Author Topic: Street fighter 4 Arcade + U360 joysticks  (Read 1904 times)
clickhea
  • Last login:August 09, 2019, 07:33:40 am
« on: September 16, 2011, 07:18:49 pm »
has anyone with 2 u360 joysticks gotten this game to run correctly?
If i play the 1 player arcade all is fine.  As soon as a second player buzzes in i lose my controls on player 1 and player 2
StriderDSO
  • Last login:May 11, 2019, 10:15:34 am
Re: Street fighter 4 Arcade + U360 joysticks
« Reply #1 on: September 16, 2011, 07:43:23 pm »
Wasn't there an issue with the non-Arcade Edition of this game using PC keyboard controls, and how it doesn't allow two players at once? I think there is a patch or a workaround if you have the none AE version - perhaps it's the sticky under the Software Forum (I haven't actually read it)?
(\__/)
(='.'=) This is Bunny. Copy and paste him into your
(")_(") signature and help him on his quest for world domination.
clickhea
« Reply #2 on: September 16, 2011, 08:58:48 pm »
i have the arcade edition tho, and iam still having issues.
StriderDSO
« Reply #3 on: September 16, 2011, 09:35:58 pm »
Well that's a little disconcerting, especially seeing as I plan on having SSFIF:AE with two U360s soon too :P
(\__/)
clickhea
« Reply #4 on: September 17, 2011, 02:51:27 pm »
i played with it for about an hour and i still cant seem to get it to work... anyone?
StriderDSO
« Reply #5 on: September 17, 2011, 06:48:07 pm »
I can't be of any help, but if you do figure something out, would you be able to post it here, because it's probably something I'll have to deal with soon!
Do both the U360s have unique IDs assigned under Windows? (they need this, right?) Do they work fine in all other games? Just not SSFIV?
(\__/)
clickhea
« Reply #6 on: September 17, 2011, 07:29:44 pm »
yes they work fine in every other game except this one, and they both have unique ids so i have no idea what the problem could be.
clickhea
« Reply #7 on: September 18, 2011, 09:20:47 pm »
okay so heres what i have figured out so far
player 1 joystick must be set under the in game joystick options.
player 2 joystick must be controlled by xpadder. (mapped under in game keyboard 2 options)
It really is a huge pain in the ass because although its working now, it seems like at times its still acting a bit funky.
« Last Edit: September 18, 2011, 09:24:26 pm by clickhea »
StriderDSO
« Reply #8 on: September 19, 2011, 01:03:30 am »
Weird. Once I get mine running I'll let you know if I run into similar issues. Thanks for your solution.
(\__/)
StriderDSO
« Reply #9 on: January 23, 2012, 12:29:06 pm »
Old thread I know, but I did get this working on my machine in case you were still having problems, Clickhea.
After some time, I ended up getting around to installing SSFIV:AE with two U360s (all buttons are using an I-PAC, and not the U360s built-in encoder). I had some troubles similar to what you described where I would try to buzz in with the second player and I would lose control, or where I would press 1up's start, and then it would think a second player was joining and then I wouldn't be able to control player 1 anymore.
All problems now seem to be resolved after installing Joy2Key and using only the keyboard 1 & keyboard 2 configurations in the game, making sure that joystick 1 & joystick 2 settings were cleared and set to <NONE>. Everything works perfect now.
(\__/)
