely based off of the PacMan cabinet plan, probably off measurements in some areas and I also made the top flat.
Using a 17" Monitor for now, hope to upgrade in the future.   Still have a lot of work to go but wanted to post what I had so far.  Also after long thoughts, I finally made the decision to go with a one player setup, as you can see vertical monitor, that will be the majority of the games, if I want a horizontal, well that will just have to be small.  :P  The one other thing that I am contemplating is having both a dedicated 8 way and 4 way joystick since i am going one player control panel.
Let me know what you think..
« Last Edit: October 27, 2011, 11:27:59 pm by jggamer »
Nimbus
  • Last login:December 21, 2019, 08:08:57 pm
Re: Finaly Got My First Build Under Way
« Reply #1 on: October 06, 2011, 08:42:31 pm »
Awesome! I love seeing repro's of the classic cabs. Keep up the good work and keep posting pics!!
jggamer
« Reply #2 on: October 26, 2011, 11:58:25 am »
OK, I have made some more progress, will try to get some updated pics later, so far I have the speakers installed, the cab painted, the coin door installed, artwork on side installed, and the marquee installed.
Now looking for some help and input on the CP.  I first was thinking I would go with a 2 player setup, but now I think one will be fine since all the games will have the players swapping on and off.  Can some one help me design a CP that will accommodate 2 player selection buttons, 2 admin buttons (Pause and Escape), 3 buttons for jump, fire etc, and a joystick or two.  I was thinking an 4/8 way combo but since i will have room, now thinking maybe a dedicated 4 way and a dedicated 8 way, or should I just stick with on switchable joy?
The CP Dimensions I have to work within are 23" x 6.75"
Thanks in advance for the help.
jggamer
Re: Finaly Got My First Build Under Way (updated) :)
« Reply #3 on: October 27, 2011, 11:29:28 pm »
Here is the CP that I put together, take a look and let me know your thoughts....note i mirrored the buttons for left or right hand play   :applaud:
nordemoniac
  • Weee! Hahaha...
« Reply #4 on: October 28, 2011, 05:44:48 am »
The layout for me seems well enough, but I'm not sure about the Artwork - it's a bit noisy. I would have sticked to one theme. If this were up to me, I would've done a donkey kong theme all over. That looks much nicer, especially when you are making a replica of the cabinet.
But that's just my opinion  :D
