Author Topic: FS:Out of Stock. ZD Encoder Boards with wiring: $14.75 shipped. [USA/MN]  (Read 85327 times)
fluentd
  • Last login:October 20, 2014, 07:30:41 pm
Re: FS: Back in stock! ZD Encoder Boards with wiring: $14.75 shipped. [USA/MN]
« Reply #160 on: September 06, 2012, 08:57:12 pm »
Hey is it possible to create a 4 player Mame setup with these boards?
  • Last login:March 21, 2024, 08:20:28 am
« Reply #161 on: September 07, 2012, 12:06:15 am »
Yes, you can. You can have multiple of these in at the same time. I have personally used 4 of these at a time with no problems. If you are not using too many buttons for player 3 and 4, you might even be able to squeeze it all in with 3 encoders.
The only pitfall you could run into is that if you unplug and plug these back in while playing, it can change around the order of the players, which happens with most USB joystick devices. Under normal cabinet use, you would be leaving them plugged in all the time have no problems.
I just wanted to point it out since I have had a person use these for 2 player cabinets, with plug in and out add on controls for players 3 and 4. He was popping in and out during use, and the USB orders screwed up when doing so. It took tweaking to get the right encoders aligned with the right USB ID#'s so that he plug in player 3 and 4 without it affecting the order of player 1 and 2.
blackjudas
  • Last login:September 20, 2012, 08:30:22 pm
  • Rockin' it out in Canuckistan!
    • My Blog
« Reply #162 on: September 13, 2012, 06:25:20 pm »
Seems like I can't PM either, I'd be interested in finding out if there's a flat rate for shipping to Canada or is it smarter for me just to use your ebay listing?
I type this out every time....
« Reply #163 on: September 13, 2012, 07:40:29 pm »
Hello,
I give international shipping at cost here. It should generally be cheaper through here directly than through ebay. I will PM you with a quote.
FYI, I only have one left in inventory until my next shipment comes in about a week from now. If you want more than one, it will take a little longer. Thanks!
blackjudas
    • My Blog
« Reply #164 on: September 13, 2012, 11:18:50 pm »
Hello,
Hi Vigo,
Thanks for the PM, seems I can't even respond to one, understandable anti-spam measures.  Well you've got me convinced, I'll take two, let me know through a PM when you have your next shipment as I'm in no magic rush.  For two, is the price different or simply multiply the amount by 2?
« Reply #165 on: September 14, 2012, 01:04:35 am »
It will be a little bit cheaper for each since I can combine the shipping for the two. I sent you a second PM with your new quote. Thanks!
sq1ne
  • Last login:October 24, 2012, 07:28:09 pm
« Reply #166 on: October 03, 2012, 05:31:43 pm »
Hi there,
How many of these boards would I need if I were to do a set up for 2 player, street fighter style?
(2) 8 way joysticks
(2) push buttons
player 1, player 2 coins
restart, select
Anything else I've missed?
Thanks,
« Reply #167 on: October 04, 2012, 09:30:22 am »
Hi Sq1ne,
These boards come standard with enough wires for the joystick and 8 buttons, with the option of buying 4 more button wires ($3 extra).
With your setup, it sounds like you would want 9-10 buttons for each player. You would want to order 2 encoder boards, and one extra wire set.
Let me know if you are interested and I will send you a PM with the payment instructions.
sq1ne
« Reply #168 on: October 04, 2012, 06:01:21 pm »
Yes,
Please send me a PM with instructions for payment.
Thanks,
manurag
  • Newbie
  • Last login:October 22, 2012, 01:06:47 pm
« Reply #169 on: October 07, 2012, 12:47:30 pm »
Want to buy ZD encoder . Can it be shipped to india .If yes,Can u please send me the quote including the shipping charges at anurag.makol@gmail.com
I will be thankful.
« Reply #170 on: October 07, 2012, 03:05:37 pm »
I will be thankful.
Email replied. Thanks!
virtvic
  • Newbie
  • Last login:September 22, 2013, 06:54:07 am
« Reply #171 on: October 07, 2012, 06:53:09 pm »
Hi there, Vigo - I'd be interested in buying a pcb, can you pm me please as I can not message you for some reason (because I am new to this forum?)
cheers
V
« Reply #172 on: October 07, 2012, 07:09:54 pm »
cheers
V
PM replied. Thanks!
DAWORM
  • Last login:October 12, 2012, 05:11:31 pm
« Reply #173 on: October 12, 2012, 04:30:26 pm »
After 1 year of researching and wishing ~ Its time to get off the pot and build me a stick.   Vigo I would like to buy a ZD Rematch ~ Im using Happ Buttons and a Zippyy Joystick (so the American size wires should work)
Please send me a message ~ Time to start building !!!
« Reply #174 on: October 12, 2012, 04:32:34 pm »
PM replied. Thanks!
RyoriNoTetsujin
  • Last login:March 23, 2024, 03:55:45 pm
« Reply #175 on: October 15, 2012, 09:53:16 am »
PM sent.  ;D
RyoriNoTetsujin
Received my 2 boards yesterday. :w00t Installed last night, cleaned up the cables a bit this morning.
They're replacing an iPac4 (with a PS3 adapter that still isn't working the way I need it to, despite Andy's best efforts to repair it ... ???) and they're doing a great job on both PC and PS3. Thanks Vigo!
Now, that said:
Hi guys, I bought one of these from ebay a few weeks back after reading the original thread on their discovery - it turned up yesterday.
I finally got around to having a play with it today, and wondered if anyone had had any luck changing the config settings. Namely the default hat/pivot selection on startup.
Currently the Red LED is default, but would like it to boot straight to the green LED to avoid having to run another (Mode) switch if possible.
I have had a look through the properties section in the device manager, and I imagine its just a 0 value that needs changing to 1 somewhere, but lack of info on these boards is making it tough.
Thanks in advance
Any information on this? PS3 only recognizes the POV hat as a D-pad for fighting games (SF4, TTT2, etc.). I've got a couple of spare buttons rigged up and hanging out the back of my CP for now, but a permanent boot solution would be really, really ideal.
« Reply #177 on: October 23, 2012, 11:13:15 pm »
Awesome! I'm glad it's working out for you! In regards to booting in POV hat mode, I will check in with the guy who makes it. It will be a few days before I get the chance to ask him, but I'm hoping he has an answer.  8)
esmith13
  • Last login:April 07, 2022, 09:27:26 am
« Reply #178 on: October 25, 2012, 02:44:57 pm »
Hi Vigo,
New user here and like everyone else I can't PM.
I would like to order one of these with wires for all 12 buttons ( not just 8 ) if it doesn't bring the total  to over $20.00
Thanks in advance,
Eric
« Last Edit: October 25, 2012, 02:48:46 pm by esmith13 »
« Reply #179 on: October 25, 2012, 04:45:05 pm »
Hi Vigo,
Thanks in advance,
Eric
Not a problem. PM replied. If you're not USA, please let me know so I can give you a shipping quote. Thanks!
esmith13
« Reply #180 on: October 25, 2012, 06:27:21 pm »
Payment Sent!! Thank you, sir!!
Eric
burncycle
  • Last login:December 31, 2013, 11:52:49 am
« Reply #181 on: November 01, 2012, 12:50:00 pm »
Hey,
I am also new to this also. I was looking to get one of your boards instead of a I-pac. I want to set up a 4 player mame. can you send me a PM also I'm in MN also could I possibly pick up ?
thanks in advance
« Reply #182 on: November 01, 2012, 01:10:19 pm »
Hey,
thanks in advance
PM replied! Thanks!
burncycle
« Reply #183 on: November 01, 2012, 01:43:29 pm »
Got your PM but I can not reply to it yet. question? can you run two encoders to have 4 players ??
phearly
  • Last login:November 14, 2012, 12:55:00 am
« Reply #184 on: November 02, 2012, 01:08:21 am »
Hi,
    I am wanting to build a 2-player Hyperspin cabinet setup(2 sticks, 6 action buttons each & a few other buttons) and would like to purchase 1 or two of your boards. I can't seem to PM you to set it up(maybe because I am new to the forum???). I am looking to get started building ASAP. Thanks
« Reply #185 on: November 02, 2012, 12:34:56 pm »
Hi,
PM replied. Thanks!
jpS14
  • Last login:October 04, 2022, 04:34:26 pm
« Reply #186 on: November 07, 2012, 02:48:59 pm »
Got my ZD encoder a few days ago. Works great and shipping was super fast! Thanks Vigo   :applaud:
« Reply #187 on: November 07, 2012, 03:56:11 pm »
Great! I'm glad you got it so quickly. Let me know if any questions come up!
ace_1989
  • Last login:November 26, 2012, 12:20:37 pm
« Reply #188 on: November 07, 2012, 06:39:07 pm »
HI! I want to order this encoder of yours but i am in Philippines..
How much would it cost if shipping cost  is included?
Is this for 1player only?
Can i connect coin slot on this board
My setup: 2-player
6 action buttons for each player
2 sticks
« Last Edit: November 07, 2012, 06:45:05 pm by ace_1989 »
  • Last login:May 18, 2024, 03:07:49 pm
« Reply #189 on: November 07, 2012, 09:10:08 pm »
Vigo, my man I'm assuming you still have these in stock, I might need a few, will these work with perfect 360 sticks? They require a common ground so I'm assuming I can tie all the top (or bottom) wires together and be good to go?
« Reply #190 on: November 08, 2012, 12:48:13 pm »
My setup: 2-player
2 sticks
PM replied. Thanks!
« Reply #191 on: November 08, 2012, 01:06:08 pm »
Hey Malenko! Yep, I got these in stock. To be honest, I have never wired a perfect 360 to it. I looked it over and think it should work. The directional inputs are all be common ground. The sanwa joystick port on there is common ground as well. I don't see it as being an issue, but I just never tried.
DracoDan
  • Last login:February 27, 2019, 09:55:31 am
« Reply #192 on: November 16, 2012, 05:29:09 pm »
After looking through all the different choices out there, I've made the easy decision to go with a pair of these for my arcade cabinet.  Like so many others, I'm new here so I can't send PMs.  Shoot me a PM or email me @gmail.com
« Reply #193 on: November 17, 2012, 01:16:58 am »
PM replied. Thanks!
adder
« Reply #194 on: November 21, 2012, 08:35:06 pm »
VIGO,  pm sent..  i think.... (the message is not in my sent items folder.. anyway let me know if you get my pm, thanks :lol)
  • Last login:April 30, 2024, 06:21:28 pm
Aww crap. I need 4 of these. I'll keep checking for when you come back online, but if anybody has one or two they'd like to sell shoot me a PM.
We in stock yet? Also, can someone point me to connectors that work with Cherry switches?
it IS February in Australia.
toopack2
  • Last login:February 28, 2013, 10:57:36 pm
I am new to gaming and a member recommended me to get this encoder board from you for my joystick.  I do not know much so it might sound silly to some, is this board like a converting board that I see in some joystick kit that you allow you to plug in computer's USB port?  Can I do the JAMMA harness with this board?  Too much to learn.
Thank you
AjunNg
  • Newbie
  • Last login:February 07, 2013, 08:54:49 pm
Looking to buy one of these. Would want the normal or the Rematch, whichever is first available.
If Vigo could PM me the cost to London United Kingdom, it would be great!
Not enough posts to send PMs yet.
